Old 01-24-2012, 03:02 PM   #71
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by phenoyz View Post
is 3000 rpm at 60 mph normal or high?
its high for most engines
the higher an engine can rev the smaller you can make the gears, smaller gears means more acceleration and more torque to the ground because smaller gears multiply torque at a greater value....
for example my car puts down about 130 something torque to the ground with my current mods, a 2010 mustang puts down about 200 torque to the ground but it doesnt rev as high, if you calculate the amount of torque to the ground through gear ratios im a bit behind, but since im like 800 pounds lighter i walk away cause my engine isnt pushing a boat like the mustang...
my top speed is about 155-165 depending on which way the wind is blowing... lol
his tops out at about 150 if the governor were to be taken off...
EDIT: at these speeds CoD comes into play and im slicker through the air, he has a higher amount of torque to the ground at that point but i still have the higher top speed because i dont have to fight as much air as the mustang does....
gearing in high reving engines is a must because we lack so much in torque...
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 01-24-2012, 04:27 PM   #72
kanundrum
Drives: 2013 Whiteout FR-S
Drive it like you live your life a 1/4 mile at a time.
Old 01-24-2012, 05:04 PM   #73
carbonBLUE
Reverse Burnouts
i drive like i live my life smoking corner at a time
soon ill be taking me and my friends 67 supercharged mustang fast back to the track bringing 8 sets of rear tires....
(wont forget you)
2011 Infiniti G37x
Old 01-24-2012, 05:05 PM   #74
kanundrum
lool.
Old 01-24-2012, 05:33 PM   #75
phenoyz
Drives: 2011 Honda Fit Sport
coz my car a honda fit sport has 3000rpm at 60 mph, would this also
affect the car's MPG?
i wonder what honda was thinkin when they made it like this on the fit
they should have added more hp, than just increase its rpm
phenoyz is offline   Reply With Quote
Old 01-24-2012, 05:40 PM   #76
serialk11r
Drives: '06 AM V8V Coupe
It depends on the size of the engine. Your Honda Fit has what, 1.5L? Honda gave it more revs so power in the top gear would be better. If it were 2.0L, to maintain approximately the same level of reserve power you would only need 2250rpm. So in fact, it is the BRZ that is revving too high, not your Fit.
The reason they use a smaller engine is it has lower frictional losses at the same rpm (but not power!), and is cheaper to manufacture.
Old 01-24-2012, 07:03 PM   #77
phenoyz
it has 1.5L engine.
But does a high RPM affect your mpg?
(i hope the brz/frs has a reasonable mpg, not a gas guzzler)
thanks
Old 01-24-2012, 07:47 PM   #78
serialk11r
So the spark ignition internal combustion engine is extremely efficient at mid range rpm, full load. Good engines have peak thermal efficiency of around 40%. This seems like a low number, until you consider that your local power plant with its constant power, highly controlled operating conditions only manages 40%. However when we are at constant speed cruising, the power requirement is TINY, and most cars use only 20% of maximum torque. At these low specific output levels, two phenomena are by far the most important; friction and pumping loss.
Higher rpm means less torque is needed for the same power, so pumping loss increases. In addition, friction increases as a proportion of output with rpm, due to the fact that bearing forces are much higher when reciprocating mass is moving faster. An additional problem with choking the engine off so much is that the effective compression ratio is much lower, and if the gearing is bad enough, the piston does negative work on the bottom portion of the power stroke (although this typically doesn't happen). Also, much of the friction in an engine is not load dependent; as mentioned before, the reciprocating mass is always creating substantial friction. When you are asking less torque of the engine, friction only decreases slightly, and becomes a much larger proportion of total output. Add in the power lost to pumping air past the throttle, and you get that half the fuel you are burning is burned just to overcome these losses.
Now running at higher rpm does have one efficiency advantage: cooling losses. At lower speed, each power stroke occurs in a longer period of time, and so the amount of heat lost to the cooling system as a proportion of power is higher. At higher rpm the absolute quantity of heat lost is higher, but this indicates that the cylinder temperature is higher, which is good, because it means more heat is doing useful work rather than warming up the cooling water. This is why efficiency can drop off at low rpm, particularly on engines with poor surface area to volume ratio cylinders (aka, less displacement per cylinder). Another aspect that varies quite a bit is combustion efficiency; Higher rpm=intake air is moving faster=fuel mixes better, but direct injection basically rewrites this rule.
However, it is almost always the case that the relatively lower friction and pumping losses overcome the inefficiencies of low rpm cooling loss. Power and torque are directly related, thus rpm and torque at the same power are inversely related. Thus if you halve the gear ratio (the torque multiplication ratio between engine and wheel), you double the torque requirement. It's not hard to see that dropping rpms from say, 2500 to 2000 would increase the torque requirement by 25%. That would be, using 25% of the engine's torque rather than 20%. This might not seem like a big difference until you consider the fact that by increasing output by 25%, and decreasing rpms by 20%, the non-load dependent part of friction has been reduced by 20% in absolute terms, but because power is up 25%, friction has effectively been cut something like 40%! In addition, the work going into pumping the air through the throttle has decreased while your total work per unit air is increased, another win-win for efficiency.
Typically, around 50-60% volumetric efficiency is thermodynamically ideal in the sense that it dumps the least amount of heat out the exhaust. However because of the effects of friction and pumping loss, as well as the fact that more compression raises the thermal efficiency, a typical gasoline engine hits maximum thermal efficiency at about 75%-80% maximum torque. Now if you have an Atkinson cycle style engine, the maximum torque is limited about 75%, and maximum thermal efficiency is at 100% torque output.
Variable valve timing makes all this much more complicated, but the basic principles still stand. That is why a BMW 3.0L engine fails to get >30mpg even though it has a very fancy valvetrain that eliminates pumping loss at part load; the extra cylinders pose a large increase in friction, among other things.
As for this engine, what we see is that it has a relatively long duration cam that is optimized for high rpm power, and it has no variable lift/duration system of any kind. What this tells us is that at lower rpm, the inevitable thing that happens is that part of the charge is pushed back out the cylinder on the compression stroke! To achieve this however, the lift needs to be relatively high to not pose pumping resistance. This makes our engine in essence a direct injected Prius at low rpm, with a little more displacement and shorter gears. As I noted, the gears are pretty typical (aka, too short for fuel economy), so fuel economy won't be Prius stellar, but it will be pretty good because the car is so small and takes relatively little power to go through the air.
Old 01-24-2012, 07:50 PM   #79
3scapist
Argues nekkid
3scapist's Avatar
Drives: 08 E92 M3
MPG schmedpg, it's a damn sports/ish car.
-Alex USAF SSgt
08 E92 M3
07 Kawasaki Ninja ZX6r
14 Subaru BRZ STI- Future track slut
3scapist is offline   Reply With Quote
Old 01-24-2012, 08:02 PM   #80
serialk11r
And to directly answer your question phenoyz, the BRZ/FRS will probably get around the same mpg as your Fit at constant cruise, because it is smaller (less aero drag), direct injected, and pumping losses will be a little greater. Overall? Hard to say.
And for people who say fuel economy be damned? Well 99% of cars never hit the track, so this is pretty relevant.
Old 01-24-2012, 08:17 PM   #81
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Yah, mpg not important -> please view any "Should I buy an RX8" thread.
Especially since it's not EVO/Sti power, fuel econ will be expected to be decent. I think it's going to be a fantastic highway car.
Khyron686 is offline   Reply With Quote
Old 01-24-2012, 08:40 PM   #82
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
MPG is pretty important to me. My WRX gets about 24mpg on my regular commute, sometimes as low as 19 if I have too much fun. If the BRZ gets, let's say 33mpg on the same commute, that's a 40% improvement (optimistically I think I could beat that, but we will have to see what the final EPA numbers are). That means I can save about $50-100/month in gas based on my rough back of the napkin calcuations (right now I am easily spending $300+ on gas most months, 40% of that is $120 in savings). So in theory I could justify a good portion of the payments on this car based on the money I'm saving on gas.
Spaceywilly is offline   Reply With Quote
Old 01-24-2012, 09:04 PM   #83
phenoyz
serialk11r, thanks again for the reply
if i buy the brz/frs this will be my dd, and will most likely will not be track
am not a rich person like others here are, so a good mpg is appreciated
will probably trade my 2011 fit for brz if they price it right
Old 01-24-2012, 09:06 PM   #84
borge12
Drives: Tie Fighter
Originally Posted by Spaceywilly View Post
MPG is pretty important to me. My WRX gets about 24mpg on my regular commute, sometimes as low as 19 if I have too much fun. If the BRZ gets, let's say 33mpg on the same commute, that's a 40% improvement (optimistically I think I could beat that, but we will have to see what the final EPA numbers are). That means I can save about $50-100/month in gas based on my rough back of the napkin calcuations (right now I am easily spending $300+ on gas most months, 40% of that is $120 in savings). So in theory I could justify a bulk of the payments on this car based on the money I'm saving on gas.
Yeah, me too. If the BRZ does get gas mileage around the Cruze Eco, for example, it will be saving me near $1k per year. That's HUGE for me and even bigger for my accountant(wife).
borge12 is offline   Reply With Quote
