#71 | |
I'm going to run the MCA traction mod, the sway bar is something I'll chase out as I may or may not use one. I haven't really decided yet Sent from my Pixel 7 Pro using Tapatalk
2013 FR-S being tortured to run a Maserati V8
https://www.ft86club.com/forums/showthread.php?t=152230 https://www.youtube.com/playlist?lis...t7TZX7iZuC45Rs |
| The Following User Says Thank You to Rex1585 For This Useful Post: | Ohio Enthusiast (12-30-2024) |
#72 |
Drives: 2018 BRZ
The MCA mod still needs the stock connection point (it bolts to it). You can use the GP Sport mod - it only uses the subframe bolt (and a few additional bolts to the chassis).
I think somebody used the 2nd gen BRZ sway bar mount in a 1st gen. It might be possible to do the same for your custom subframe (as the 2nd gen BRZ mounts to the chassis using the mounting bolt rather than to the subframe). |
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | Rex1585 (12-30-2024) |
#73 | |
Thanks for the info on the GR86! I'll dig for some photos, etc. Sent from my Pixel 7 Pro using Tapatalk
#74 |
Drives: 2018 BRZ
It's the 2nd gen BRZ that has the new sway bar mount. The GR86 uses the same mount on the subframe as the 1st gen.
#75 |
Drives: Crapcan
The trailing arm goes from the body to the knuckle.
#76 |
Drives: 2018 BRZ
Nope, it goes to the subframe (AFAIK that's the whole point of a subframe - to have the suspension attached to it instead of the chassis (which actually makes the 2nd gen BRZ rear sway bar (attached to the chassis bolt) kinda strange)). Hard to find good pictures showing it, but this one from MCA calls it the crossmember:
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | NoHaveMSG (01-03-2025) |
#77 | |
Drives: Crapcan
#78 |
Drives: 2018 BRZ
Yeah, there's a reinforcement bracket that goes to the body (below the subframe). The GP Sport mod replaces that bracket, effectively connecting the trailing arm pickup point to the chassis instead of the subframe (unlike the MCA mod that keeps it on the subframe).
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | Rex1585 (01-11-2025) |
#79 |
Newest video is up. I am hoping to get onto the start of the tubular subframe this next week before February.
I have a few loose ends I need to tie up on the daily driver before I can start playing again, but these should be fairly straight forward. As always, let me know what you guys think!
#80 |
Drives: 2018 BRZ
Another option for the rear sway bar mount with your custom subframe could be this aftermarket mount. It got posted on the new GR86 forum and it might work well in your case.
#81 |
Newest video is finally complete!
Let me know what you think.
| The Following User Says Thank You to Rex1585 For This Useful Post: | T-Steve (08-03-2025) |
#82 |
I got the reinforcement plates drawn up, I just need to get them over to send cut send or someone else. I'd really like them to be done in strenx, but none of the companies that have those services offer it as an option.
https://www.aedmetals.com/store/mate...nx-domex-sheet I'll figure something out. Here is a quick teaser of what I'm thinking.
| The Following User Says Thank You to Rex1585 For This Useful Post: | T-Steve (08-25-2025) |
#83 |
Big things in the works, after a lot of reading, asking people in the know of the Maserati cars. The ability to use the factory Bosch ECU would be too much of a challenge to accomplish my goals.
Because of this, I am going to be going with a Motec M150. This allows me the use of the factory gauges and Toyota wiring and chassis electronics. It will also allow me some really crazy things I can do for driveability. Torque based traction control, launch control, are among the other neat things I can do. I have also been able to get all of the needed hardware, spacers, material, and fasteners for the rear subframe build.
#84 |
I just ordered my first 3D printed metal parts
To say I'm excited is an understatement.
| The Following 4 Users Say Thank You to Rex1585 For This Useful Post: |
| Swapping FRS Door on BRZ | Coop | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 07-17-2018 01:05 PM |
| Engine swapping my first car. | MK42Dragon | Engine Swaps | 23 | 04-01-2018 06:55 AM |
| BRZ to FR-S Trunk Lid Swapping | wahsaihin | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 11-05-2014 07:22 PM |
| spoiler swapping?? help? | Justinyuen16 | FR-S / BRZ vs.... | 2 | 07-10-2014 10:04 AM |
| Swapping springs need HELP! | SleekMachine | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 07-17-2013 04:05 PM |
