#8345 | |
Drives: 2014 BRZ (SOLD)
Sent from my SM-G960U using Tapatalk
Supercharged 2014 DGM Limited
The Following User Says Thank You to SpeedWi For This Useful Post: | jflogerzi (05-05-2019) |
#8346 | |
2013 Series 10 FRS #553
#8347 | |
![]() Sent from my SM-G960U using Tapatalk
#8348 |
Getting more whine with the stock intake. I saw this video on YouTube where this guy added a sound tube from the intake through the firewall to amplify the whine. Car was a mustang but still same concept. Gotta admit I was looking forward to a louder wine. What are ppl thoughts on this and using the old firewall opening where the OEM sound tube was?
#8349 | |
Drives: 2013 Subaru BRZ Limited (Black)
#8350 | |
#8351 | |
Drives: 2017 toyota 86
3” filter does Supports the plastic pipe as well though. But the metal pipe adds a lot of whine. More prone to heat soak though. |
#8352 | |
The Following User Says Thank You to ajcarson11 For This Useful Post: | jflogerzi (05-08-2019) |
#8353 | |
But neither are recommended unless E85 or WMI to keep Intake temps down. As the metal pipe heat soaks more then plastic and the 3” filter is basically a hot air intake. Did you switch from metal pipe and Perrin big maf to the plastic pipe and 3” filter? |
#8354 |
Drives: Boosted Toyobaru
Hi,
Is anyone here able to tell me if an aftermarket mid-pipe (cat-less or high-flow) will make a difference in terms of gains? (Im currently 210 supercharged with exhaust) My header + over pipe are cat-less and my cat-back is high flow. I kept the mid pipe to stay somewhat quiet but now Im curious to know if replacing the mid-pipe for a high-flow or even straight piping will benefit at all. |
#8355 | |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | JDM_Import (05-11-2019) |
#8356 | |
The Following User Says Thank You to jflogerzi For This Useful Post: | JDM_Import (05-11-2019) |
#8357 |
Drives: 2013 FR-S Argento
The Following User Says Thank You to bfrank1972 For This Useful Post: | JDM_Import (05-11-2019) |
#8358 | |
The Following User Says Thank You to jflogerzi For This Useful Post: | bfrank1972 (05-10-2019) |
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
