#71 |
Drives: 2013 FRS
Have some news ! I installed my bride Zeta iii 's this weekend. Drivers side was previously done a year ago since I just replaced my cusco bride seat w the new red one.
Passenger side I used a resistor from bride which required soldering and also removed the occupancy sensor from the passenger seat and installed it underneath the cloth on the bride since you can remove the center pieces on the zeta iii bucket seat. I'm happy to report everything works like it's from factory. No need for a seat belt insert. No airbag light. Someone sits in it and airbag turns on and when they get off, airbag turns off. Sent from my iPhone using Tapatalk Last edited by ft86me; 08-17-2015 at 11:43 PM. |
#72 | |
Drives: Fr-S
"mr.Balloon hands, no way, get real..."
#73 | |
Drives: 2013 FRS
#74 |
Drives: 2014 FR-S
Having an issue with this DIY. bought the right resisters as per thread plugged it in and still light. So i disconnected battery tried another resister connected battery and still have air bag light. Let it be known i tried the resister kit that was being sold from a site mentioned earlier but not the toyota or subaru one. that didn't work. is it possible that plug maybe blew a fuse? thats why light is still on?
#75 | |
Drives: Black GT86 from UK
I am having the exact same problem as
-Max Butler |
#76 |
Working perfectly!
#77 |
Drives: 2014 Raven Black FR-S
Airbags After Front End Collision?
Hey guys,
So I bought my FRS as a theft recovery vehicle for super cheap, 5,200 miles on it, 2014 model. Its going to be my track car... so I don't want or care about having airbags anyway, so even though the steering wheel airbag deployed, I modded the wheel with an airbagless wheel, replaced the front bumper & hood, no frame damage or anything... so worked out for me! It has the resister installed on the airbag leads that attach to the clockspring, but I do still have an airbag light. Going to try to pull the fuse to see if that light will turn off... any suggestions on whether that will work or not? Going to be putting in after market seats sometime soonish too... Open to suggestions! - Sweetspeed |
#78 |
Drives: SWP BRZ
does anyone know if a 3.3 ohm 1/4 watt resistor work instead of 3.3 ohm 1 watt? found one at a local radio shack. i dont really want to buy it online since most are in a pack of 10 and 8$+ when i only need one
#79 | |
will a 2watt work? |
#80 | |
Drives: Vortech Supercharged FR-S
Will I be able to restall the seat cover after I took out the sensor? I got a pair of BRZ limited seats and thinking to swap in to my FRS. People say there will have airbag issue because BRZ heated seats and FRS regular seats have different sensor. So I am thinking to swap the sensor. Do you think I will be able to recover the seatcover?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. |
#81 | |
Drives: 2013 Whiteout Scion FRS
#82 |
I actually took off the cover on both BRZ and FRS complete sensor set last weekend and swap the seats; however, the swap is not 100% functional. The seatbelt light keep on and it seems like the sensor detect that there is person on the passenger side. I have to put a seat belt plug to turn off the light.
#83 | |
#84 | |
when you turn the chime off, i assume that the seatbelt light will still on, just no chime. am i correct?
| Light Weight Seats | sw20kosh | Tracking / Autocross / HPDE / Drifting | 23 | 11-06-2012 11:15 PM |
| Aftermarket Seats sets off SRS light? | Hanakuso | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 08-25-2012 05:09 PM |
| Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! | DjDATZ | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 06-28-2012 11:21 AM |
| FR-S / BR-Z Racing Seats!!! | vividracing | Interior Parts (Incl. Lighting) | 8 | 06-19-2012 08:07 PM |
