Old 06-11-2018, 02:32 PM   #813
KroozX
Drives: Peugeot
I've already built pretty the same setup. The result was pretty interesting:
[ame]https://www.youtube.com/watch?v=f9w4qTTLKVo[/ame]
KroozX is offline   Reply With Quote
The Following User Says Thank You to KroozX For This Useful Post:
Matt@Cosworth (06-11-2018)
Old 06-11-2018, 03:05 PM   #814
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
the figures are a little difficult to read off the meter and gauge
what does this setup reach / achieve in terms of pressure and mass airflow?
Matt@Cosworth is offline   Reply With Quote
Old 06-11-2018, 04:02 PM   #815
KroozX
Drives: Peugeot
It makes about 0,5 Bar at 120-130kg/hr airflow. The most interesting thing is that the power used for this is only about 3-3,5KW. I'm pretty sure this compression wheel is not the most efficient one, so prboably there is a way to improve the setup even further.
Old 06-11-2018, 05:02 PM   #816
churchx
churchx's Avatar
Drives: 2014 GT86
I wonder which type of chargers may fit better to pair with electric motors, centrifugal or positive displacement ones ..
Thinking that there might be more gains with centrifugal, as electric, non mechanically linked to engine, may have less problems spinning fast at low engine rpms, and i guess having turbine might simplify not designing in bypass for when ESC is not on, or there might be some pros to positive displacement one + ESC too?
Old 06-11-2018, 05:33 PM   #817
al3k
Drives: Audi A4 B7 2.0T Quattro
Can you share how you mounted the compressor wheel to the motor and how you mounted the motor to compressor housing, sealing methods?
Which motor (kv) and voltage to motor did you test in video?
al3k is offline   Reply With Quote
Old 06-12-2018, 05:59 AM   #818
KroozX
Drives: Peugeot
The motor is tp4070cm 2200kv, powered from 12S LiPo with custom developed motor controller. I turned the wheel on the lathe to the shaft diameter and fixed it with a screw. No extra sealing except of the turbo housing ones, which is already there.
Old 06-12-2018, 10:08 AM   #819
al3k
nice! you should turn on sound in your video, I couldnt hear it spool.
"It makes about 0,5 Bar at 120-130kg/hr airflow."
Are you sure you are measuring this the correct way? 120-130kg/hr doesnt make sense if you maxet out your motor or did you mean 120-130g/s?
Old 06-12-2018, 12:24 PM   #820
Matt@Cosworth
a PD blower will take a lot more shaft power to turn I'm afraid
centrifugal are the only viable option at the motor power levels we're talking about
The Following User Says Thank You to Matt@Cosworth For This Useful Post:
churchx (06-12-2018)
Old 06-12-2018, 05:16 PM   #821
KroozX
Drives: Peugeot
Sorry for no sound, there was something wrong with my camera. I definitely should make the one with the sound.
According to the datasheet of the used MAF sensor, it gives 2,8V output voltage on about 120-130kg/hr airflow. The gas flow calculator says it corresponds to ~100m3/hr or ~1500-1600 l/min. If I'm correct it also corresponds to about 1500rpm of 2,0 liter engine.
It probably could look like the pipes are simply opened, but it's not the case. I made a kind of throttle valve in the middle section of the piping:
Old 06-13-2018, 12:19 PM   #822
Matt@Cosworth
Something I meant to ask when I 1st saw your video was why aren't you measuring the air flow on the compressor intake?
as presumably your dummy manifold has a restrictor of some sort in it ( you mention a throttle above) so it can generate some boost
but if you're measuring downstream of that restrictor then there will be pumping losses so you are being a bit unfair to it I feel
also looking at your MAF datasheet 2.8V = about 180kg/hr so 50 g/sec if its a Pierberg unit or 70 Kg/ hr if its a Bosch unit?
Old 06-13-2018, 01:36 PM   #823
KroozX
Drives: Peugeot
No, I'm measuring on the output of the compressor, after "manifold" and throttle
It's a Bosch sensor. I made a screenshot from the video (in attached fotos), it shows about 2,94V top flow. Looking more precisely to the diagramm from datasheet (attached foto) there is about 110-115kg/hr airflow. Which is a bit less, than I assumed before, thanks for the correction. So such airflow is at approx 1400rpm of the 2,0L engine.
Anyway I was really surprised achieving even this result after looking the videos of other ESCs.
Which pumping losses do you actually mean? I also thought about moving the MAF sensor to the intake of the ESC, but not really sure if it could be any better.
Lonewolf (06-14-2018)
Old 06-13-2018, 03:51 PM   #824
al3k
Would be interesting to see if putting the maf to the inlet changes the results.
Did you measure the inducer and exducer of the compressor wheel? This is a T04E right?
Old 06-13-2018, 04:26 PM   #825
KroozX
Drives: Peugeot
The compressor wheel is 48/75mm. There is also a pretty big gap between wheel and housing, the overall precision and matching isn't that good.
Old 06-14-2018, 05:21 PM   #826
Matt@Cosworth
Ideally I'd say you want as large a compressor that your motor can spin at a reasonable speed to stand a chance of the greatest amount of mass flow
there's obviously some trade off here as depending on the compressor map / efficiency a 50K rpm compressor that delivers 200 g/sec
may need a lot more shaft power than is available than a 70K rpm compressor that also delivers 200g/sec
however shaft power is something that the turbo manufacturers don't tend to release
probably because its not easy to measure and most folks don't care anyway
hairdyerperformance, only pulls hard one gear
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
DUP THREAD MODZ PLZ DELETE KTHX SloS14 Forced Induction 0 07-09-2013 05:41 PM
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 02:47 PM
Electric 86 frosty86 Scion FR-S / Toyota 86 GT86 General Forum 8 11-10-2012 02:16 PM
WRX Electric turbo Neilus Engine, Exhaust, Transmission 42 05-03-2012 09:20 PM
