Old 08-17-2017, 12:18 AM   #799
kuangxtc
Drives: 2013 DGM BRZ Limited
Hey guys I've been reading up on various tuning posts and ordered my genuine Tactrix Openport 2.0 and it will arrive tomorrow. So as far as I understand, you can read and save the current rom on your ecu with ECUFLASH but need the definition file in order to be able to edit and flash it.
If I want to open the rom in ROMRAIDER and then edit and save, then flash to the car with ECUFLASH, I need a specific ROMRAIDER definition and a specific ECUFLASH definition?
So when I get my openport 2.0 tomorrow, I will pull the current tuned rom from my car (open source dyno tuned) and find out the calibration ID associated with it.
I believe all that is accurate. Now what I don't understand is in the OP where the Rom compatibility is discussed:
D Series
ZA1JA700D, 900D,A00D,A01D,B00D all compatible with ZA1JB01D
Does this mean that whether I have any of the listed IDs that they will all work with the ZA1JB01D definition? (I have a 2013 US A/T).
Thanks!
kuangxtc is offline   Reply With Quote
Old 08-17-2017, 12:48 AM   #800
freerunner
freerunner's Avatar
Drives: GT86
Originally Posted by Roadcone View Post
What are you guys using to comb thru your logs? i've given up on an alternative logging option appearing so i'm going to just say screw it and deal with it now. Do you have something you dump your data into that makes it more manageable? google sheets seems like a very clunky way to do it.
If you're running Linux, you may take a look at Kst. It would be perfect, if it only had a gauge view or dynamic markers, like datazap.me.
Example picture
freerunner is offline   Reply With Quote
Old 08-17-2017, 01:11 PM   #801
Kodename47
Kodename47's Avatar
Drives: UK GT86
No, it just means that the ECU is compatible with those ROM versions. Go get a B01D file, edit that and flash that onto the ECU. That way you have all the updated changes made by the OEM that we can't see etc.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
kuangxtc (08-17-2017)
Old 08-17-2017, 05:18 PM   #802
kuangxtc
I am having a problem reading my current ROM. I hope I can find some help.
I just received my tactrix and have the 32bitbase file in the correct directory. My car has the B01D calibration ID, so I have the raw definition in brz/2012/2013/2014 folders. ECUFLASH reads the current rom, but it says there are no definition files for the rom. I save it as .bin and try to open in Romraider with the specific romraider definition file and it still says no matching ecu definitions. And there's no Rom Metadata for the read in ECUFLASH.
Is there something I'm overlooking? Thanks!
Old 08-17-2017, 05:55 PM   #803
steve99
post up the rom image you saved and ill look at it. It probably been tuned previously with a calid hacked rom
Id also download the latest 32bitbase and B01D Ecuflash definitons from the github site
the error message your getting saving your rom as .bin is normal ,about the padding. Just click yes to save as bin
also try opening a stock B01D rom that attached to first post in this thread, see if that will open.
If not update your 32bitbase and defs from github
Old 08-27-2017, 01:31 AM   #804
steve99
Added ZA1JK00P 2017 Australian manual new logic rom for udated car with red intake manifold
Old 09-02-2017, 02:47 AM   #805
steve99
Added ZA1JK01I
2017 auto European
Old 09-03-2017, 03:45 PM   #806
Marco kinaa
Drives: Superchared BRZ
Ecuflash Definition file for 2017 BRZ MT Chinese Market ID ZA1JK00N
Hi everyone
can someone help me out with the definition file for 2017 BRZ MT foe the Chinese Market , calibration ID : ZA1JK00N
Attached is the Stock file
appreciate any help
Cheers
Marco kinaa is offline   Reply With Quote
Old 09-05-2017, 01:05 AM   #807
Dazrour
Drives: 2017 gt 86 auto
Added ZA1JK01I
2017 auto European
Hi
I believe this is the rom from my car
Still having trouble with the definition file for this thing, its the old logic but doesnt match any of the old definition files. Attempted reverse engineering the rom using IDA but its a little beyond my current understanding. Anyone know an easier way to identify the tables if they should be similar to a previous rom?
Dazrour is offline   Reply With Quote
Old 09-05-2017, 04:23 AM   #808
steve99
Originally Posted by Dazrour View Post
Hi
Unfortunatly very few people possess both the skills and time to reverse engineer these roms and find the tavles and logging addresses.
Basicly one guy on ghe planet tdd over at romraider, and i think hes swamped and has a real job to do as well.
If your in a hurry your going to have to buy brzedit, ecutek or oft.
Old 09-05-2017, 04:35 AM   #809
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Hi
There will be large chunks of tables with similar data, but at locations offset from earlier roms.
Old 09-05-2017, 12:14 PM   #810
Kodename47
Kodename47's Avatar
Drives: UK GT86
Hi
ScoobyRom might help.
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-06-2017, 06:58 PM   #811
Dazrour
Thanks everyone for the responses in the posts above. It looks like the community could do with a few more hackers 😉
I have a feeling the oft guys dont have a working rom for this id either, I emailed shiv as that would be my preferred option over ecutek.
I'll have a go with ScoobyRom it looks promising and see how far I can get. Hopefully post findings and guidance back to the forum incase anyone else fancies giving it a go on any new roms. Cheers.
Old 09-06-2017, 10:43 PM   #812
Wayno
Wayno's Avatar
More people isn't what you need, it's time (and/or money).
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 09:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 08:27 AM
