#71 | |
Sent from my ONEPLUS A5010 using Tapatalk |
#72 |
Drives: 2018 Subaru BRZ Limited with PP
True, but with modern technology, even cheap cars like Mazda seem to do it just fine. So I wouldn't think it to be impossible, but rather cool and beneficial in terms of NA. But as you said, it's a cheap sports car, and also a fairly cheap gen 2 upgrade, so I wouldn't expect them to make a major change like a 13.5:1 CR as this would require some more extensive work on the engine.
#73 | |
#74 |
I hear ya! I'm simply saying I wouldn't take it to be impossible, but definitely less likely when they've managed with some struggles on 12.5 in gen1.
#76 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Dzmitry (06-10-2021) |
#77 |
Drives: 2015 Subaru BRZ WRB
#78 |
Drives: Crapcan
If you want to go that far you might as well do pistons since the FA/FB's are cast. At that point you are better off putting that 2500 extra towards a K swap.
#79 | |
Having your FA heads and timing cover cleaned and prepped $800ish FA20 OE forged crank $400 FA20 aftermarket con rods $300-600 FB25/FA24/FA20 custom sized pistons $600+ ARP head studs $250 FB25/FA24 HG $100~ So you really are only at like $3500 or so in extras before the normal cost of a rebuild which can be like $3500 or so. So like $7k Can you do a full K swap for $7k And have boost ready internals? |
#80 | |
Drives: Crapcan
I am not saying you can't do it and be under a K swap. I am saying the savings isn't worth what you are left with. If it is that good and easy they why aren't people doing that over a K swap?
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Tcoat (06-27-2021) |
#81 | |
https://www.subarusource.com/oem-par...aft-12200aa490 Right, those rod bearings, main bearings, case studs, and seal kit would go along with everything else in a normal rebuild. Also I'm under the impression that ARP case studs aren't needed until you break into the 600whp range. |
#82 | |
Drives: Crapcan
#83 | |
What retainer kit did you get ? |
#84 |
Drives: car
@irax pretty sure the FB engine has a different timing cover design and wouldn't fit FA20 heads. This was evident during the J02 recall since the FB engine recall procedure was much simpler than the FA20.
| The Following 2 Users Say Thank You to radroach For This Useful Post: | Goingnowherefast (06-28-2021), Tcoat (06-28-2021) |
| FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 10:18 AM |
| 2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members | Cookiemonster | Engine Swaps | 18 | 05-25-2019 12:40 PM |
| FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 03:59 PM |
| Dead RB25 Swap, Alive 2jz swap | -Phil | Engine Swaps | 72 | 09-15-2018 02:35 PM |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
