Old 08-07-2017, 11:25 AM   #785
s4nd
Drives: brz
to change the pi/di ratios you would need to later the three pi/di ratio tables for cold/warm/hot
I just guessed on the 30% port
you will need to look at your port and direct injector pulse widths and adjust ratio of port to direct to keep them under 7ms direct and 15 ms port.
Or possible increase size of port injectors if this cannot be done
In addition to rescaling the load axis on tables you also need to adjust the max load limits in the tune else the ecu will just truncate load at a level to low for turbo causing you to run lean.
engine load limiter A and B tables
Thank you Steve, previously i have ever change value on GDI flow rate table,a bit much ,and primary fueling additive a bit much also. after drive hard a few moment,approx 1 hour, i get my engine stall and rough,the check engine light on, after i check, the dtc is p1261 and p1262, DI circuit open, could this cause i change gdi flow too big Steve?, but after reduce all value i was change,the car back to normal
Sand
s4nd is offline   Reply With Quote
Old 08-07-2017, 05:03 PM   #786
steve99
Sand
Im not sure im understanding what your doing.
If you alter the GDI flow tables you will likey unbalance the two fueling systems
Its same as changing the port scalar without changing injectors it just unbalances the port and direct fuel systems.
you better off leaving those alone unless your running E85 and if you do alter them alter both the port scaler and the GDI the same amount percentage wise so they stay balanced.
If your on petrol then don't touch the port scaler or GDI flow tables.
Just adjust the pi/di ratio tables so your using both fuel systems all the time this will increase your overall fueling capacity as you will be splitting your fuel delivery over both systems at all times.
Those error codes indicate you have an actual problem with your DI system. Check your DI computer under bonnet is securely grounded and all mounting bolts care secure, it get its ground via the mount bolts.
Old 08-07-2017, 05:07 PM   #787
steve99
Sand
have you rescaled the Load limiter A and B tables ??
stock they limit load to 1.4 this is way to low for turbo
Old 08-14-2017, 02:36 PM   #788
s4nd
Drives: brz
Thank you Steve,you're right,about error codes, i loose connection on my DI computer box.
and Steve,i need a little bit richer afr when i release throttle pedal,so what table i must modify?, i run lean now when release throttle especially at around 2000 rpm.
thank you in advance
Sand
Old 08-14-2017, 05:25 PM   #789
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's normal, you don't need to modify anything. When off the throttle the injectors shut off.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-15-2017, 08:09 AM   #790
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
What are you guys using to comb thru your logs? i've given up on an alternative logging option appearing so i'm going to just say screw it and deal with it now. Do you have something you dump your data into that makes it more manageable? google sheets seems like a very clunky way to do it.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 08-15-2017, 08:37 AM   #791
steve99
www.datazap.me
Old 08-15-2017, 01:37 PM   #792
Kodename47
Kodename47's Avatar
Drives: UK GT86
Viperdata
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-15-2017, 06:25 PM   #793
Roadcone
StreetKart
Originally Posted by Kodename47 View Post
Viperdata
Happen to have a link to a safe site for it?
Sent from my Pixel XL using Tapatalk
Old 08-15-2017, 06:55 PM   #794
Kodename47
Kodename47's Avatar
Drives: UK GT86
http://blog.vittuned.com/viperdata/
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-15-2017, 07:23 PM   #795
Roadcone
StreetKart
Oh my jebuz. If that had live access it would be about perfect. Thank you!
Old 08-15-2017, 08:21 PM   #796
steve99
If you want live lgging with tactrix , brzedit is about only option but its $100 usd
www.brzedit.com
Old 08-15-2017, 08:23 PM   #797
Roadcone
StreetKart
www.brzedit.com
I need to throw all of my data away right now and start over. I've never done anything beyond pull the tune from my car. I can't even remember if I can reasonably log with the stock tune or not.
Old 08-15-2017, 08:25 PM   #798
Tor
Tor's Avatar
Drives: Toyota GT86
www.brzedit.com
I think Toyota Tech Stream will live log too. It's just annoying that you have to configure it with the engine running.
Tor is offline   Reply With Quote
The Following User Says Thank You to Tor For This Useful Post:
steve99 (08-16-2017)
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
