Old 05-30-2013, 12:34 PM   #71
onefasazn
Drives: Chevrolegs
Originally Posted by Draco-REX View Post
REALLY???
You can do it all by hand. Subaru uses only enough preload to keep the springs seated. It's even easier if you have a buddy. Get everything aligned, then one person pushes down on the tophat and the other gets the nut started. From there you can use hand tools. Hell, I'm 250lbs so I was able to do it myself. There's no need to do something silly like lowering a car onto a disassembled strut.
Yup I agree. When he told me he did it that way, I told him to jack his car up and I would re-do it. Guy didn't have much experience on cars but he is learning. Had to show him that the right way was not that hard. Helps if you have the right tools as well...
onefasazn is offline   Reply With Quote
Old 06-01-2013, 02:43 PM   #72
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Just installed these with RCE's yellows, it was cake to do with the right hand tools (the open center ratchets with a good allen key works wonders) - took awhile getting everything done but this is only my second go around with replacing springs on a car - wouldn't dream of just dropping it down on the strut to compress, knowing my luck I'd end up popping something through the fender!
mikalem is offline   Reply With Quote
Old 06-01-2013, 03:47 PM   #73
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Are you having any popping issues with the whiteline mounts?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-01-2013, 09:30 PM   #74
mikalem
mikalem's Avatar
Aftwr 30 miles or so of shakedown the car is solid, no unwanted/unexpected noises. Double checked the mounts were with the newer bushings too.
Sent from my SGH-M919 using Tapatalk 4 Beta
Old 06-02-2013, 06:26 AM   #75
Calum
That Guy
Drives: 2013 asphalt FRS MT
Yeah mine were still good after the first couple days aswell. Not so much after a week.
Sent from mission control
Old 06-02-2013, 09:07 AM   #76
makinen
makinen's Avatar
Drives: Toyota 86
Originally Posted by enjoyminutemaid View Post
UPDATE: Yesterday, I swapped the OEM tophats back on my Koni/RCE Yellows and the noise went away. I also noticed that the bearings on the Koyo-bearing COM-Cs will spin, but not smoothly, and they definitely don't spin nicely like the bearings on the OEM tophats. The clunking I had is also gone. I had the COM-Cs professionally installed a month or so ago, then reinstalled the OEM tophats yesterday using a spring compressor.
I had same problem with mine after just one day of a track event. Before that event, no noise happened. After installing stock top hats again, the clunking noise is gone. SAD......
makinen is offline   Reply With Quote
Old 06-02-2013, 11:53 AM   #77
wootwoot
Drives: FRS
Damn it.... I guess I'll just get rid of mine before I install them. I don't want to have to deal with this issue on my car. Can someone tag whiteline in this thread and maybe they can chime in on what they are doing about this?
wootwoot is offline   Reply With Quote
Old 06-02-2013, 01:57 PM   #78
mikalem
mikalem's Avatar
Spoke too soon it seems, I have a popping sound when leaving the driveway that it wasnt doing yesterday. Looked over some of the trouble shooting mentioned here and elsewhere, seeing some deflection under load. Product was from 5/2/13, emailed Jan, waiting on what he has to say to check.
Sent from my SGH-M919 using Tapatalk 2
Old 06-02-2013, 03:37 PM   #79
feldy
feldy's Avatar
so weird. I wonder if these will never work with the frs. The frs has more suspension travel then the imprezzas do. maybe we need more rubber for when these things are full turned.
Old 06-05-2013, 11:17 AM   #80
feldy
feldy's Avatar
My new ones came in today. They came in a different box then last time. Had the new bearings but no dust caps. Also no return tracking slip either.
Old 06-07-2013, 12:35 PM   #81
feldy
feldy's Avatar
Got the new replacement ones on last night. So far everything is good. Going to be leaving work and doing a little back road driving to see if something happens.
Old 06-07-2013, 01:16 PM   #82
Calum
That Guy
Keep us posted. Mine are being shipped today.
Old 06-07-2013, 03:15 PM   #83
d1ck
Drives: Black 2013 FRS
I've been dealing with Daniel at Whiteline USA, and he's been very helpful. I'm on my second set of mounts now and one of them is popping and clanging sometimes. I've got the Subaru washers that you're supposed to use as well. He's going to send me another mount when they get more stock in. I'm starting to lose faith here, but he did say that their own car runs V3's with these mounts trouble free.
d1ck is offline   Reply With Quote
Old 06-07-2013, 03:21 PM   #84
Calum
That Guy
Could you post a link to where it says that we're supposed to use those washers?
upgraded mounts? 7thgear Engine, Exhaust, Transmission 19 01-11-2013 11:31 PM
Buyer Beware: Motor Mounts cobrabyte Engine, Exhaust, Transmission 5 01-04-2013 08:14 PM
Autocross Camera Mounts? fritzy BRZ First-Gen (2012+) — General Topics 7 08-03-2012 10:48 PM
SEAT BRACKETS / SIDE MOUNTS - Planted Technology - Font Motorsports Font Motorsports Interior Parts (Incl. Lighting) 2 07-03-2012 06:43 PM
Dash Mounts for gadgets smbrm Cosmetic Modification (Interior/Exterior/Lighting) 0 06-28-2012 07:07 PM
