Old 03-15-2011, 08:14 PM   #71
Giccin
Giccin's Avatar
Originally Posted by aliphian View Post
I played this game for about 2 hours after I bought and I realized that I suck at it.
Its ok. I'm bad at racing games too.
Old 03-15-2011, 08:36 PM   #72
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
It's all good. No one is good at first. When you get used to it, you'll be fine.
Old 03-15-2011, 08:43 PM   #73
BlueLotus91
Drives: FT-86
First, you're using DFGT to drift, that's the problem. It's almost impossible to drift w DFGT, so use regular controller. Second, take off all the assistant off. Lastly, put comfort hard tires, LSD, custom tranny, custom suspension. That should do it
Yup, I have modified the car with all parts. Adjusted the suspension and LSD. All assists are off. But I still fail in drifting with the wheel.
Check out this video.... there are many players using dfgt to drift in GT5.
Can someone guide me in dfgt? I have tried using controller, and I don't like it. It is easy and don't feel right.
BlueLotus91 is offline   Reply With Quote
Old 03-15-2011, 09:36 PM   #74
ichitaka05
Site Moderator
ichitaka05's Avatar
FYI that vid you used is from LFS not GT5, so that's so different. At least bring right vid next time... like this one
[u2b]5x8eHkFgDKA[/u2b]
For me, I prefer to use DFGT for grip and don't use it for drift.
Not to be harsh, but if you can drift w regular controller then you just need to adjust few suspension setup. That should let you drift w DFGT. If you can't drift w regular controller then, you start from there. Learn how to drift w controller might be better idea first.
Old 03-15-2011, 09:49 PM   #75
BlueLotus91
Drives: FT-86
sorry for the wrong video. I get your point though. I already know how to drift with controller. that's why I don't like it. have you tried the wheel to drift? can you guide me?
Old 03-15-2011, 10:24 PM   #76
BlueLotus91
Drives: FT-86
I found the correct video now....
Old 03-15-2011, 11:03 PM   #77
ichitaka05
Site Moderator
ichitaka05's Avatar
Yeah, if you're using the wheel, it's best to drift w AWD cars. Also you wanna change your setup to braking drift instead of ebraking drift.
I have all the assist off and have FFB to max.
Old 03-15-2011, 11:37 PM   #78
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
Hi, is there any step-by-step guide of drifting? I also found myself really sucks on this (just 5K points at best). It seems that I either counter-steer too much or not enough power, the tail is swinging left to right and eventually off the track. Any help would be appreciated.
BTW, I found that with FT-86 running at CH/CM tires with default setup with custom suspension running at 300-400 hp, it fairly easy to get the tail swing. There is no need for e-brake. (where is that button again?)
The hardest part is to maintain the drift using the controllers. Any hints?
Thanks.
Want.FR-S is offline   Reply With Quote
Old 03-15-2011, 11:49 PM   #79
ichitaka05
Site Moderator
ichitaka05's Avatar
Thanks.
[u2b]H3ryd01UXCM[/u2b]
put the joke on the side, IDK exactly what's the problem... but from the sound of it, in the mid of corner you're putting too much throttle. Corner out, not enough counter steering.
Another way to learn is go to open drift lounge and just go into view mode and see some good drifters drift. How throttle control & brake timing & etc can be seen in view mode.
Old 03-16-2011, 12:15 AM   #80
Want.FR-S
Want.FR-S's Avatar
See if I got the sequence corrected for braking drift:
1. brake into the corner, but not too much
2. turn the steering and brake a little bit to make the rear tires slip
3. once slip, gentlely counter-steer (1/3 to the left using controller?) and press and hold the gas
4. maintain the counter-steer angle and gas level until exiting the corner
does this sound alright?
Old 03-16-2011, 05:08 PM   #81
BlueLotus91
Drives: FT-86
Yeah.... I manage to drift a 350Z with DFGT wheel. Even though it is not as perfect as using a controller. But it was satisfying! I will perfect the drifting skill with DFGT more.
Old 03-16-2011, 08:23 PM   #82
XpLiCiT_CaShh
XpLiCiT_CaShh's Avatar
Drives: Mk2 Escort
Ive changed my setup in the 7 a lil ichitaka, and getting some wickid full throttle - rev limiter bouncing - powerslides outta 4th hahaha.
Maybe il be able to compete at Suzukua and not get in the way haha!
XpLiCiT_CaShh is offline   Reply With Quote
Old 03-16-2011, 09:40 PM   #83
Zaku
-Proud of Brzerhood-
Zaku's Avatar
Drives: '17 BRZ CWP LMT.
I found that it's harder for me to drift my FT with more HP and CH D: I was doing ok with Stock and CM the other day.
Old 03-16-2011, 10:04 PM   #84
ichitaka05
Site Moderator
ichitaka05's Avatar
You gotta adjust setup every time hp goes up. IDK how much HP you have, but if it's over 300hp then you should be putting CM. Also fix the damper setup and lds setup.
truck got hit. time to upgrade... NESW20 Other Vehicles & General Automotive Discussions 20 06-12-2011 02:43 PM
Best drift ever Matador Off-Topic Lounge [WARNING: NO POLITICS] 1 05-11-2010 02:48 PM
Drift car photoshop plz... Lexicon101 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 03-02-2010 04:18 PM
ft-86 drift trueno Scion FR-S / Toyota 86 GT86 General Forum 46 01-21-2010 05:39 AM
Will you drift this car often? Axel Scion FR-S / Toyota 86 GT86 General Forum 47 11-09-2009 06:35 PM
