Old 10-19-2018, 11:15 AM   #71
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by CK View Post
Immo could be done by Techstream and tactrix cable. For those turn-key car without the immo setting the engine wouldn't start after changing the dash. Mileage couldn't be changed using tactrix.
I have just ordered the eeprom reader and hopefully will reach next week.
So even with a Key car. If I buy the techstream I can program the Immo system/new cluster at home?
DustinS is offline   Reply With Quote
Old 10-19-2018, 03:37 PM   #72
geraldjust
Drives: MR2, Sliver BRZ
Well seems that techstream has the ability to do so. To bind a cluster to the BCM and ECU.
Are you using the MRS colins adapter for your swap?
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 10-19-2018, 03:40 PM   #73
DustinS
DustinS's Avatar
I was under the impression I would need to get security access, but would be delighted if that wasn't the case.
and Yes I am
Old 10-19-2018, 07:16 PM   #74
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
How hard would this be?. Have steps to complete this?
el-guapin is offline   Reply With Quote
Old 10-20-2018, 02:12 AM   #75
geraldjust
Well according to CK its easy though techstream. But seems he said ANY 2017+ cluster can be binded to a older car as the new clusters are binded at all.
I have never used a tactrix cable. Or not sure what version of techstream he had.
@DustinS i ask because im not sure if it binds with the only and the BCM authenticates with the ECU. and since its going though a gateway if it would also pass on the binding data to the Original ECU assuming you wired your car to the stock Starter relay to turn your engine over..
Old 10-26-2018, 06:13 AM   #76
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
just curious where did u get the 2017 wiring diagram,
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 10-26-2018, 04:24 PM   #77
Dawan
Le Ingenieur
Dawan's Avatar
Drives: 2015 Subaru BRZ Aozora
Hey I am planning on doing this retrofit. How did you guys get the odometer to match the reading of the old cluster? I would prefer to figure this out before the car is put into storage. Mind that I have a push button car.
Dawan is offline   Reply With Quote
Old 10-28-2018, 09:29 PM   #78
geraldjust
Wel the Usual places were to get the 2017+ wiring diagram. Do you need it?
Old 10-28-2018, 09:34 PM   #79
geraldjust
Well since you got a push start car you should be plug in play mostly. Well the way it's possible is though reading the EEPROM chip directly from the board. then changing it based into what your old cluster odo. I would offer it as a service if anyone just not sure if people are interested.
Old 10-28-2018, 10:51 PM   #80
Dawan
Le Ingenieur
Dawan's Avatar
It’s just really expensive to ship a cluster across the border. I’m in Toronto and it seems like you are in SoCal. I however would be interested in the joystick you seem to be working on.
Old 10-29-2018, 11:56 PM   #81
1GiantTurtle
Space for Rent
i wouldn't mind having it
Instagram: 86turtle
Instagram: 86turtle
Old 10-30-2018, 01:12 AM   #82
geraldjust
OH! ok cool. Well if your crafty with electronics i could send you a corrected EEPROM file.
For the joystick are you thinking of replacing the middle button. Or placing it were ever you see fit?
@1GiantTurtle PM'ed
Old 10-30-2018, 06:00 AM   #83
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
@geraldjust
Hi mate, I am now still searching tS JDM cluster MY'17 (I get the MY'13 one and I paired with no issue as it was new from Japanparts.), can you give me directions about wiring? (colours from car cluster main harness), which one in PIN 1 and so on, thanks mate.
I know that in US is sold this item but I need only KMS range and not MPH.
Trap63 is offline   Reply With Quote
Old 10-30-2018, 10:34 AM   #84
Dawan
Le Ingenieur
Dawan's Avatar
@1GiantTurtle PM'ed
Middle button seems to be the most natural spot for it.
2017 Limited Gauge Cluster halleffect Electronics | Audio | NAV | Infotainment 26 10-22-2020 07:32 PM
2017 GR edition cluster mod vagthomas Cosmetic Modification (Interior/Exterior/Lighting) 63 06-29-2020 04:41 PM
Help! Is there anyway to change the 2017 cluster start up image? slashlee DIY (Do-It-Yourself) Guides 2 11-17-2018 05:36 PM
2017 Limited Gauge Cluster halleffect Cosmetic Modification (Interior/Exterior/Lighting) 0 01-16-2017 03:55 AM
2017 gauge cluster Drakiv Cosmetic Modification (Interior/Exterior/Lighting) 2 11-14-2016 11:32 PM
