Old 12-05-2012, 12:41 PM   #71
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by Frostyman View Post
normally I have no cold start issues, but today it was in the 60s, and still didn't start first crank. Second crank did it. I'm gonna take some logs and send them in after I get car back from the dyno this evening.
Were you on the e85 map before startup? Mine was 42 this morning and it fired up right away.
JoeBoxer is offline   Reply With Quote
Old 12-05-2012, 12:46 PM   #72
Yruyur
Yruyur's Avatar
Are you tapping the gas at all on start or just turning the key.
Sent from my flux capacitor using Taptalk
Old 12-05-2012, 12:54 PM   #73
JoeBoxer
JoeBoxer's Avatar
I turn the key to on, switch to map 4 and turn the key to start I don't touch the gas pedal.
Old 12-05-2012, 12:55 PM   #74
Frostyman
Drives: 2013 Raven FRS
e-85 is the only map I have currently. I took it to the dyno today, and found that my AFR is SUPER rich. so that's probably why.
Frostyman is offline   Reply With Quote
Old 12-05-2012, 12:56 PM   #75
xjohnx
Grip>Slip
xjohnx's Avatar
keep in mind there are 3 different "blends" of e85 available that change based on your state and the month. If i recall, the ethanol content goes down to as low as 70% at certain times during the year. That could explain why some of you were seeing no issues while others had trouble.
The Following User Says Thank You to xjohnx For This Useful Post:
Yruyur (12-05-2012)
Old 12-05-2012, 12:58 PM   #76
xjohnx
Grip>Slip
xjohnx's Avatar
What AFR numbers were you seeing?
Old 12-05-2012, 01:16 PM   #77
JoeBoxer
JoeBoxer's Avatar
Same question, some of mine look a little lean but definitely not rich.
Old 12-05-2012, 01:19 PM   #78
Frostyman
at 2.5k RPM afr was 14.5, then from 3.3k it dropped below 10, and the engine started to knock and misfire at 6700
Old 12-05-2012, 01:22 PM   #79
2forme
I think you should fill up and flash back to 93 until FA20Club can fix that for you.
Good thing you took it to the dyno and saw what it was actually doing instead of just driving it around until something went wrong...
Old 12-05-2012, 01:26 PM   #80
JoeBoxer
JoeBoxer's Avatar
Never seen anything that low on mine, what other mods do you have??
Old 12-05-2012, 01:32 PM   #81
Frostyman
I have the AFE intake, which was making me run lean, and the perrin crank pulley. So my guess is overcompensation after the lean CEL that popped over the weekend.
Luckily, the issue doesn't show up until 3k+ rpms, so I can at least drive it home from work and get it fixed.
Old 12-05-2012, 01:42 PM   #82
xjohnx
Grip>Slip
xjohnx's Avatar
Were you datalogging the run too? if so, it should help them a ton with a fix.
Old 12-05-2012, 01:44 PM   #83
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
CEL for lean. Now it's in limp mode perhaps?
Jeff86 is offline   Reply With Quote
Old 12-05-2012, 01:45 PM   #84
Frostyman
Unfortunately I was not. I was at work, while the car was at the dyno. I'm going to take her for a ride tonight and log it, hopefully have a new flash by the morning.
APEX-i SMART Throttle Controller - preliminary test. Moto-P Engine, Exhaust, Transmission 33 05-24-2015 07:01 PM
REVIEW: FA20Club Tune, AFE Intake, and Perrin Pulley draggin_az Engine, Exhaust, Transmission 21 04-29-2013 04:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
FA20CLUB.com E85 Goodness FA20Club.com Engine, Exhaust, Transmission 45 11-13-2012 01:05 PM
Tunehouse BRZ Tuning program preliminary details Hachiroku Engine, Exhaust, Transmission 42 06-25-2012 07:40 PM
