Old 09-30-2014, 04:33 PM   #813
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by post_break View Post
Hope the baby and mom are doing good!
I decided to say screw it, I took the harness out and now evap is hooked up as if stock. The latest tune you gave me does not go to ready, but I think the tune before that will work just fine. I will test it and report the all clear. It just kind of sucks because I paid for the work so I could log my wideband in ecutek. But if I have to rip that thing out every time I need to pass inspection it just isn't worth it.
Sent an update for the P1449 code.
Questions for you.
1. Why not use the rear O2 sensor voltage as the input for the wideband O2? This way you can leave the evap all connected (working properly) and still have your wideband working as you want. This eliminates the need to worry about the evap all together. If you go FlexFuel, we can add the input wire to the MAF input voltage and still not worry about the evap.
Just a thought.
Cheers,
William Knose
Old 09-30-2014, 04:55 PM   #814
8686
8686's Avatar
Drives: 86
Originally Posted by 8686 View Post
@DeliciousTuning
sent you an email regarding a review of data log for my tune. I hope to hear from you soon.
@DeliciousTuning
Dear Bill did you have a chance to look at my log.
thank you
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 09-30-2014, 05:39 PM   #815
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Questions for you.
Just a thought.
Cheers,
William Knose
Right now I have my flex fuel kit connected to the Rear O2 sensor input on the front of the engine. Just waiting for you to release flex fuel tune pricing so I can upgrade.
I will try the latest tune you sent me with my Evap hooked up as if it were bone stock. If I need to log with my wideband, I can just use my harness and in 10 minutes get it plugged in. Clear any CEL's, and be good to go.
I hardly log, and if plugging in my harness causes is a CEL for evap, I can live with that. I'll just leave it unplugged and harness in the garage. Bone stock evap for daily driving, and then clear the CEL if I need to log with any evap codes that go around it. This way I can pass inspection.
post_break is offline   Reply With Quote
Old 09-30-2014, 05:56 PM   #816
DeliciousTuning
@DeliciousTuning
thank you
Thank you for asking. I have responded to your email.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
8686 (09-30-2014)
Old 09-30-2014, 05:58 PM   #817
DeliciousTuning
Will let you know on the FlexFuel.
Thanks for the information, if you need something else, let me know.
Old 09-30-2014, 09:34 PM   #818
NightRaid
Drives: GT86
What do I do if I have an aftermarket steering wheel with the cruise control removed? Is there another way to swap maps on the fly or am I screwed.
NightRaid is offline   Reply With Quote
Old 09-30-2014, 09:45 PM   #819
protpibe
protpibe's Avatar
European gt86s have cruise as an option so tuners set up the defrost switch (iirc) to change maps
Old 10-01-2014, 08:12 PM   #820
DeliciousTuning
Couple options.
1. Defrost/Defog Button
2. Traction Control Button
Cheers,
William Knose
Old 10-04-2014, 03:58 AM   #821
FRS Justin
Drives: 2013 Asphalt FRS
2 more records for Delicious Tuning and PPE Header
[ame]http://youtu.be/CCFOM4fuWSM[/ame]
Fastest Frs N/A and 1st N/A to break 100mph in the 1/4 mi
FRS Justin is offline   Reply With Quote
The Following 2 Users Say Thank You to FRS Justin For This Useful Post:
DeliciousTuning (10-07-2014), raven1231 (10-04-2014)
Old 10-04-2014, 05:26 AM   #822
troek
troek's Avatar
Drives: 2012 Toyota 86
Thats pretty quick
The Following User Says Thank You to troek For This Useful Post:
FRS Justin (10-04-2014)
Old 10-04-2014, 04:18 PM   #823
M23
Drives: 86
Wow, very nice and inspiring.
Reminds me when Honda dohc cars first started breaking 13s in the mid 90s (in a good way)...then 12s, then 11s, then 10s, then 9s and beyond
It's only a matter of time and I can't wait to see even faster NA times..maybe when NA cams, springs, high comp pistons and other stuff finally become available
I think I read a past post that @DeliciousTuning tuned some white NA race car that had custom cams in it (but hadn't publicly released the dyno results for it yet). Maybe Delicious should offer that particular NA cams to the public/customers with their matching tune as some sort of NA package. I'm sure many would bite
M23 is offline   Reply With Quote
The Following 2 Users Say Thank You to M23 For This Useful Post:
DeliciousTuning (10-09-2014), FRS Justin (10-04-2014)
Old 10-04-2014, 04:31 PM   #824
Calum
That Guy
Drives: 2013 asphalt FRS MT
Great time. What was the 60 ft? Any other mods aside from the header and tune?
The Following User Says Thank You to Calum For This Useful Post:
Old 10-04-2014, 04:40 PM   #825
raven1231
Yes! Love it
This could keep up with many stock turbo cars
Old 10-04-2014, 05:16 PM   #826
FRS Justin
1.8 60ft is the best usually a 1.9 with hoozier street slicks
All engine mods are:
1: k/n panel filter
2: PPE header and over pipe
3: invidia exhaust and front pipe
4: E85 Stage 2 tune from Delicious Tuning
5: ACT Clutch and streetlite flywheel
No lightweight pulleys
no cold air intake
no crawford blocks
I will shoot you straight I have tried other headers other tuners but nothing comes close to this setup, I live in San Antonio and made over 200 wheel horsepower on a dynapac dyno on a day that was 100 degrees and 50 to 60 percent humidity.
Last night I ran multiple 13.61's and 100mph passes, its a really consistent setup. It will go faster based on i was running in a 7 to 10 mph head wind. The flags at the track were blowing straight torwards me lol
Are 12's possible N/A I dont know but nobody thought mid 13's or breaking 100 mph in the 1/4 were either at one time lol
I'm Working on something right now that might get me down a few more tenths but its going to take a little time..... lol
peace and thanks for the props!!!!
The Following 9 Users Say Thank You to FRS Justin For This Useful Post:
acro (10-07-2014), Calum (10-04-2014), CarzCarzCarz (10-06-2014), CK_Bladesmith (10-04-2014), DeliciousTuning (10-07-2014), Lawnik (10-05-2014), Pseud0logik (10-05-2014), raven1231 (10-04-2014), texasbound972 (10-04-2014)
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 04:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 06:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 02:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 03:33 PM
