#71 |
THANK YOU
Its 5 degrees and this saved me a really cold ride home - had to join just to say thank you!
#72 |
Drives: 2013 Argento FR-S
Would putting something like 303 Aerospace on the seals prevent the window from sticking in cold weather?
#73 | |
If your window seals aren't already being pulled out of it's seat I highly recommend applying some sort of rubber conditioner monthly. Helps the window slide past with less resistance. I hate these seals haha it brings out my inner OCD |
#74 | |
Drives: 2013 FR-S Ultramarine 6MT
This issue is a common occurrence and not only in the FR-S. My Cooper S had the same problem as well as my Dodge 2500. It becomes expected here in new Hampshire. Especially with the weather like last Sunday, rain and 40's then by early morning teens, frozen windows! Inconvenient but not the end of the world. Let the interior warm up and don't force the window.
#75 |
Boosted
Drives: Sideways
I found that holding the window up button on the driver window for several seconds is the fastest method. You can just skip the hold window down button altogether.
#76 |
I've only had my FR-S 6 months and the window thing has happened to me 3 times, all on cold days. The service tech said I was the first complaint and just held the window buttons down until they reset. Two weeks ago, he did the same but admitted that they had another lady in that same morning with the same issue. I made an appointment to bring the car in today to be checked out. When I went this morning, he told me that Toyota issued a TSB on 1/9/14 about the windows. Seems there is something faulty afterall. They are ordering parts to fix the problem.
#77 |
Drives: 86, Santa Fe, bicycle, sailboat
Stealership
I wish I checked here before going to the dealer. I also had a frost issue with windows. The dealer said it was not a warranty issue and wanted 55 bux. Such a simple fix.
Hello, nice to meet you.
#78 |
Drives: 2013 Scrion FR-S
Hopefully this will be my final post in regards to my window. The third party lubricant Toyota applied to my passenger window seems to have done the job. The window has worked in truely frigid temps (single-digits for days, etc.).
Thankfully, however, my Toyota dealership service center just called and told me Toyota finally has an official fix. They're going to replace the weather-stripping along the base of the windows and install more powerful window mechanisms that move the window up and down. As my dealership has been told, this apparently has worked seemlessly in all Toyota testing. Anyone who's car is still under warranty (or who wants to fight with Toyota to replace the parts at no cost), I would suggest asking for this fix. |
#79 |
Drives: WRB Limited BRZ
Omg lol I'm having this same exact issue ever since it got COLD AS FCK and tonight is gonna be 5 degrees lol
#80 |
FR Noob
Bummer
Guess it's about time I join the club on this window issue. Tried the "hold-down to reset method", didn't work. Run out of time trying to figure this out but will try again later...
Here's the symptom: * Car was parked outside in the cold over night 15*-30*. It didn't get stuck on ice or anything since both windows are dry this morning. * The auto scroll up/down still work on both windows when opens/closes. * Can't use the master switch from driver to close/open passenger window. However, it still open/close normally from its switch. Auto up/down still working fine. * The "auto" (fully press/hold) no longer function for driver side. It still open/close just have to fully press/hold.
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in |
#81 |
Drives: 2013 FRS
This forum is life <3. Last night weather dipped down to 30 and this morning I was freaking out. But after the reset it works perfectly fine now
#82 |
Drives: 2016 Scion FR-S
Mine is a 2016 and the resets do not seem to work on the passenger side window
any tips? Also the passenger side window button does not light up at all on either sideSent from my Nexus 5X using Tapatalk |
#83 |
Drives: 2013 FR-S, hot lava
i feel like there are two problems here:
1. blinking lights on the window switches, no window function 2. lights on window switches don't work, switches do not work, auto up/down on door open features DO work i have problem #2 on my pass window. if anyone was wondering the low here is in the 50's. it's not freezing up. also the reset doesn't work for me. window tint has been on there for 2 years and this is the first time this has happened. off to the dealer. |
#84 | |
![]() humfrz |
| Passenger's Auto Window Scroll | Bonburner | Issues | Warranty | Recalls / TSB | 204 | 04-17-2018 07:34 PM |
| Window auto close module..? | luv85 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 11-18-2012 01:05 PM |
| Passenger window mystery | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 09-07-2012 02:30 PM |
| Teaking Tail light and Driver side passenger window auto down | feyrerm | Issues | Warranty | Recalls / TSB | 2 | 08-11-2012 12:32 AM |
| Auto up and down window Issues? | CzRceCar | Issues | Warranty | Recalls / TSB | 3 | 08-07-2012 07:44 PM |
