Old 12-10-2014, 05:15 PM   #71
VTRTWIN
Drives: BRZ Limited - Shiny Black
Originally Posted by technoid View Post
I also completed the install using these instructions. Thanks to Runny_Yolk for the terrific post.
Don't be afraid, it was easy enough.
Side Note:
I also tested a second camera with a splitter, plan to use this for a front mounted camera (curb view) The camera works, but I need to find the wire that triggers the radio to display the camera view. It is not detecting video from the camera, only displaying video when reverse trigger activates it.
I can confirm that a Pyle PLCM38FRV also works with the head unit, and has the ability to remove the lines and also is reversable for a forward or reverse view. This is a very cheap camera and appears to be well made, not currently using so no word on durability though.
The above got me thinking about whether the rear camera can be activated not only when in reverse, but also while driving forward with some sort of switch. My simple thought to do this is to tap into the hot lead to the head unit for the camera with an on-off switch to "trick" the head unit into thinking the car is in reverse. But before I try this and turn my car into a smoking cinder I thought to ask this esteemed group if anyone has actually done this and if so, how? Thanks.
VTRTWIN is offline   Reply With Quote
Old 03-02-2015, 07:59 PM   #72
ChrisJ
ChrisJ's Avatar
Drives: 2014 Subaru BRZ
Thanks for the great help. I made a few bonehead mistakes, but learned a few things in the process.
My camera came with a red and black wire from the camera, and a red wire on the cable to the head unit. I had to solder the red wire of the camera cable to the red wire of the body harness cable, and then solder the cable to the connector at the head.
I grounded it to the cover of the speaker amplifier in the trunk.
The ground on the harness connector is really too short. An extra inch and a half makes all the difference. Or so they say.
I found the best place for the extra cable is in the door sill.
I found a really easy way to check if the camera works with a 6V head. Take a mini LED flashlight, open it and take the battery pack out. It should be three AAA batteries delivering 4.5 volts. The pack has a plus and minus terminal for easy checking. Mine powered right up with 4.5 Volts.
Lastly, you can test the camera without putting the car in reverse, which is kind of nice if you have the head unit resting on the shifter. Press Map --> Then press the three buttons together, then Failure Diagnostics --> System Check. If it comes up OK you're good to go. I can't say this works when a relay is in place, but it worked for me.
Happy modding, C
ChrisJ is offline   Reply With Quote
The Following User Says Thank You to ChrisJ For This Useful Post:
notout86 (03-02-2015)
Old 03-02-2015, 10:21 PM   #73
notout86
Drives: GTS 86 auto
" I found the best place for the extra cable is in the door sill "
Each to his own but I am surprised that people continue to use the door sill method. Having used that myself (for parking sensors), as well as the method between the back seats and tucked up under the lower edge of the console, thence up behind the dash to the head unit, I found the latter much easier.
GTS86 Auto (Australia)
notout86 is offline   Reply With Quote
Old 03-02-2015, 10:28 PM   #74
notout86
Drives: GTS 86 auto
See post #65 in this thread and the link in it. From that you will be able to work out your "view while driving forward" idea.
Old 03-04-2015, 07:17 AM   #75
tracerit
Drives: '13 SSM BRZ Limited 6MT
can i confirm if this is the right cable to get?
http://ae64.com/images-e41/16-pin_ca...arness_LG6.jpg
stock BRZ with stock Fujitsu Ten HU and I'd be using it with the Rydeen Duo as well.
tracerit is offline   Reply With Quote
Old 03-04-2015, 04:49 PM   #76
DC2R
Drives: 2014 Scion FR-S
Do you need any special adapters for an aftermarket radio?
DC2R is offline   Reply With Quote
Old 03-05-2015, 12:29 AM   #77
tracerit
Nope just the stock radio.
Old 03-06-2015, 01:30 PM   #78
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
Yes, that harness (the 'bypass' version) will work and is the one I recommend for a BRZ, FR-S, or GT86.
The purpose of these adapter harnesses is to convert the OEM HU's proprietary socket to a standard female RCA socket. Aftermarket HUs with rear camera capability normally will already have an RCA socket for that, so they don't need an adapter harness.
One exception is the Pioneer AVIC-X9310BT that Subaru Canada fits as the "OEM" HU in some models. It's identical to the aftermarket AVIC-X930BT, except it omits Pioneer's harness with a bunch of RCA jacks (including the one for rear camera). You can buy a replacement Pioneer RCA harness on eBay or Amazon to regain the missing jacks. Search "AVIC-X9310BT" here for more info.
SVXdc is offline   Reply With Quote
The Following User Says Thank You to SVXdc For This Useful Post:
tracerit (03-06-2015)
Old 03-06-2015, 02:22 PM   #79
tracerit
Just sent payment information. Thanks for confirming the correct cable. Looking forward to it!
Old 06-05-2015, 02:07 PM   #80
stoked_on_spool
Drives: 2013 BRZ, SSM, Limited, M/T
Great writeup! Thank you for taking the time and effort to bring this to the community!
*Ninja edit*
stoked_on_spool is offline   Reply With Quote
Old 06-05-2015, 07:17 PM   #81
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I installed mine with svdx harness and works perfectly
Old 06-05-2015, 08:46 PM   #82
notout86
Drives: GTS 86 auto
Originally Posted by zinzan View Post
This is a matter of preference, drilling into a plastic trim piece vs poking a hole into the trunk release grommet. I preferred drilling into the OEM designed location for the backup camera, and not interfering with the trunk release button. If for some reason I ever wanted to remove the backup camera, the cleanly drilled hole could be covered with a pop clip or a rubber plug easily enough. Yes, it is off-centered, but most OEM backup cameras (like the one in my wife's Honda Odyseey) are off-centered, and the BRZ Head Unit is calibrated by default for the camera to be off-centered.
-Z
Our Toyota 86GTS h/u gave a distorted view with the cam in the OE position and I found it much better centred. I suggest always trying temporary mounts (BluTac) first.
The Following User Says Thank You to notout86 For This Useful Post:
zinzan (06-24-2015)
Old 06-25-2015, 04:01 PM   #83
brz_enthusiast
Drives: '13 BRZ Limited WR Blue
Pictures on the original post seem to have disappeared.
'13 BRZ Limited 6MT | Perrin Catback | AEM CAI
brz_enthusiast is offline   Reply With Quote
Old 07-03-2015, 03:56 AM   #84
a_dee
a_dee's Avatar
Drives: '14 BRZ CBS
Got any step by step instructions on how to run the wires from the trunk via the rear seats and through the centre console?
'14 BRZ CBS
>>Pretty Stock
a_dee is offline   Reply With Quote
WRB BRZ - 2 step paint correction & Opti-Coat by Mr. Sparkle Detailing - Long Island Mr. Sparkle Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 02-10-2013 11:04 PM
step 1 :buy frs in phx, step 2: drive to pikes peak haymaker FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 08-21-2012 11:44 AM
[StreetFX] License Plate LED light upgrade, and DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 12:38 PM
[StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 12:27 PM
