Old 08-06-2019, 09:30 AM   #71
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by Semiihcircle View Post
The Apex Arc-8 Wheels do fit over the Brembos but interfere with the stock suspension of PP BrZ. When mounted with 245/40r17 Bridgestone Potenza RE71Rs.
That's strange. Do you use camber bolts?
timurrrr is offline   Reply With Quote
Old 08-06-2019, 09:35 AM   #72
Semiihcircle
Drives: 17 BRZ
I think i was at -1 or -.5 degrees with camber, and but there was absolutely no clearance between rubber and spring
Sent from my SM-G973U1 using Tapatalk
Semiihcircle is offline   Reply With Quote
Old 08-06-2019, 10:01 AM   #73
Evan55
Drives: 06 Exige, 17 BRZ PP
17x8 or 17x9?
I would expect most 17x9 wheels to interfere with stock suspension especially with a tire as wide as a 245 RE71R. (heck, that could even rub on a 17x8 depending on offset and camber)
Evan55 is offline   Reply With Quote
Old 08-06-2019, 10:33 AM   #74
Semiihcircle
Drives: 17 BRZ
Originally Posted by Evan55 View Post
17x8 or 17x9?
17x9 When i was in the group buy apex mentioned making the wheel for tires 235-255 and still having negative camber
Old 08-06-2019, 12:10 PM   #75
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
Yup, I've got the same issue. Just picked some up used and at -2 deg with camber bolts they won't even go on because they contact the spring perch. I got them with 245/40R17 Forcuem Hena. Previous owner said he had 3 mm of clearance with 0 camber. He got rid of them because he didn't want to run camber plates but wanted camber. I'm probably going to pull the bolts and go back to 0 camber until I get some coilovers, or I may be able to just add a big spacer.
Horrid_Funk is offline   Reply With Quote
Old 08-06-2019, 12:29 PM   #76
Semiihcircle
Drives: 17 BRZ
Mine would only clear with positive camber, i was told after the fact that not all 245s work, i wish i knew that before hand or i wouldnt have bought them. I had to buy coils else they would be used as door stops
Old 08-06-2019, 01:00 PM   #77
Lebby83
Drives: 2019 BRZ, 2016 Touareg
I know this is a thread about what wheels work but is there any list out there where it states what tires work without rubbing in 245/40/17?
Rob
2019 BRZ Limited Sport
2016 VW Touareg TDI
Lebby83 is offline   Reply With Quote
Old 08-06-2019, 03:19 PM   #78
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
I think that would be a difficult list to achieve. There would be a lot of factors to consider, wheel width, offset, ride height, coilovers etc. That said, most tire manufacturers have the actual width of the tire listed on their sites. 245 width can vary between brands.
In regards to the Apex ARC-8s and spring clearance; I have Continental DWS06 tires/RCE yellows and was not able to achieve more that approximately -0.2 degrees of camber before the tires were too close to the stock springs using camber bolts. Camber plates were necessary to maintain proper clearance.
tehShirt is offline   Reply With Quote
Old 08-06-2019, 05:10 PM   #79
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Re: stock suspension clearance of Apex ARC-8
Can you please bring this up on the thread dedicated to those wheels?
The manufacturer specifically says that they've designed the wheel to be a no-brainer fit for OEM suspension.
In the meantime, I'll make a note on the top post in this thread.
I do however agree that +42 sounds like a pretty aggressive offset, very likely not friendly to camber bolts. FWIW, I'd expect camber plates to be required to be able to dial in any substantial camber with any 245/40 tire on any 17x9 wheel. On top of that, 245/40 on 17x9 looks like a buggy at stock height, so you might want to also lower the car, which is best done with coilovers, and then you might as well get those with adjustable camber plates. An extra re-alignment and corner balancing can cost about as much as just getting the camber plates...
Old 08-06-2019, 06:33 PM   #80
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by SmoothIsSlow View Post
... Performance Pack suspension ... My wheels are Enkei VR5 17x8 +45mm.
Can you please share photos of your car, and how much clearance do you have between the wheel and the PP Brembos? Do you use any spacers?
Old 08-07-2019, 09:37 AM   #81
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by jaydueces View Post
SSR Gtx01
I presume the wheels are 18x8, and the Brembos are the same as the PPs on the BRZ?
Can you please tell us what's the offset on these wheels and whether you needed to use any spacers?
Thanks!
Old 08-07-2019, 03:17 PM   #82
gpvecchi
gpvecchi's Avatar
Thanks!
8.5x18 ET44, same Brembos on 86 and BRZ.
gpvecchi is offline   Reply With Quote
Old 08-07-2019, 07:51 PM   #83
livingasleep
Drives: 2018 Subaru BRZ Sport-Tech RS
mesh style wheel aggressive fitment on performance pack brembos
I previously made a post looking to fit a mesh style wheel on the performance pack brembos, as these are my favorite wheel style. After a TON of research about the caliper size and consulting the wheel manufacturers, Aodhan gave me some confidence saying they previously cleared the 2013 STI, which were pretty similar caliper clearance to our PP brembo kit. I was determined to get this done WITHOUT spacers, which I'm happy to say worked out!
Yes it is TIGHT (1-2mm clearance at the caliper for me), but I will CONFIRM that these clear the caliper. I have ran these for almost a month now (driven ~2km) and have not had any issues with this tight of a clearance.
No the camber and tire stretch is not needed, you can see I have a lot of fender clearance, so a less aggressive camber and more meaty tire is possible.
Dunno if I'm the first to try and clear these kind of wheels on stock body but hope this helps others. Learned a ton about fitment over this process, it was a huge headache, but I love the result and hope others enjoy it as well.
Specs:
Wheels: Aodhan AH02 (white face, polished lip), 18 x 9.5, +30 offset
Tires: Nankang Ns-II, 215/40/18
Suspension: BC racing coilovers (maybe 3" drop?)
Camber: -4 deg front, -6.8 rear (absolutely not necessary to fit these, BC camber plates are near maxed, have camber bolts for fine adjustment, rear SPC LCA is not maxed)
See more pics and fitment details here:
https://www.fitmentindustries.com/wh...cing-coilovers
livingasleep is offline   Reply With Quote
Old 08-07-2019, 10:48 PM   #84
indlinx
Drives: 2018 BRZ Sportech RS
XXR 550 18X8.75 +36 wheels fit
indlinx is offline   Reply With Quote
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 08:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 08:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 08:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 05:15 PM
