Old 06-22-2020, 10:07 PM   #71
Racecomp Engineering
You can definitely make these into nice GT cars with better handling and ride quality than stock. With a 1 inch drop too.
- Andrew
Old 06-23-2020, 01:47 PM   #72
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
- Andrew
I was leaning towards yellows and B6, you think they will do that?
Ernest72 is offline   Reply With Quote
Old 06-23-2020, 02:12 PM   #73
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Bilstein B6/B8 are monotube. And monotube shocks are more performance oriented instead of comfort oriented, so no. GT means comfort so you're better off with twin-tube shocks.
I've lowered my Saab on Eibach Pro-Kit's (1.2" drop) and its B6 shocks HATED it. The ride was attrocious after. IMO you need the B8 for any amount of lowering.
N_Raged is offline   Reply With Quote
Old 06-23-2020, 04:19 PM   #74
ZDan
ZDan's Avatar
Drives: '23 BRZ
B8/B6 ride fine, better than stock PP Sachs for sure.
Also B6 are fine for lowering up to about an inch, springs won't be "loose".
I got B8s with 1.25" lower Swift springs but with further research I found that people have run the same springs with B6.
Racecomp Engineering (06-23-2020)
Old 06-23-2020, 04:26 PM   #75
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Good to hear, can you elaborate? I test drove a PP a few weeks ago and I HATED the bounciness in the front. Hoping that RCE yellows with B6s will be more compliant.
Old 06-23-2020, 04:30 PM   #76
ZDan
ZDan's Avatar
Drives: '23 BRZ
My impression is the Bilsteins have less high-speed damping (less harsh/crashy) and more low-speed damping (firmer under braking/cornering, maybe a bit less bouncy over undulations with stiffer springs vs. Sachs)
Yoshoobaroo (06-23-2020)
Old 06-23-2020, 05:11 PM   #77
B6 and RCE Yellows is a great combo.
It was my plan for my own car, which was initially supposed to be an all around street fun daily driver. Lots has changed since then with my car, but it's still a great combo!
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
Ernest72 (06-24-2020), Yoshoobaroo (06-23-2020), ZDan (06-23-2020)
Old 06-24-2020, 08:50 AM   #78
sneaky_pete
Drives: MY14 86 GTS Manual Velocity Orange
Originally Posted by nashcarr View Post
Big difference from BRZ w PP. Have driven and ridden in it. She has as well. The TRD springs on anything but smooth roads are crap.
They didnt do their homework and they are really not damped properly with the TRD lowering springs. Down at the Dragon they were great, but I live in Ohio where the roads blow
I COULD buy some OEM springs and swap them out or by coilovers as well.
I could also complain about the TRD springs since they are under warranty, they MIGHT replace them, who knows???
I swapped out the stock springs in my MY14 86 GTS (Australia) and put in the TRD units along with the TRD sway bars.
i doubt our roads are any better than yours.
In terms of ride quality I find very little difference between the stock springs and the TRD in their initial travel, the TRDs are a tad firmer for sure but still comfy for most conditions. when you hit bigger bumps the TRDs hit the bumps stops which is to be expected since they are lower, even though the bump stops are smaller - reaching the limit of the travel in the damper I guess.
the most noticeable difference between the two is how flat the car sits in corners, way flatter with the TRD springs, the sways will have something to do with it too.
there would have been a fair bit of development work go into the TRD springs and the TRD sways. they may not be perfectly matched to the stock dampers but they wouldn't have released them as a kit for the car if they were not going to be a handling improvement. they would have specified new dampers if that was the case.
I like them a lot. I don't think you are going to find any relief in a BRZ - it's going to be different but not chalk and cheese.
My wife got sick in our 86 on the stock suspension - she hasn't been in it since but she is fine with it. Ours isn't a daily and she knows what it means to me so its not going anywhere. she loves the look of the little jigger too.
maybe the twins aren't the car for you. hire one with stock suspension and see what you think.
sneaky_pete is offline   Reply With Quote
Old 07-19-2020, 01:17 PM   #79
gpvecchi
gpvecchi's Avatar
Update on my post with latest discoveries.
https://www.ft86club.com/forums/show...9&postcount=36
gpvecchi is offline   Reply With Quote
Old 07-20-2020, 11:04 AM   #80
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Originally Posted by gpvecchi View Post
Update: reading a Japanese article, I discovered that Subaru added a couple of stabilyzing spoilers behind rear wheels, on the bumper in models G and H, and suspensions have been tuned accordingly. Toyota didn't, that's why Subaru rear shocks have been revised, but not Toyota's.
Is that what the tiny plastic piece behind the rear wheel is?
dragoontwo is offline   Reply With Quote
Old 07-20-2020, 11:24 AM   #81
N_Raged
Yes I have them on my 2019. They look so insignificant I wouldn't think it would warrant changing the damping rates to compensate.
The Following User Says Thank You to N_Raged For This Useful Post:
dragoontwo (07-20-2020)
Old 07-20-2020, 02:32 PM   #82
gpvecchi
gpvecchi's Avatar
Those.
Old 07-20-2020, 04:24 PM   #83
Ernest72
It supposably just smooths out the turbulent air go around the rear end. I got them for my BRZ, they were $30 bucks on eBay. Can’t say they do anything.
Old 09-05-2020, 02:09 AM   #84
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I have Bilstein spec'd by STI dampers in a 2015 BRZ and I'll check now the Sachs factory dampers in a 2020 BRZ. The springs on the Bilstein are 10mm lower, so the height difference is not that much. I'll be interested mainly on a comparison of damping characteristics. I am aware that factory was constantly improving the chassis stiffness and suspension up to manufacturing year 2019, so pretty interested to see how far they went.
FS: Performance Package Sachs Springs and Dampers Desai_N Brakes, Suspension, Chassis 3 01-15-2020 07:12 PM
Looking to purchase 2018 BRZ performance package Sachs mitama Want-To-Buy Requests 0 07-01-2019 12:52 PM
Sold...2017 OEM Performance Package shocks 86MLR Australia Classifieds 7 10-06-2018 01:56 AM
WTB: 2017 performance package Sachs dampers panand Want-To-Buy Requests 1 03-16-2018 02:57 PM
FS; 2017 PP Struts performance package shocks brz sokol Brakes, Suspension, Chassis 3 08-30-2017 09:26 PM
