Old 06-10-2021, 02:16 PM   #71
Ashikabi
Ashikabi's Avatar
Originally Posted by Dzmitry View Post
I believe this was a mistake when the BRZ launched or a simple mistake made by someone that ended up widespread all over. Toyota claims it to be 12.5:1 and I believe there was a collaboration of both not too long ago also mentioning 12.5:1 - which I would think is the correct CR. It would also make more sense for them to stick to 12.5:1 rather than complicating things more with the engine.
13.5 in a cheap sports car like this would be pretty crazy.
Sent from my ONEPLUS A5010 using Tapatalk
Old 06-10-2021, 02:21 PM   #72
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
True, but with modern technology, even cheap cars like Mazda seem to do it just fine. So I wouldn't think it to be impossible, but rather cool and beneficial in terms of NA. But as you said, it's a cheap sports car, and also a fairly cheap gen 2 upgrade, so I wouldn't expect them to make a major change like a 13.5:1 CR as this would require some more extensive work on the engine.
Dzmitry is offline   Reply With Quote
Old 06-10-2021, 02:27 PM   #73
Ashikabi
Ashikabi's Avatar
Mazda is just over there doing freaky Mazda stuff. How many other cars under 100k have that CR?
Old 06-10-2021, 02:40 PM   #74
Dzmitry
Dzmitry's Avatar
I hear ya! I'm simply saying I wouldn't take it to be impossible, but definitely less likely when they've managed with some struggles on 12.5 in gen1.
Old 06-10-2021, 02:43 PM   #75
Ashikabi
Ashikabi's Avatar
It's certainly possible. Just not plausible
The Following User Says Thank You to Ashikabi For This Useful Post:
Dzmitry (06-10-2021)
Old 06-10-2021, 02:58 PM   #76
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Direct injection helps a lot in making this possible. The D4S system works very well.
Old 06-12-2021, 05:18 AM   #77
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
The FB25 has a worse rod to stroke ratio(the FA20's is already not great), thinner rods, and thinner rod bearings then an FA20. Pass.
Like i said you swap out for the fa20 crank and fa20 aftermarket rods.
irax is offline   Reply With Quote
Old 06-12-2021, 12:01 PM   #78
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you want to go that far you might as well do pistons since the FA/FB's are cast. At that point you are better off putting that 2500 extra towards a K swap.
Old 06-25-2021, 01:18 PM   #79
irax
irax's Avatar
FB25 short block $500
Having your FA heads and timing cover cleaned and prepped $800ish
FA20 OE forged crank $400
FA20 aftermarket con rods $300-600
FB25/FA24/FA20 custom sized pistons $600+
ARP head studs $250
FB25/FA24 HG $100~
So you really are only at like $3500 or so in extras before the normal cost of a rebuild which can be like $3500 or so.
So like $7k
Can you do a full K swap for $7k And have boost ready internals?
Old 06-25-2021, 01:34 PM   #80
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
ARP head studs $250
FB25/FA24 HG $100~
So like $7k
A new OE crank is not 400, it is about 650. Don't forget rod bearings, main bearings, ARP case studs, full seal kit.
I am not saying you can't do it and be under a K swap. I am saying the savings isn't worth what you are left with. If it is that good and easy they why aren't people doing that over a K swap?
Tcoat (06-27-2021)
Old 06-25-2021, 01:40 PM   #81
irax
irax's Avatar
Sorry last time I looked at them they were like $400ish
https://www.subarusource.com/oem-par...aft-12200aa490
Right, those rod bearings, main bearings, case studs, and seal kit would go along with everything else in a normal rebuild.
Also I'm under the impression that ARP case studs aren't needed until you break into the 600whp range.
Old 06-25-2021, 01:51 PM   #82
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'm of the opinion of "while I am in there." Especially the abuse from tracking my car. Personally if it was me I would probably do springs/retainers and a rocker retainer kit too, which I should have delivered today for my FA.
Old 06-26-2021, 04:18 PM   #83
irax
irax's Avatar
Fair enough.
What retainer kit did you get ?
Old 06-27-2021, 08:00 PM   #84
radroach
Drives: car
@irax pretty sure the FB engine has a different timing cover design and wouldn't fit FA20 heads. This was evident during the J02 recall since the FB engine recall procedure was much simpler than the FA20.
The Following 2 Users Say Thank You to radroach For This Useful Post:
Goingnowherefast (06-28-2021), Tcoat (06-28-2021)
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 10:18 AM
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members Cookiemonster Engine Swaps 18 05-25-2019 12:40 PM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 03:59 PM
Dead RB25 Swap, Alive 2jz swap -Phil Engine Swaps 72 09-15-2018 02:35 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
