View Poll Results: How should the 'inner' of this hood be designed?
Bring fresh air to the air box area. 37 44.58%
Leave it to where it just drops up right above the center of the motor. 9 10.84%
Vent it to the left and right side of the engine bay to cool the motor. 37 44.58%
Voters: 83. You may not vote on this poll
Old 08-09-2012, 04:41 PM   #71
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
Originally Posted by Rampage View Post
They could solve that problem by making bolt on under panels that routed the air to different areas. Example: No panel dumps the air into the engine bay right in front of the AP Turbo air filter location. Bolt on under panel #1 routes the air to the area of the stock intake box. Under panel #2 routes the air to a location to the right or left of the engine bay where it could tie into a side mounted air intake. Options are good.
Something like this?
Symbiont is offline   Reply With Quote
Old 08-09-2012, 05:07 PM   #72
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Well I was thinking more of a flat ducting that directed air from the scoop to a particular area. Two or three could be made and you would purchase and install the one that works best for our application. The photo you provided looks like a complete hood liner that you would then trim to direct the air where you want it. Correct? That would work but would be heavier than smaller, more specialized, panels.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 08-09-2012, 08:23 PM   #73
Juan@aePerformance
Juan@aePerformance's Avatar
Drives: Raven Scion FRS
just make sure its lighter than stock
Juan@aePerformance is offline   Reply With Quote
The Following 2 Users Say Thank You to Juan@aePerformance For This Useful Post:
Brimford (08-24-2012), Entropy (08-10-2012)
Old 08-10-2012, 02:07 AM   #74
Entropy
Oversteer > Understeer
Entropy's Avatar
Drives: GT86
+1
Entropy is offline   Reply With Quote
Old 08-10-2012, 01:41 PM   #75
Symbiont
Tall guys fit, too.
Symbiont's Avatar
I have been assured that it should be at least a tiny bit lighter than stock. And there's always the CF option they're talking about projected for after SEMA...
Old 08-21-2012, 11:16 AM   #76
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Has anything come of this hood? I would love to see a finalized/painted picture
Old 08-21-2012, 12:14 PM   #77
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
This what I somehow pictured, however it interferes with the car's flowing lines and thereby gives it a dated appearence. On the other hand, such a scoop is a Subaru marker. I'll hold out for a twin gill vent design.
Wolfking is offline   Reply With Quote
Old 08-24-2012, 12:39 AM   #78
Dragonist
Dragonist's Avatar
Drives: 83 cutlass 68 olds 350
I would buy if the price, is right...
Dragonist is offline   Reply With Quote
Old 08-24-2012, 12:58 AM   #79
Symbiont
Tall guys fit, too.
Symbiont's Avatar
The hood is sitting in my garage, currently. Funds are extremely tight right now and I can't afford to have the pearlescent paint blended. The paint job will cost around 600-700, plus the Optiguard and clear bra afterwards.
When I finally get it done, I'll post pics. The hood design came out great, though.
Old 08-24-2012, 01:07 AM   #80
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
I wonder what the Tunnel specs went down to? .33 I would guess looks like the old FC Rotary hoods.
Spartan65 is offline   Reply With Quote
Old 08-24-2012, 02:42 AM   #81
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
This hood is on ebay already.
JoeBoxer is offline   Reply With Quote
Old 08-24-2012, 10:35 AM   #82
djdnz
1337
Drives: 2013 BRZ WRB S/C
The stock hood is aluminum, its not like you really need to save much weight there. You'll get better results elsewhere.
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
raz0rbladez909 (08-24-2012)
Old 08-24-2012, 02:56 PM   #83
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Dammit, my car is on eBay.
YOU CAN NO HAZ.
Old 08-24-2012, 03:21 PM   #84
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
If it's made of fiberglass I think this hood might be heavier than stock. The stock hood is aluminum and already lighter than Subaru's usual aluminum hoods. As it is, wet carbon hoods for the WRX/STI are only a couple pounds lighter than stock. Considering how lighter the BRZ/FR-S hood is, I think wet carbon might be needed to match the stock weight, and dry carbon needed to see any real weight reduction.
I'd want to see some real weights before ordering a replacement hood.
Anyone making/willing to make an 86 emblem for the hood? Coultergeist Cosmetic Modification (Interior/Exterior/Lighting) 28 04-18-2014 12:41 AM
Hood strut/prop peenut1086 Cosmetic Modification (Interior/Exterior/Lighting) 0 07-25-2012 11:35 PM
vented hood? 75 carrera Cosmetic Modification (Interior/Exterior/Lighting) 2 07-02-2012 09:57 PM
Carbon Fiber Hood/Trunk lunchbox BRZ First-Gen (2012+) — General Topics 64 01-06-2012 11:03 AM
What you want under the hood of a higher performance OEM variant of the AS1? MrVito BRZ First-Gen (2012+) — General Topics 26 12-26-2011 11:07 PM
