#71 | |
Sarcastic SOB
#72 | |||||||
I'm a little surprised you can visibly see the difference in camber with your wheel specs, it's about a 1/4" difference side to side at the top of the tire. Quote:
Make sure the car is on a really flat surface, both left to right and front to back. Quote:
How much do you know about the previous history of the car? Any accident repairs at all? If the subframe is shifted, it could cause more poke on one side even without the camber difference. He's saying that the camber on a typical car from a ~1" drop doesn't really require any correction. If you want to keep the balance closer to stock, or want closer cross camber, then you'll need LCA's to correct it.
| The Following User Says Thank You to wparsons For This Useful Post: | Norinradd (11-07-2016) |
#73 | |
not playing cards
I am reasonably certain that something on your suspension or your subframe is bent. Not shifted, bent. A shift in the subframe would show up in both wheels. If we were to spend some quality time discussing the topic in general, you would benefit greatly from understanding the whole thing. Your improved understanding and correct use of terminology would then enable you to figure out with reasonable certainty if, and how the suspension was damaged.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | wparsons (11-07-2016) |
#74 |
I'd be willing to bet that the problem side is actually the side with -0.9*, not the side with -2.5. With a 1" drop I'm at -2.5*R and -2.6*L (with me in the driver's seat). Even with 1/4" less drop, it should be closer to -2.5* than 0.9*.
| The Following 2 Users Say Thank You to wparsons For This Useful Post: | strat61caster (11-07-2016), Ultramaroon (11-07-2016) |
#75 |
Drives: 2013 frs
Took the car to the only good alignment man i know in lowermainland here. Dialed in the rear to -1.7 and -2.0. Guys a wizard. Found some wiggle room within the bolts.
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
#76 |
That's an understatement, if he can consistently find 0.8/0.5 degrees of camber adjustment off of 'wiggle room' on an 86 he'd be a rich man.
People would legit fly him out across the continent to have him align the car if that's the case. Glad to hear your car is all sorted now, wish we could know how it was off so badly but some mysteries remain unsolved.
| The Following 3 Users Say Thank You to strat61caster For This Useful Post: |
#77 | |
not playing cards
Anyhow, glad it's worked out.
#78 | |
Drives: 2013 frs
I think the fountain tire that first did it must have made some mistakes. The guy today who i wanted to bring it to saturday. His initial reading i think was 2.2 and 1.4. Somewhere round there. Not as off as the fountain tire job at 2.6 and .9. So no lcas. Yay. And he says i have more than enough room for degree or two in the fromt. Anyone familiar with grinding the front spring perches down? as i noticed they are the closest thing to the tire, not the spring itself. Have people done that? Any feedback? Sent from my iPhone using Tapatalk
#79 |
Drives: 2013 frs
Anybody know a good video or article explaining these macpherson struts and double wishbones
#80 |
Don't, there's a lip on the edge to keep the spring seated properly. If you want more clearance there buy coilovers.
#81 | |
Drives: 2013 frs
Nah inwas just wondering. I understand a spring seat. Haha. Just theres room there to be grinded out. Btw what is the whole 16mm vs 14mm thing. 16mm whitelines allow for 1.5 degree like they advertise. Or do you need 14mm to get that much?! 14mm bolt in a 16mm hole sounds retarded to me. Just a show car with ridiculous camber Sent from my iPhone using Tapatalk
| This is how camber affects toe in front. Also RCE camber plate info. | Pat | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 05-04-2016 10:08 PM |
| Basic Noob Questions - Camber bolts/alignment/etc | Rifle | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 10-28-2015 01:59 PM |
| *FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 01:10 PM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
