Old 12-30-2012, 03:37 AM   #71
whataboutbob
AutoX-10/10ths every run
Thanks to the OP for this post. I referred to it more than once this weekend while I was installing my RaceCompEngineering Yellows and a bunch of Whiteline stuff.
One thing I'd add is that the OEM springs don't have a huge amount of preload. I was able to remove them by myself, and the top had barely popped off once I spun the nut off. The RaceCompEngineering Yellows are 20mm shorter (i think) and I was able to mount them and start the nut on the shaft by hand easily.
Build thread:Here
Old 12-30-2012, 08:00 AM   #72
Bluecille
Drives: Scion FR-S Ultramarine
What a deal
Originally Posted by DarrenDriven View Post
mechaghost, just drive down to Portland and I'll do it for ya. Just bring me a case of microbrew.
What a deal. I'd bring one for after we finished and one for helping. To bad I live on the east coast. Where are the kind folks over here?
Bluecille is offline   Reply With Quote
Old 12-30-2012, 02:15 PM   #73
Dezoris
Dezoris's Avatar
Can you please re-do this DIY and add some explosions and nudity?
Good job.
The Following User Says Thank You to Dezoris For This Useful Post:
WolfSongX (05-08-2013)
Old 01-11-2013, 03:54 PM   #74
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
so, i have my springs compressed and im trying to take off the 17mm nut holding the top hat on the strut. Its just spinning the whole assembly on the inside. what should i do?
nevermind.. i didnt read through everything. durr.
Kuzuri is offline   Reply With Quote
The Following User Says Thank You to Kuzuri For This Useful Post:
peachch (11-08-2013)
Old 01-21-2013, 06:37 PM   #75
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Section Two: Removing and Replacing the Front Strut
22: Here is my shadetree system for removing a spring safely from a strut. The spring is under pressure and if you just unbolt the top then it will likely shoot off. With a wheel pinning the strut against an immoveable object, and a 2nd person using their foot to push against the wheel, you don't have to worry about any violent action. Additionally, I use an additional piece of plywood over the spring
that I stand on just in case it wants to move up. (see plywood being held at top of photo) These springs did not have much potential force and unbolting the top bolt with a deep 14mm socket was very anticlimactic. This method ONLY works with an air impact wrench.
I'm getting prepared to change out my springs. I plan on doing the spring compressors and pass through ratchet to remove the top hat.
I didn't have a pass through ratchet so while in Lowe's today I bought one, along with extension and 14mm socket based upon this information. For giggles when I got home I popped the rubber boot on top of the front strut and tried the setup. 14mm didn't fit. Need a 17mm socket for the top nut.
FRSFirestorm is offline   Reply With Quote
Old 01-21-2013, 06:43 PM   #76
FRSFirestorm
Red is Fastest
Originally Posted by Phaedrus29 View Post
My top nuts now seem to be at least 41 ft-lbs although I think it's possible they are over-torqued from my impact wrenching.
Good info. I was wondering how the heck I was going to torque the nut.
Old 01-21-2013, 06:46 PM   #77
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
14mm for the rear, 17mm for the front.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
FRSFirestorm (01-21-2013)
Old 01-21-2013, 06:50 PM   #78
FRSFirestorm
Red is Fastest
Ah, that makes sense. Thank you sir!
Old 01-22-2013, 03:54 AM   #79
Mo707
Mo707's Avatar
Thanks for this DIY!
Mo707 is offline   Reply With Quote
Old 01-22-2013, 01:44 PM   #80
wparsons
wparsons's Avatar
I didn't read the whole thread, but there's another "easy" way to get the top mount off of any macpherson strut vehicle. Just loosen the top strut nut off with the weight of the car on the wheels and totally remove that nut, THEN follow the rest of the steps. With the weight of the car on the wheels the strut won't budge, but as you jack it up the spring will decompress and will be easy to remove.
Doesn't help with older hondas or the rears here though
flickr
Old 01-22-2013, 01:51 PM   #81
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
That can be dangerous btw. I have seen springs shoot off using that method. The rates on these cars probably aren't high enough for that but it's definitely not the most controlled method of spring removal.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-26-2013, 11:03 AM   #82
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
@DarrenDriven
I didn't have to remove the top abs clip. It has a latch that allows the ABS line to come free.
On the bottom clip, only the top and bottom had to be squeezed. Just pushed a little with my flat tip screwdriver.
Since there's more than one way to skin a cat:
I also removed the rear sway bar end links because it made for an easier solo install.
Using a jack under the rear lateral link was helpful in lining everything up.
ZC6BRZ is offline   Reply With Quote
Old 01-26-2013, 11:18 AM   #83
wWaldo
Drives: Asphalt Frs
Im guessing if you bought coils overs all you need to do is just swap?
wWaldo is offline   Reply With Quote
Old 01-26-2013, 11:22 AM   #84
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Depends on the coilover. Some use stock strut tops. Some you need to adjust preload.
But for the most part, yes.
Replacing the Scion FR-S seats bloomy116 Scion FR-S / Toyota 86 GT86 General Forum 36 11-09-2012 01:41 PM
Installing TRD Parts / Locating a good shop Re~Mix Engine, Exhaust, Transmission 9 06-12-2012 01:05 PM
T1R Coil-over suspension AJ PwR Brakes, Suspension, Chassis 33 05-29-2012 11:07 PM
Handling: Camber Attainable with Struts. Your Experiences? skeeler Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-09-2011 05:07 PM
