Old 09-22-2020, 01:42 PM   #71
Sasquachulator
Pavement Grey
But I thought Miata was always the answer, thus eliminating the entire list except that....
Torque dip is always the answer.....
Or was that always the question?
The Following User Says Thank You to Sasquachulator For This Useful Post:
Dadhawk (09-22-2020)
Old 09-22-2020, 02:09 PM   #72
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Well you ain't sen us get off topic yet!
As the previous owner of three top trim Lancers (not Evos) I can assure you with 100% confidence this is ten times the car and you will not accidently "drift" unless you are really pushing it. Forget that it is RWD since most of what you hear about driving one is pure myth created by generations used to FWD.
With REAL snow tires (not "performance" ones or supposed All Season) these things are a tank in the snow. I have had to stop in deep snow and push AWD cars out of my way to get down some streets.
The main thing to grasp is how RWD will behave on throttle. The nannies do a pretty good job, but they are pretty intrusive. Gearing and wheel speed is important.
I find it harder to accidentally drive straight over the winter months. Mainly due to my inner 5 year old.
It's extremely predictable and makes you properly appreciate this chassis in the snow. Throttle, it goes sideways, off throttle is straightens out. Modulate to be somewhere between doing circles and going straight. Second gear is the most fun, the wheel speed seems about perfect for about any hooning you want to do while having a controllable wheel speed.
From a stop you almost have to let the rear end move around to get momentum. I can see that making some uneasy.
you can leave the nannies on but it kills so much wheel speed which you often need for low speeds in the city.
For maximum sideways on the lockstops
Old 09-22-2020, 03:23 PM   #73
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
I thought they came that way from the dealer.
Ok, that one got an audible laugh from me!
CrowsFeast is offline   Reply With Quote
Old 09-23-2020, 03:26 AM   #74
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by Sasquachulator View Post
one car for each purpose:
-Drift car
-Cargo carrying car
-Trailer hauling truck
-family hauling car
-zombie apocalypse SUV
-go-fast-in-a-straight-line car
-drag car
So you better have a bigass garage because cars are clearly intended for use with one and only one purpose each.
Exactly!
That's why I just bought a house with a 900 sq ft barn on a concrete slab, additional covered parking for four cars (or five if two of them are British sports cars or Japanese kei cars) and no HOA to bitch if I park cars on any of the three driveways or on the 1/2 acre out back.
I'm only up to four vehicles now, but I suspect I might do some shopping in the next year or two after I get the house and my well a little better fortified against the apocalypse. I'm really starting to want a '68-'70 AMX for driving in straight lines.
The Following User Says Thank You to extrashaky For This Useful Post:
p1l0t (09-24-2020)
Old 09-23-2020, 07:24 PM   #75
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
We used to drift these all the time!
It is possible that I drove the very one pictured actually.
Didn't call it "drifting" and had no idea it would eventually be a real sport but you could break traction and side them around a corner with relative ease once you learned the trick.
The Following 3 Users Say Thank You to Spuds For This Useful Post:
Dadhawk (09-24-2020), p1l0t (09-24-2020), Tcoat (09-23-2020)
Old 09-23-2020, 10:16 PM   #76
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
Originally Posted by Ohio Enthusiast View Post
These cars are certainly tail happy. I moved to my BRZ from a Focus ST and it's hilariously fun to get the tail out a little in slow tight corners or feel the push of the rear end in a fast sweeper. Both of these require active driver control - you need to be aggressive on the gas pedal to get there.
If you drive the car at a reasonable speed for the road and don't mash the gas you won't have to worry about unexpected oversteer. For me, the beauty of the Twins is that they are controllable, allowing you to approach RWD driving dynamics at your own pace and at your comfort level.
If you drive a Twin like a regular car you won't need to worry about oversteering or drifting, but as you grow more confident, comfortable and interested it will allow you to explore that, unlike FWD or most AWD cars.
Yes the twins are amazing at giving you all the feedback you need. You really have to apply a lot of throttle in a corner to get oversteer, and if you leave traction control on it will keep you from spinning. Sport mode on the older cars and Track mode on the newer cars allows more slip before traction control kicks in, but it still saves you. The limited slip differential is great at keeping power down also. Plus there isn’t much torque there anyway.
Even with the stock all season tires there is plenty of grip, and if you get better tires there is even more grip.
So basically I think the twins are better at grip than drifting, in stock form anyway.
JesseG is offline   Reply With Quote
Old 09-23-2020, 10:26 PM   #77
JesseG
JesseG's Avatar
Originally Posted by Lantanafrs2 View Post
Fuck. I knew it. Mustang time
Just be prepared for the Mustang’s insatiable appetite for people...
The Following 4 Users Say Thank You to JesseG For This Useful Post:
Lantanafrs2 (09-23-2020), NoHaveMSG (09-24-2020), soundman98 (09-24-2020), WildCard600 (09-23-2020)
Old 09-23-2020, 10:32 PM   #78
JesseG
JesseG's Avatar
The BRZ is built for grip driving anyway. The FRS is the DRFT model.
There is still plenty of grip in the FR-S, it’s just a little easier to provoke oversteer.
One thing I will mention, on my FR-S with TRD springs, it’s not very happy with mid corner bumps. A softer spring setup would be easier to control through a corner. It’s never scary, but something to be aware of. Applying throttle mid corner with a bumpy surface, something has to give.
The Following User Says Thank You to JesseG For This Useful Post:
p1l0t (09-24-2020)
Old 09-23-2020, 10:38 PM   #79
JesseG
JesseG's Avatar
That’s a good point, leaving traction control fully on will pretty much kill the throttle to prevent a spin. And that gets really old once you get a better feel for the car. Sport mode is usually good enough for me driving on the street.
Old 09-23-2020, 10:55 PM   #80
Spuds
The Dictater
Spuds's Avatar
5 second press. Every time. Except rain.
... Well, usually not in rain...
The Following 4 Users Say Thank You to Spuds For This Useful Post:
daiheadjai (09-24-2020), JesseG (09-24-2020), RToyo86 (09-24-2020), soundman98 (09-24-2020)
Old 09-24-2020, 12:22 AM   #81
JesseG
JesseG's Avatar
I’m not that dedicated to holding the button down
Old 09-24-2020, 12:34 AM   #82
Spuds
The Dictater
Spuds's Avatar
It's a way of life.
[Turn around, walk away, play music, roll credits, fade to black]
The Following User Says Thank You to Spuds For This Useful Post:
JesseG (09-24-2020)
Old 09-24-2020, 06:56 AM   #83
p1l0t
p1l0t's Avatar
The Following 6 Users Say Thank You to p1l0t For This Useful Post:
Dadhawk (09-24-2020), NoHaveMSG (09-24-2020), soundman98 (09-24-2020), Spuds (09-24-2020), The Red One (09-24-2020), Ultramaroon (09-27-2020)
Old 09-24-2020, 01:32 PM   #84
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have a switch for full disable of TC
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
JesseG (09-24-2020), soundman98 (09-24-2020)
If Anyone's Interested... MuseChaser Scion FR-S / Toyota 86 GT86 General Forum 13 05-01-2018 09:02 PM
2 LCA I am interested in. DriftEightSix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 02-17-2014 05:05 AM
Anyone interested in doing a dent day? YDNA Southern California 22 11-19-2013 04:10 AM
Who would be interested in this ? Garstang Scion FR-S / Toyota 86 GT86 General Forum 1 11-05-2013 01:27 AM
