Old 02-10-2017, 11:06 PM   #785
Somerandom18
Drives: 2017 manual BRZ
Anyone know how accurate the HP reading is? I put in the gross weight (car with fluids) plus 200 lbs to account for me and junk. Says I'm putting down 197hp at 6900 rpm. Seems a bit high for an untuned car..
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 02-11-2017, 02:26 AM   #786
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
Is that BHP or WHP?
Sent from my iDroid
Jajanken86 is offline   Reply With Quote
Old 02-11-2017, 06:20 AM   #787
churchx
churchx's Avatar
Drives: 2014 GT86
It's obd app reporting by some unknown calculations readings. Not something actually measured at crank or wheels as on dyno. So neither. Just "some reading" i wouldn't care about unlike eg. oil/water temps and so on ..
Old 02-17-2017, 09:56 AM   #788
allowe
allowe's Avatar
How accurate is WHP ??? I'd be stunned if it gave an accurate reading. I have an iPhone and I'm using dash command which was about 15 bucks. It has saved my life a lot using it to reset my codes and reading live data. The horsepower number on dash command seems to be almost on point.. but you'd never really know
allowe is offline   Reply With Quote
Old 03-18-2017, 12:15 PM   #789
djwishbone
Last Starfighter
Drives: 2016 FR-S Series 2.0
Has anyone ever tried to create their own ethanol gauge? Theoretically it should be possible right? Since most of us are using the rear O2 sensor for our flex fuel gauge input to the ecu. I can see the O2 sensor voltage, but I think it uses frequency and not just a standard voltage to relay ethanol level? Just wondering if anyone else has played with this. My delicious app is not very reliable stability wise and it would be awesome to get this integrated into my torque pro gauges!
djwishbone is offline   Reply With Quote
Old 04-12-2017, 04:59 PM   #790
Chronology
Drives: 13' Satin White Pearl BRZ
Anyone know the PID for gear selector?
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
Old 04-19-2017, 11:04 AM   #791
BIAbenny
Apologize if someone have already mentioned it, but has there been a work around with shutting off the car with Torque on will cause the CEL U0073 come on? I have been hesitant to use the app on the track in case of a spin off or forgetting to quit the app after pitting the car.
BIAbenny is offline   Reply With Quote
Old 04-19-2017, 07:19 PM   #792
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Ya i did it at the gym so many times, I just bought gauges. It really pisses me off too because I used my old Samsung S4 for the Torque app.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 05-14-2017, 07:06 PM   #793
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
I am interested in this as well. Has anyone been getting issues lately?
nos145 is offline   Reply With Quote
Old 06-20-2017, 10:39 PM   #794
aRex
Drives: '13 BRZ '97 Dak
Looking for VVT angles; not available in torque pro app...
aRex is offline   Reply With Quote
Old 07-12-2017, 08:44 PM   #795
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
It's possible I missed it, but I did look through this thread just about completely. So is there a way of getting the oil temp PID to read in Fahrenheit? I already had Torque set to display things in °F, but the way the PID is detailed in this thread is for display in Celsius, so that's what gets displayed for that one gauge.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 07-12-2017, 10:45 PM   #796
lazyluka
Drives: GT86
Have you tried to change the unit type and equation part in Torque?
From post #2:
Unit type: C
Equation: AC-40 (no space between A and C; "AC" is the location within the response)
Try:
Unit type: F
Equation: (AC-40)×1.8+32
You may also need to convert the Min and Max from C to F as well.
lazyluka is offline   Reply With Quote
Old 07-13-2017, 09:36 AM   #797
Overdrive
Sittin' Sideways
Overdrive's Avatar
I did try that, but I think I may have jacked up the parentheses when I did. Thanks.
-O/D
2016 FR-S, Hot Lava
Old 07-13-2017, 03:44 PM   #798
lazyluka
Drives: GT86
Also, try the * instead of the x for multiplication.
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
