#71 |
^ Yes that is the one. For fronts only.
- Andrew |
#72 |
Anyone know the out-of-box compression and rebound settings? I have 8 clicks front and 10 rear.
#73 |
Drives: brz 13
#74 |
Thanks.
I always thought you could just adjust settings from any setting. After looking at the manual, I am supposed to turn clockwise to the hardest setting and make adjustments from there. Last edited by BRZranger; 10-06-2012 at 08:14 AM. |
#75 |
Conedancer
Drives: 2013 Subaru BRZ SWP
After about 100 plus runs on my car since new..I am still very impressed with how the KW Var3 works... I have said it from the beginning that they got it right to begin with. They did the R&D and its shows...I have done some minor tweaks to my initial setup but its not that far off from the factory recommended settings.. a couple of clicks on the Rebound and compression, the ride height, and camber settings...(I am using front Plates).. I don't know how the others compare to the KW's but I Know that I got the best product for the money to be competitive in my Class.. the car has a number of class wins and a couple of index wins.. so the car is competitive..
-Recommendations: Alignment is absolute critical with this platform, My car has been on the rack 4 times before I finally figured out the 'sweet spot' -KW's have multiple settings for bump and rebound...Don't be afraid to experiment a bit to know what the suspension is doing. -Ride height is also critical with this platform... Slammed is not the optimum handling option for this car.. it will take some time to play with that too...again don't be afraid to experiment. -spring rates are a personal choice...but I will say the KW's are pretty good out of the box...I have tweeked the spring rates to my liking making the car handle better..but Know that the stock spring rates are adequate.. -Sway bars: I have not found a need to swap out sway bars with the KW's... I have upgraded the bushings and the endlinks...as well as the Rear subframe bushings..Less movement overall makes the car more predicatable.. thats my review in a nutshell ... I won't get into specifics on my settings, Alignment or my setup...I will give you general information... ...besides that my driving style might be alot different than yours.. ... I will say my car is setup to shave 10ths off not just seconds... I will be fighting for a championship next year so I am trying to get the car as comfortable as possible that is fast and instills the most confidence driving it.. one last thing...Car is setup to run with NO Traction Aids whatsoever...ALL OFF.. hope this helps Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#76 |
86-er
Drives: BRZ tS
wonder if the whiteline bushings will make a difference on the subframe, I know its out of the subject but look at the movement on the video.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
#77 |
Drives: Firestorm FRS
#78 |
What a great thread, great idea! I'm certainly on the KW bandwagon for sure, and they seem to be our hottest selling suspension part we sell, great stuff!
#79 |
Conedancer
I would definitely consider the KW's...LIFETIME warranty should do it..
Talk to Sam at Strano Performance...I hear he can get a smoking Deal on these... PM him or Call ... I absolutely love them... Nothing against any of the other brands.. just my opinion of course.. ![]() Any other Questions LMK Bill
#80 | |
Conedancer
, more planted rear and faster times..![]() Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD Last edited by Scooby South; 10-12-2012 at 04:55 PM. |
#81 | |
Drives: Ultramarine frs
Tap'd from my G-Nex
#82 |
Finally did some autocrossing! Went through the alignment before the event. Here is what I ended up with.
Camber 2.5 front and 1.9 rear Toe zero front and 2mm total toe in rear Shock settings, started out about in the middle. front 6 bump and 9 rebound rear 5 bump and 8 rebound First thing I found is I think I need a bit more front camber. Tires were rolling over pretty good and was pushy at turn in. Tho tire temps were dead even across the tire. Not sure how important tire temps are. Next is I was getting oversteer trying to put down power out of corners and in the slolom. I messed around with the shock settings and got the car a little better. I tried both stiffer and softer and it got better little softer, but the problems were still there. So I get pictures last night and it looks like I am lifting the rear tire and almost the front. Looks like a stiffer front and maybe rear might be in order. Open to all sugestions. ![]() ![]() http://www.facebook.com/index.php?st...34940639854901 http://www.facebook.com/index.php?st...34900923192206 |
#83 |
Drives: 2021 Supra / 2022 Tundra
What tires and pressures Max? FSB?
TomR
#84 |
Tires are 255 star specs and running 35 front 33 rear. Stock fsb. Only mods are the Kws with the stiffer spring on the front and rear whiteline camber bushings.
Should add that this is a relatively low grip surface. Pad is very new. Last edited by -max-; 10-16-2012 at 11:43 AM. |
| My BRZ ST* Autocross build | Scooby South | Tracking / Autocross / HPDE / Drifting | 848 | 08-14-2018 12:20 PM |
| Is there a thread for 'people doing stupid things in their brand new car' thread? | Symbiont | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 36 | 02-18-2013 01:24 PM |
| 1st Autocross w/ my FR-S | MarkRacerX | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 24 | 06-24-2012 11:55 PM |
| Will you Autocross your 86? | Ribface | Tracking / Autocross / HPDE / Drifting | 131 | 06-22-2012 06:48 PM |
| FR-S at a CA Autocross | oneday | Scion FR-S / Toyota 86 GT86 General Forum | 57 | 03-26-2012 04:38 PM |
