Old 09-26-2014, 07:39 PM   #785
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Agreed. I'll pay attention to it next time I press in the clutch. I think I might have thrown away my oem pulley.
texasbound972 is offline   Reply With Quote
Old 09-26-2014, 10:47 PM   #786
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by texasbound972 View Post
Just had the exedy stage 1 clutch installed now there is a noticeable idle drop and engine sounds like it's knocking. Does the ecu have to re learn? If so how long does that take? Thanks!
Too much load due to the lightweight flywheel. It's not knocking, it's bogging and trying not to die. Do you have a lightweight crank pulley as well? Not exactly a good recipe for keeping the load levels happy.
Sincerely,
Old 09-26-2014, 11:28 PM   #787
texasbound972
USMC
Yes I do Zach. Does the stage 2 tune I have not adjust for it?
Old 09-27-2014, 11:36 AM   #788
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Originally Posted by sales@delicioustuning.com View Post
Ryan,
This update addresses your EVAP concerns only. As for the issues you're describing with the throttle stabbing without you touching it on certain maps, this is not normal and we haven't seen it elsewhere (provided the car is stationary and in neutral, not moving and clutch in while in gear as others have stated). I would be interested in seeing some logs of this occurring, but please first test and make sure that your EVAP readiness clears on this map.
Sincerely,
Zach
From the looks of it, and my EVAP CEL for signal high and low signal, did you just turn on the evap? I have my AEM wideband connected to that signal, I just need evap to show ready. I still can't pass inspection with this tune.
P0452 and P0453 codes.
I have a tune from a different vendor that shows EVAP as ready, in my current configuration with AEM connected to that wire, just need to get that on your tune.
post_break is offline   Reply With Quote
Old 09-27-2014, 06:29 PM   #789
Calum
That Guy
Drives: 2013 asphalt FRS MT
Any chance of getting my cold start rpm fixed guys?
Old 09-28-2014, 02:07 AM   #790
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
Do the Stage 2 tunes have the EVAP system switched off? I need to get an inspection very soon and solving the issue with the CEL helps but with a not ready for both the header and EVAP I wont be able to pass inspection either. Possible to get a tune file that I could set for inspection then put the normal tune back in?
Shneegle is offline   Reply With Quote
Old 09-28-2014, 11:15 AM   #791
DeliciousTuning
No, the Stage 2 NA tunes do not adjust for an aftermarket flywheel, because an aftermarket flywheel/clutch isn't necessary until 330whp or thereabouts. That said, running both a lightweight crank pulley and lightweight flywheel is really doing more harm than good. The car will feel more responsive, but likely will actually slow it down. Ever wonder why drag cars run heavy, heavy flywheels? Intertia, an object in motion tends to stay in motion, and it's a lot easier for a 10lb flywheel to slow down than a 20lb flywheel. I'd recommend going back to stock on at least the crank pulley.
Sincerely,
The Following User Says Thank You to DeliciousTuning For This Useful Post:
texasbound972 (09-28-2014)
Old 09-28-2014, 11:16 AM   #792
DeliciousTuning
What header are you running?
Sincerely,
Old 09-28-2014, 11:17 AM   #793
DeliciousTuning
Calum,
Please send me an email with your full name, dongle id, and delicious user id. We'll get an update out.
Sincerely,
Old 09-28-2014, 11:42 AM   #794
Calum
That Guy
Calum,
Sincerely,
Zach
What's your email because I've sent bill two emails already.
Also having a spread sheet with that info on it might make things easier for every one.
Old 09-28-2014, 02:29 PM   #795
Shneegle
Shneegle's Avatar
Sincerely,
Zach
The Nameless Performance header and exhaust.
Old 09-28-2014, 04:13 PM   #796
DeliciousTuning
delicioustuning01@gmail.com
Sincerely,
Old 09-28-2014, 05:42 PM   #797
DeliciousTuning
Our tunes are not designed around lightened clutch's, flywheels, and under drive pulleys. If you change these parts on the vehicles it may have an abnormal affect even on the stock tune at idle. This is why our tunes are designed around stock rotating mass weights.
Because all clutch's, flywheel's, under drive pulleys have different masses to them there is no one end all solution to making sure the idle is perfect for all configurations. Just not possible.
You can attempt a relearn, and the best way to do this is reset the ECU, then turn the vehicle ON and let is idle on it's own for about 5 minutes and never touch the throttle.
Cheers,
William Knose
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
MINOCIN (09-30-2014), texasbound972 (09-28-2014)
Old 09-28-2014, 05:48 PM   #798
texasbound972
USMC
Okay so I guess I need to find someone with a stock pulley and buy a laptop to reset the ecu.
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
