Old 04-28-2013, 01:27 PM   #71
iketiak
iketiak's Avatar
Drives: 2013 Toyota 86/Scion FRS
Originally Posted by tbwoodlee View Post
As someone who has done it myself I can definitely say I would not take it to a dealer. The wiring is incredibly easy.
Since the bumper has to be removed you can bet the dealer will charge you a pretty penny and I am all about saving some money. Having done quite a few mods to the vehicle myself, I will say that this one is one of the easier ones. Hell, I had a harder time with the fog lights.
I just wanted to check if I wired everything up correctly from the starting from the top left row is pin number 1.
I'm tapping 12v power for the DRL's just below the horn assembly but DRL's do not light up when driving regularly.
If anyone can correct or verify that it was wired correctly I would really appreciated it, Thanks in advance!
iketiak is offline   Reply With Quote
Old 04-29-2013, 07:28 AM   #72
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Originally Posted by dokterdewe View Post
Are you talking about BCU ? Main Body ECU ???
Correct.
I've read about a DRL resistor behind the bumper, I wonder if it's missing from our cars?
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 05-01-2013, 08:23 AM   #73
dokterdewe
dokterdewe's Avatar
Drives: an automatic lightning red 86
Send a message via Yahoo to dokterdewe
Originally Posted by HRTROB View Post
Try plugging in a relay on the empty DRL slot inside the fuse box in the engine compartment. It worked for us over here in the Philippines. Let us know how it goes!
i have PM-ed you..
try to look at Moto-P diagram again.. or try contacting him (PMs, or email..)
Originally Posted by sav View Post
Correct.
don't you think the DRL relay slot means it works as resistor too ?
dokterdewe is offline   Reply With Quote
Old 05-12-2013, 05:14 AM   #74
Overland'n'5thGEN
Overland'n'5thGEN's Avatar
Drives: 5th Gen Toyota 4Runner
Ok so this is a mod on my small list that I am checking off. My question is when I order the LHD set of lights do the HID bulbs and balast come with the lights?
I also plan on cracking them open and blacking the chrome out around the projector.
Thanks in advance. I am sure I will have wiring questions once I get them.
Overland'n'5thGEN is offline   Reply With Quote
Old 05-27-2013, 11:25 PM   #75
bggns
Drives: 2013 Scion FR-S 6AT, Asphalt
The bulbs and ballasts do come with the lights.
bggns is offline   Reply With Quote
Old 10-12-2013, 03:06 PM   #76
DeOppressorLiber
DeOppressorLiber's Avatar
Drives: FRS Full Blown Custom
Curious to how many people would be interested in a Plug and Harness for the FRS to GT86, Eurospec LHD and 10Series lights.
The Trypticon Transformation in Progress!
DeOppressorLiber is offline   Reply With Quote
Old 10-14-2013, 01:40 PM   #77
DeOppressorLiber
More interest in these than what I expected. I have some available. PM me because the way these are wired you actually have a couple options on brightness of the L.E.D's. These are OEM CONNECTORS wired specifically for your taste.
Old 10-15-2013, 09:48 PM   #78
tbox
tbox's Avatar
Drives: GT86
I did some digging and found part numbers for the headlight to harness connectors just to see how much it'd cost to make one myself. An 8pin JDM to 6pin FRS adapter would cost $50+....I think I'd rather save some money and just re-pin the JDM 8-pin onto the FRS 6-pin for $6.
FRS 6-pin:
Male connector: 90980–11033 ~$6
Male terminals: 82998–12430 ~$15
Male seals: 82998–12450 ~$5
Female connector: 90980–11034 ~$6
Female terminals: 82998–12460 ~$15
Female seals: 82998–12440 ~$5
JDM 8-pin:
Male connector: 90980–10896 ~$7.50
Male terminals & seals: same as male 6-pin
Female connector: 90980–10897 ~$7.50
Female terminals & seals: same as female 6-pin
Source: http://www.toyota-tech.eu/wire_harness_rm/RM06H0E.pdf
tbox is offline   Reply With Quote
Old 10-16-2013, 02:33 PM   #79
DeOppressorLiber
FRS 6-pin:
JDM 8-pin:
I am glad you posted the part numbers because I had already ordered most of the parts. The male and female terminals is for one terminal only with a pigtail. It is crazy! When I ordered them I thought they would come in a pack of at least 6 or more but nope just one for 15 bucks! So if you order all the parts from Toyota its going to cost over 120 bucks just for the terminals at dealer cost plus the seals at 5$ each plus the connectors. My best friend is a master mech at Toyota and we even ordered a terminal repair kit and to replace the terminals is the same price. Not to mention you have to have the crimpers to crimp the terminals. So to make them by going through Toyota will actually cost right at 200 bucks! So I called some other companies like Aeromotive and they want 86 bucks for the 8 Pin connector with pigtails and they dont have the 6 pin. So that option was out the window. Currently from the manufacturer of the male and female terminals, they come on a roll of a thousand. Any ideas?
Old 10-27-2013, 05:59 PM   #80
Calavera
Calavera's Avatar
Drives: Scion FR-S Whiteout
Harnesses from DeOppressorLiber
Got the harnesses from DeOppressorLiber and man were they helpful. After a pain in the rear bumper removal (more than likely cause I did it alone) the harnesses were just what I needed.
If my calculations are correct, when this baby hits 88 miles per hour... you're gonna see some serious shit.
Calavera is offline   Reply With Quote
Old 11-20-2015, 08:48 PM   #81
ganjara
ganjara's Avatar
Drives:
Originally Posted by WWEVOX View Post
LHD eauro spec is the best way to go. You would likely get the high light cutoff on the correct side. However, I understand that if you order right from the factory, you will get the lamp unadjusted for either side, meaning you wouldn't blind people in either direction but you also don't benefit from a little extra lighting. My lamps are like this. Since I'm not being a blinding jerk to anyone, I don't mind not having the extra lumination off to the side.
The leveling sensor isn't necessary. The default position is the "0" height so it's where you would have your lights set most of the time. (but in case you want leveling, you need the sensor and leveling ecu).
Ancient thread wake up! Sorry about that. I've been searching far and wide
Has anyone plugged in the auto levelling ECU into a FRS or base model 86? I'm assuming it works plum n play but somebody put doubt in my mind saying it's dangerous and you can brick the whole car/ECU by doing something like this?
Would love to hear if someone has fit the auto levelling ECU. I need to in order to run the The GTS hids legally in Australia and is only thing holding me back
ganjara is offline   Reply With Quote
Old 11-21-2015, 02:31 AM   #82
sav
sav's Avatar
Surely you'd need the leveling sensors on the front and rear control arms as well?
95RON SAV Tuned
Old 11-21-2015, 02:35 PM   #83
ganjara
ganjara's Avatar
Drives:
Yep correct, there's only one leveling sensor on the rear lower control arm though.
Have never understood how that sensor actually transmits information to the ECU as I can't see any OEM wiring, but that's another issue lol
Old 05-15-2016, 02:19 PM   #84
ahquit
ahquit's Avatar
Drives: Whiteout FR-S
Resurrecting this old thread...
From reading the thread it sounds like the gt86 and jdm lights would be wired the same since Moto-P seems to use either title interchangeably.
However, I picked up a set of jdm lights (will swap to lhd cutoff) and they only have 6 wires in the 8 pin harness, not 7 like in Moto-P's guide.
For anyone who installed actual jdm lights (and not euro gt86 lights), what order did you pin the wires?
I saw the garagefrs page, and the lights they used also have 6 wires but not all the same colors (theirs has a white wire but mine has a green wire). So it's a bit confusing! (Below is a pic of mine)
Sent from my A0001 using Tapatalk
ahquit is offline   Reply With Quote
gt86, gt86 headlights, headlights, lhd
Plug N Play Super Bright LED Kits @ JWM- FREE SHIPPING! JWMotoring Interior Parts (Incl. Lighting) 166 03-23-2014 08:08 PM
ECU Plug and Play Mo707 Engine, Exhaust, Transmission 8 08-26-2012 11:21 AM
Xenon HID Conversion PLUG & PLAY jarviz Cosmetic Modification (Interior/Exterior/Lighting) 5 08-01-2012 05:34 PM
HID Plug 'n Play Kit JW89225 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 07-31-2012 12:17 AM
Which hid plug n play kit? huma Cosmetic Modification (Interior/Exterior/Lighting) 11 07-20-2012 11:10 PM
