#71 |
Do you guys do cash deal for local pickup?
#72 |
FT86Club Official Vendor
Drives: Miata, GT350, FR-S
#73 | |
Drives: BRZ 2017 Pure Red, MT
#74 | |
Just the same, we have no plans for a shorter spacer. Too many other projects and our current spacer covers the needs of most people that need one.
#75 | |
Drives: 2014 BRZ Limited
It's a very nice piece of hardware. It's basically two pieces, the spacer that slips onto the splines on your steering column, with an insert that mounts your steering wheel. This is the side that your wheel mounts on: ![]() This is the end that slips onto the splines on your steering column: ![]() Closer shot of the insert: ![]() A 5mm hex key (not included) removes the six bolts holding the insert in place. You'll need to remove the insert to mount the spacer on the steering column. ![]() Since the insert should have exactly the same splines and threads as the steering column, I just stuck it in the spacer so you can get an idea how it mounts: ![]() ![]() As Emilio wrote earlier, there were no instructions. However, there was this warning page. ![]() I found the warning kind of funny because there's a trap here if you don't pay attention to what you're doing. They put the "THIS SIDE UP" label on the insert, which can be installed in either direction. It's the spacer that has to be installed a certain direction, not the insert. If you're not paying attention to which side of the spacer is "UP," once you take the insert out to install it on the column you have nothing to show you which side is up. (Just remember it's the smaller hole.) ![]()
| The Following 7 Users Say Thank You to extrashaky For This Useful Post: | churchx (07-09-2019), cjd (07-10-2019), Hyper4mance2k (08-30-2019), Jdmjunkie (07-11-2019), new2subaru (07-09-2019), strat61caster (07-08-2019), turbofan (07-09-2019) |
#76 |
| The Following User Says Thank You to extrashaky For This Useful Post: | Clutch Dog (07-10-2019) |
#77 |
Weight Weenie
Drives: 15 FR-S
#78 |
949Racing Support
Drives: 1999 Mazda Miata Turbo
Thanks for the detailed photos!
#79 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Thanks for the pictures... absolutely understand why it costs what it does from those pictures. Price is VERY justified.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#80 |
Drives: Scion FR-S 10 Series
Had mine installed today, excellent fitment, it went on super easy. I am very impressed.
#81 |
CAD monkey
Drives: '15 GT86 Giallo - Supercharged
The aforementioned adapter looks identical to the one I got from Girol, Italy
http://www.girol.it/en/motorsport-and-tuning/ Maybe a colab between 949 and Girol? Installing the spacer in the coming days. To the ones who already installed it, did you need to lengthen the cruise control wiring/cables? I'm combining the spacer with the Revolution/J.Luth steering wheel. Can't wait for the most perfect driving position/ergonomics Thanks
| The Following 4 Users Say Thank You to Boccaccio For This Useful Post: | BigTuna (06-29-2020), Clutch Dog (07-11-2019), Hyper4mance2k (08-30-2019), snoxracer183 (07-11-2019) |
#82 |
Drives: 2017 BRZ
And the newspaper is Italian... Not that I care one way or the other.
#83 | |
Drives: 2017 BRZ PP , 2005 Saab 97X
#84 |
Drives: 2014 GT86
@Boccaccio: would appreciate if you'll review later on. I too have J.Luth wheel and not too keen on putting stock wheel back, but rising total offset to 7cm makes me cautious a bit to just pull a trigger on purchase prior hearing similar setup experiences.
| Tags |
| 949, spacer, steering |
| MY2018 GT86 OEM Steering Wheel Spacer | AndMsc | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 06-15-2020 08:51 AM |
| Do spacer's/adapter's cause heavy steering? | lupindub | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 08-30-2016 09:36 PM |
| TE37SL Red $2799 - Rays Volk Racing & GramLights, Advan RSII, Eibach Spacer | eauto | Wheels and Tires | 316 | 10-15-2014 01:41 PM |
| Steering Wheel Adjustment or Spacer | Goya | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 09-29-2014 03:54 AM |
| RAYS RACING DURA NUTS EXTENDED 50MM RED WITH LOCK 20 PCS 12X1.25MM ???? | 20valvewynn83 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 04-07-2013 04:33 PM |
