Old 05-09-2013, 12:32 PM   #71
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
Originally Posted by TYPEONE86 View Post
for the people want to upgrade their fog....u guys can order the pigtail from this website.
http://www.spoonzauto.com/product_p/hn-brz-h11.htm
Nice...I see they stole my pictures!
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 05-13-2013, 08:32 AM   #72
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
Installion of these is very easy. Like 10 minutes each side easy. Remove 4 clips on fender liner and 2 screws on fog light housing. Install new housing, connect adapter harness and button it back up.
I used these adapter harnesses:
Some tips that I learned form the install. Reuse the pressed in bushings from the stock housings on the holes with the screws and wrap the other tabs with a few wraps of electrical tape. This will make the housings fit tightly into the opening. See pic below for the bushings. Just press them out and install them into the new light housing.
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
Old 07-03-2013, 03:35 PM   #73
joergasm
joergasm's Avatar
Drives: Subaru BRZ 2013 - SWP 6MT
Is it possible for the h11's to fit into the stock harness and to just get the pigtail connectors?
Sent from my SGH-I317M using Xparent Skyblue Tapatalk 2
joergasm is offline   Reply With Quote
Old 07-03-2013, 05:55 PM   #74
jpit
Drives: Subaru BRZ
Those people buying new H11 bulbs - are you getting the 35W or the 55W? Thanks.
jpit is offline   Reply With Quote
Old 07-05-2013, 09:36 AM   #75
Philly758
Drives: GMC
If you look at the pictures BRZNutt posted, it looks like he used 55w.
Also, has anyone used the stock bulb that comes with the new fog? Would there still be an improvement? New bulbs look nice but they cost about as much as the fog assembly...
Philly758 is offline   Reply With Quote
Old 07-05-2013, 12:00 PM   #76
Diode Dynamics
Diode Dynamics's Avatar
I would strongly advise against using a 55w HID in that housing.
55w generates a lot more excess heat than a 35w kit. You run the risk of damaging your factory housing (lenses etc*) by using a 55w.
-Nick C.
John C.
Diode Dynamics
Old 07-06-2013, 07:07 PM   #77
Extreme86
Live Free, Drive Hard
Extreme86's Avatar
Drives: 13 BRZ, 19 WRX, 10 GMC, 20 RAV4
Thanks @Opie for sharing this info on a better BRZ foglight option! Pulled the trigger this morning on the following:
45.13 EA. PN# 84501AJ00A @ subaruparts.com
10% OFF and free shipping coupon code: 5KQoRzW2 (Sparktacular Savings - The Sequel) Expires: 7/7/13 https://www.facebook.com/subaruparts
$81.24 Shipped for two.
5202 to H11 Pigtail Sockets wires for BRZ FR-S fog lamp conversion.
$11.99 Shipped for two.
[ame="http://www.amazon.com/Optilux-H71071132-Series-Yellow-Halogen/dp/B002E2WMWG/ref=cm_cr_pr_product_top"]2 - Hella Optilux H71071132 XY Series H11 12V/55W Xenon Yellow Halogen [/ame]
$20.20 Shipped (Got mine from an ebay seller for a few dollars less. It was the last pair.)
Above is a $113.43 mod. Not bad IMO. I've used the H11 yellow halogens in foglights on other vehicles and tend to like the way they help visibility. The H11 bulbs have got to be a huge improvement over the OEM setup!!!
Better hurry to take advantage of the coupon code!!! Make sure subaruparts.com manually subtracts the shipping charge as mentioned on the FB post.
Extreme86 is offline   Reply With Quote
Old 07-28-2013, 12:50 AM   #78
WRB-DZA-BRZ
Cookie Monster
WRB-DZA-BRZ's Avatar
Drives: 2013 Subaru BRZ Premium 6-MT WRB
I've searched and read through this thread... and I'm still not entirely clear.
What will I need to install fogs like these on my premium BRZ (no stock fogs)?
Do premiums with no fogs still have the wiring present for the fogs?
Do I just need the proper fog bezels? Part number?
Also, what's the deal with the oem fog kit not bring compatible with early VIN BRZs?
WRB-DZA-BRZ is offline   Reply With Quote
Old 07-28-2013, 02:20 PM   #79
xn7485
Drives: 1995 Acura Integra GS-R
Here's the Subaru accessory install guide. Got part numbers and picture diagrams. I not entirely sure, but I think there is still wiring for the fogs in the premium, I do see them add a switch or a light on the inside though.
Just replace the fogs listed in the manual with the outback ones listed in this thread.
- Haven't heard anything about oem fog kit not being compatible, you'll have to get other people's input on that.
This is still on my to-do list so.. hope it helps.
xn7485 is offline   Reply With Quote
Old 08-12-2013, 10:47 AM   #80
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
can someone tell me the OEM BRZ foglight lens diameter. i'm trying to swap lenses and i dont know what size i need.
and also does someone know the diameter of the outback foglight lenses?
Jive Turkey is offline   Reply With Quote
Old 08-17-2013, 10:17 AM   #81
Philly758
Drives: GMC
I ended up ordering Sylvania 9006 SU SilverStar Ultra Halogen Headlight Bulbs
Not sure about the bulbs... But I wanted the whitest/brightest bulb (with a reasonable price) to compliment my HID's
Old 08-17-2013, 02:17 PM   #83
ANREX
ANREX's Avatar
Drives: GT86
Originally Posted by Mari0 View Post
Has anyone with an FR-S tried buying those, plus the foglight turn lamp cover (OEM, Gazio, or anything else) to get a stock(looking) foglight set up on their car that will not cost $550+
:happy0180:
ANREX is offline   Reply With Quote
Old 08-17-2013, 04:39 PM   #84
ANREX
ANREX's Avatar
Drives: GT86
:happy0180:
http://www.kadean-dev.com/pro.asp?cP...5,&cLa=1,5,181,
DIY Rear foglight Silverdub DIY (Do-It-Yourself) Guides 159 04-09-2018 12:14 PM
Is foglight wiring in the car? FastLap Scion FR-S / Toyota 86 GT86 General Forum 7 08-26-2012 11:54 PM
Foglight replacement help Zadkiel Cosmetic Modification (Interior/Exterior/Lighting) 4 08-06-2012 11:11 AM
Rear Bumper Foglight kanundrum Cosmetic Modification (Interior/Exterior/Lighting) 2 06-08-2012 12:47 AM
