#813 | |
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#814 |
Drives: Red
#815 |
yes
#816 |
BoostedBRZ
Drives: Turbo BRZ
http://datazap.me/u/pgranberg11/1128...zoom=5465-6255
hey everyone! the weather is changing here in chicago so I decided to switch my fueling to 93 for easier cold startups. I'm running flex fuel right now so this run was with e25 and kraftwerks c38 standard boost pulley. Can somebody just make sure and double check everything is ok? someone did tell me that the short term fuel trim is a little unstable and should be cleaned up a bit. and during at times of idle i do see my AFR wander all the way to 17ish. let me know what you guys think. i appreciate any input! Edit: there are two pulls in the chart, one towards the middle and another towards the end |
#817 |
Drives: 2013 FRS- Hot Lava
Some help necessary here. Setup:
Open Flash OFT300 package Vortech supercharger (standard pulley) Open Flash Header Stock catback Vortech Maxflow BOV Logs: http://datazap.me/u/sirsol66hotmailc...data=1-2-10-11 Car is showing very very high fuel trims (25+) at idle and low RPM areas. Car is running completely fine but the trims are not settling. No knock at WOT pulls. Exhaust has been leak checked and no issues. I will leak check the intake side this week. One thing I noted is that the BOV is completely open at idle and moving A LOT of air. I never ran the normal vortech bypass valve so I am not sure how the maxflow compares with it. Can this be contributing to the high fuel trims? I would think no since the MAF is quite a ways after the BOV but still curious. |
#818 |
EX-86 Supercharged God
Drives: '16 Series.HyperBlue BRZ
delete
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ Last edited by Rifle; 12-10-2015 at 02:52 PM. |
#819 | |
Drives: UK GT86
.: Stealth 86 :.
#820 |
Okay, so there's nothing weird there. Which tells me the injector is probably fine.. So spun rod bearing it is. Fml.
295WHP/220TQ |
#821 |
Drives: FR-S Whiteout
They all have huge amount of fuel trims at idle and low MAF. Is this typical for boosted setups, or do they need to modify the MAF scale?
Intent > Content
cowardice is the mother of cruelty. |
#822 |
Drives: UK GT86
All cold idle fuel trims go all over the place it seems. It's not unusual, it's why it's best to ignore any fuel trims below 50C coolant temp.
.: Stealth 86 :.
#823 |
Drives: 2013 Scion FRS
Running fullblown's turbo kit with gt2871r at 8psi, stock injectors, 3 bar map sensor. Im getting some AFR fluctuations when cruising, possibly because of erratic maf voltage readings. Here are some logs. Wondering if everything looks normal.
Cruise Control on: http://datazap.me/u/rasta42/ft86crui...=6-10-11-30-42 Operating temp Idle http://datazap.me/u/rasta42/ft86idle...ata=6-10-11-30 2nd gear pull http://datazap.me/u/rasta42/ft862ndg...ata=6-10-11-30 |
#824 |
I started to get this knock at .60~.80 loads seemingly out of nowhere. NOt sure what to make of it. I tried tightening my header to over pipe connection and it seemed to lessen for a short time. Is it just the exhaust fasteners loosening because of the large difference in the cold winter ambient temps to the high exhaust temps heating up the exhaust rapidly? Or, should I bee looking at the cam and ignition timing for a fix?
Log:http://datazap.me/u/solidone/af1z-ca...6313-3928-1628 Edit: I think it might be just a tank of bad winter blend gas. Just fueled up a fresh tank of gas and the knock seems to have lessened. Will update post with another log with this new tank of gas tomorrow. edit2: Lower amount of flkc this morning, but still there. http://datazap.me/u/solidone/af1z-ca...zoom=2182-2790 edit3: Logging KC and Cams with some aggressive throttle and pulls to redline: http://datazap.me/u/solidone/af1z-ca...2107-2164-2078 Probably fuel quality related. Exhaust vibration not ruled out 100%.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 12-26-2015 at 06:13 PM. |
#825 |
Drives: Toyota 86
Hi,
Merry Christmas! I've logged 3rd pull on Christmas eve .http://datazap.me/u/makinenkr/201512...-13&zoom=3-107 98 RON petrol, HKS catted EL header, overpipe, Exedy stage 1 clutch + flywheel kit, DSS AL shaft. I'm curious about whether I have to open loop MAF scaling or not. The MAF curve after applying OL scaling is somewhat not smooth. For the ignition timing, could I get more after 6800rpm by advancing some? Based on Virtual Dyno, it hits 204hp . Just for fun.Thanks. |
#826 | |
But that pull doesn't look like a good candidate to convert to dynograph with a lot of little dips and spikes in the rpm. I like to use 2 smoothing on virtual dyno. http://datazap.me/u/makinenkr/201512...66-92-97-86-73 I would suggest doing many back to back pulls on a nice and flat/level surface to get good/consistent data for conversion. At least 3-4 pulls. I do about 10 in a row then a 3to4to5 gear at the end for good measure and good data to see if you can add or pull some timing for better power or knock resistance
Intent > Content
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
