Old 08-30-2013, 12:35 PM   #799
Anaxilus
Drives: They have four wheels
Big brake + big wheels = less fun, agile, nimble on the street. More high speed grip and braking for track but less zippy for around town.
Anaxilus is offline   Reply With Quote
The Following User Says Thank You to Anaxilus For This Useful Post:
supra2nv (08-30-2013)
Old 08-30-2013, 12:56 PM   #800
torqdork
torqdork's Avatar
Drives: RV-7
I'm not so sure. If you assume greater weight, yes, but he's running light forged wheels and the TRD BBK may well weigh less than the chunky cast OEM's. OTOH, the tires might be heavier but maybe not. When I was shopping for 225/45-17 performance rubber there was about a 6 lb. difference between the top rated brands with one about the same as the OEM Michelins.
In general I agree, but he has anything but a typical build going on.
torqdork is offline   Reply With Quote
The Following User Says Thank You to torqdork For This Useful Post:
Old 08-30-2013, 01:35 PM   #801
Anaxilus
To know for sure, you have to look at the polar weight. While the TRD thing is cool, they aren't the most optimized parts for saving weight, TRD never is. Bigger/ wider tires also have more friction as well as weight where you don't want it and I find that makes a car feel more sluggish. Same thing for BBK. You can drop weight on the caliper and rotor hat, but a bigger OD puts weight further out where OE had no weight at all. This is why the Essex Sprint kit is so popular versus the Endurance.
In short, a 20lb 16" wheel will feel snappier than a 19" 19lb wheel. static weight wrt rotational mass means very little w/o consideration of overall dimensions and dynamic weight.
Old 08-30-2013, 01:43 PM   #802
supra2nv
supra2nv's Avatar
Drives: 10 Series TRD
Yeah bro my car is definitely lighter
"Electrons act like photons. They are both screwy, but in exactly the same way." Richard Feynman
Wave Particle Duality
supra2nv is offline   Reply With Quote
The Following User Says Thank You to supra2nv For This Useful Post:
torqdork (08-30-2013)
Old 08-30-2013, 01:45 PM   #803
supra2nv
supra2nv's Avatar
Originally Posted by Eurasianman View Post
Elaborate? My guess is you baby the TRD, hence why the Raven is more fun *shrugs*
Side note: Wish I could have another BRZ/FR-S just to mod
Haha I don't baby my cars. I don't abuse them either...I use them for their intended purpose
Trd grips, is loud, stock is driftyyy and funnnnnnn
The Following 2 Users Say Thank You to supra2nv For This Useful Post:
Eurasianman (08-30-2013), Jose_Timberlake (10-16-2013)
Old 08-30-2013, 01:49 PM   #804
supra2nv
supra2nv's Avatar
Switchback
Diode Dynamics (08-30-2013)
Old 08-30-2013, 01:56 PM   #805
Anaxilus
Good to hear!
Old 08-30-2013, 02:13 PM   #806
supra2nv
supra2nv's Avatar
I swear they must be related
Old 08-30-2013, 02:15 PM   #807
supra2nv
supra2nv's Avatar
Conquest TSI
Old 08-30-2013, 02:16 PM   #808
supra2nv
supra2nv's Avatar
I love these things
Old 08-30-2013, 04:43 PM   #809
torqdork
torqdork's Avatar
Drives: RV-7
It depends on the wheel design and where the weight is located. The smaller wheel might have more mass at the rim while the larger wheel may have more at the hub giving the larger wheel an acceleration advantage.
Similar consideration for the TRD BBK material aluminum vs. steel, one piece vs. two and where that weight is located.
Then alignment plays a part. Factory spec front toe-in can be easily changed to toe-out that will improve steering response.
Old 08-30-2013, 10:40 PM   #810
Anaxilus
True but unlikely, which is why I picked a 16" versus 19" wheel. A 3" larger wheel will pretty much always carry more polar mass, don't really see how that's not possible if the weight difference is only a pound unless you think his TRD rims are only 4-5" wide.
A BBK will always have more polar moment as the rotor is by definition 'bigger' and both rotors are steel regardless. If you want an exception then carbon ceramic is what you want for a rotor.
Shifting weight outward on a larger lever never improves response. Also, that same alignment technique can be applied to a more agile setup as well, it is not limited to only larger rims and brakes. You get even more response benefit not going bigger.
Normal physics doesn't allow for us to have our cake and eat it too. We have to make choices. Trade-offs are inescapable w/o a sub-space field.
Old 08-30-2013, 11:40 PM   #811
torqdork
torqdork's Avatar
Drives: RV-7
Not necessarily. It depends on mass distribution relative to axle centerline. That's where design comes into play and why high-end wheels are often two or three pieces of different materials like BBS.
Also, everything I've read indicates TRD BBK calipers (OK, Brembo by another name) are aluminum, an enormous weight savings over OEM steel.
http://www.brembo.com/en/car/Racing/...Pages/Kit.aspx
Old 08-31-2013, 12:01 AM   #812
Anaxilus
Also, everything I've read indicates TRD BBK rotors (OK, Brembo by another name) are aluminum, an enormous weight savings over OEM steel and from the all important outer circumference of rotating mass.
Ok, we are talking typical comparisons. Nobody here is debating whether to put a 16x11 wheel on or a 19x4. It's pretty much 16, 17x7 to 19x10. I don't want to waste time debating esoteric and unrealistic extreme examples (outliers) that are irrelevant to the original question of why he enjoys the Raven compared to the TRD version.
You mean the ones w/ the bolts on the rim for swapping out different sizes? 2 and 3 piece wheels are pretty universally heavier than comparable single forgings. What BBS wheels are you referring to? I haven't seen a multi-piece wheel in F1 in since before most of us were born?
Where do you see the rotors are aluminum in your link? I don't see it, nor have I ever felt or seen one. Only the hat and calipers are. The only thing I can pull up on aluminum rotors is a prototype alloy version developed in 2012.
http://wardsauto.com/vehicles-amp-te...d-200000-miles
No, just no, the rotors are iron based. This is why they have a zinc coating, to prevent rust from forming. If they were aluminum, they wouldn't be. Plus they are floating because the aluminum hat and iron rotors expand at different rates. If the rotors were aluminum like the hat, they would make a single forged rotor w/ integral hat to save weight like a F1 wheel from Enkei or Volk. This does not exist or at least is not purchasable by the average consumer.
supra2nv (08-31-2013)
BRZ in Born To Race Fast Track Trailer switchlanez BRZ First-Gen (2012+) — General Topics 34 06-28-2013 07:21 PM
10 Series are Release Series kALMIGHTY Scion FR-S / Toyota 86 GT86 General Forum 4 04-30-2013 08:23 AM
Sold my 1st born to join the BRZ crew.... cfl4rat BRZ First-Gen (2012+) — General Topics 31 04-22-2013 11:41 AM
What was the coolest car built the year you were born? ichitaka05 Other Vehicles & General Automotive Discussions 80 09-04-2011 12:43 PM
The wait till my daughter is born WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 73 06-21-2011 08:26 AM
