#71 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
#72 |
#73 | |
Panda Trueno
Drives: No twin now.
| The Following User Says Thank You to Summerwolf For This Useful Post: | venturaII (09-16-2019) |
#74 |
Only users lose drugs.
Drives: All the time
Because by picking ANYTHING different from what the rest of the community recommends as a byproduct of experience, he gets to pretend he secretly knows something we don't, when it's really just dumb luck. But hey - lots of people feel the need to think they're the smartest guy in the room. His questions suggest otherwise.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| The Following 2 Users Say Thank You to venturaII For This Useful Post: | Summerwolf (09-18-2019), wparsons (09-17-2019) |
#75 | |
Drives: 2005 Toyota Camry
This is the dumbest way to inspect brake pads. Why? You’re only looking at half of the pads. Any halfway decent mechanic, DIY or professional, will look at both outside and inside pads during an inspection. So yes, you’re right. This is a shitty design. Should’ve made the rotors transparent. |
| The Following User Says Thank You to mav1178 For This Useful Post: | Spuds (09-17-2019) |
#76 |
Drives: 14 BSP Edelbrock BRZ
In Star Trek IV they gave us the designs for transparent aluminum but Scotty didn't mention anything about transparent steel. Aluminum brake rotors would suck, so we're SOL.
| The Following 3 Users Say Thank You to toast For This Useful Post: |
#77 | |
#79 |
No, there may be a reason to avoid the PQ version of the pad. There is a reason he didn't suggest it in the first place, since the prices are similar. Either he's aware of this version, or he's deliberately avoiding them.
#80 | |
....but..but...did you know about the PQ version of the pad? Because he does.
| The Following User Says Thank You to venturaII For This Useful Post: | Summerwolf (09-16-2019), wparsons (09-17-2019) |
#81 | ||
Even worse, only looking at one end of one pad! The wear at the front edge of the pad could be far worse. Quote:
And the calipers/brackets too!
| The Following User Says Thank You to wparsons For This Useful Post: | Spuds (09-17-2019) |
#82 |
Drives: 2014 GT86
No need for transparency. Just add webcam for each caliper and stream 4 videos real-time to audio headunit screen.
#83 |
#84 |
| Bad ball joint;possible to just replace balljoint or do I have to replace control arm | kev0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 01-03-2019 03:07 PM |
| Have to replace entire assembly to replace fuel filter? | tobkin | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 08-04-2017 02:26 PM |
| Vinyl on driver's seat split open; dealer will replace | babydriver | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 12-20-2014 08:55 PM |
| Why do my Stoptech brakes squeel so loudly? Fix or replace? | eikond | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 05-20-2014 02:17 PM |
| Help me replace my rear brakes? | PoWn3d_0704 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 02-28-2014 03:55 PM |
