Old 06-04-2018, 03:51 PM   #799
NJUL9925
Drives: 2013 FRS
Hey guys I have a V1 and need to do the SC oil change on it. I dont have my manual however and cant find one except for the install manual on the V3 from ft86speedfactory.
It does not offer much help in terms of showing a procedure to doing this oil change safely.
-does anyone have a link where I can download the V1 manual or other reference to use?
also has anyone done it that can give advice on this?
thanks !
NJUL9925 is offline   Reply With Quote
Old 07-07-2018, 02:35 AM   #800
killsafkat
killsafkat's Avatar
Drives: 2013 GT86
Anyone using an aftermarket intake or induction box with their v2 or v3?
killsafkat is offline   Reply With Quote
Old 08-01-2018, 12:09 PM   #801
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
So how is everyone's reliability holding up?
MS, CSCS, TSAC-F, CPT
Old 08-07-2018, 12:31 PM   #802
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Hey, are you thinking on this supercharger? The one I tested once had the HKS kit. It was the basic one and made 240 @wheels. Very very strong result ...
Old 08-12-2018, 06:53 AM   #803
killsafkat
killsafkat's Avatar
Drives: 2013 GT86
Originally Posted by Andew727 View Post
go with a Tial QRJ full recirculating BOV. i have one on my car with a high boost pulley. sounds amazing, looks better, and in my opinion performs better than the bypass valve.
pictures on my IG: andyb727
ill have videos up soon once i fix the crank pulley pin that i bent.
Which spring did you use with ur tial qrj?
Old 08-13-2018, 04:42 AM   #804
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Now on test! I install a new wider restrictor of 41 mms of diameter vs the stock one of 39.
Car gains much more reactivity on medium –low range and from initial logs I see a medium range of +20grs air, a need of +6/7 of fuel in comparison with stock configuration of HKS V2.
It’s mandatory to revise all parameters first of all DI+PI and to better balance engine load.
I think that this is the best mod for upgrade HKS V2 without exceed and no need to change fuel pump and injectors.
Tune suite: Ecutek RaceRom10, 100 RON fuel only.
To cut with laser a new Iron Aisi304 restrictor I paid $10,00 (if someone wants I get the file for laser cutting).
Inviato dal mio SM-G960F utilizzando Tapatalk
Trap63 is offline   Reply With Quote
The Following User Says Thank You to Trap63 For This Useful Post:
Yobiwan (08-13-2018)
Old 08-13-2018, 10:50 AM   #805
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
you can go to 43~44mm on stock MAF sensor & injector .
(max boost is about 11.5)
I use 45.5mm now with stock injector, pump & STI maf sensor.
max boost is about 12~13 depends on IAT & altitude.
good luck !
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
The Following User Says Thank You to Yobiwan For This Useful Post:
Trap63 (08-13-2018)
Old 08-13-2018, 11:03 AM   #806
Trap63
Trap63's Avatar
good luck !
hi mate do you have part no. of sensor? thx
Old 08-13-2018, 11:27 AM   #807
Yobiwan
Yobiwan's Avatar
Here
http://www.ft86club.com/forums/showthread.php?t=106496
Trap63 (08-13-2018)
Old 08-27-2018, 06:04 AM   #808
phlipsyde
Drives: 2013 Whiteout FRS
Hey guys, I have the v3 kit and love it. Two questions for someone seasoned - any idea why I see -11 vacuum at idle instead of 20ish? This is the reading from my OFT. second, how do I attach a Tial QRJ to the HKS manifold? I'm having a tough time finding the base that fits. I emailed Tial but haven't gotten a response. Thank you!
phlipsyde is offline   Reply With Quote
Old 09-05-2018, 02:02 AM   #809
johl
johl's Avatar
Drives: toyota 86
What headers and front pipe is everyone running?
I’m concerned once the standard headers are removed I will experience a terrible rasp in the exhaust. Does anyone have an ACE header and catted front pipe with the hks supercharger?
johl is offline   Reply With Quote
Old 09-05-2018, 03:03 AM   #810
Trap63
Trap63's Avatar
I run on Tomei EL and Tomei overpipe with HKS Spec L Ti.
very low sound and no resonance. Only very high Db level @160Km on highway
johl (09-05-2018)
Old 09-05-2018, 04:37 AM   #811
johl
johl's Avatar
Drives: toyota 86
I was actually just looking at your engine bay. That is exactly what I want to do. It looks almost factory when it is painted black.
I was hoping it was possible to keep the exhaust a little on the quiet side with no annoying rasp or drone so that is good to hear. Thank you
The Following User Says Thank You to johl For This Useful Post:
Trap63 (09-06-2018)
Old 09-14-2018, 09:28 PM   #812
FT86Z
Drift noob
FT86Z's Avatar
Drives: 2015 BRZ Sport-Tech CWP 6MT
Differences between HKS supercharger kits
Hello FT86'ers,
I am shopping for my first supercharger and I have been researching the HKS V3 kit which I believe is the 12001-KT003. On the HKS JP website theres also the PRO 12001-AT009 which says its to be discontinued as per the site, and the GT2 PRO 12001-AT012 kit:
https://www.rhdjapan.com/hks-gt2-sup...t-zn6-zc6.html
Pricing is not too much different between them all and I was just wondering what the main differences are. Also, any reviews or comments regarding the flash editor if I were to get one with it?
Thanks in advance for the info.
FT86Z
藤原とうふ店
FT86Z is offline   Reply With Quote
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 10:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 10:37 AM
