#785 |
Drives: 2016 Scion FRS
#786 | |
With that said, what is the end goal? Is it overall PAX? If you are displeased with DS because you are getting thumped, is PAXing a bit better, but getting thumped in STX much different? I don't think STX trim gets you from 36.3 to a 34.0. |
#787 | |
Drives: 2017 BRZ PP, 2004 WRX
Steel Cities is quite competitive. I once broke into the top 1/4 overall in PAX, but I'm usually around the top 1/3. I'd be really pleased to be in the top 1/4 consistently. I guess I'm looking at the car and less at myself because my co-driver for the first half of the season here used to own a first gen and last year was in the top 1/10th of PAX in a GS Civic Si many events. If we're both in my BRZ and we're right within a tenth of each other almost every event, I'm thinking it's less about me and more about the car being at the low end in DS. I feel like I'm doing a lot right in the driving department. That example of a 36.4 vs a 34.0 was with Todd Kunze who was visiting from OH. I know he's a good driver. But hell, even if STX trim got me to 35.0 from that 36.4, that would have moved me up in PAX a good bit.
#788 | |
You don't have to go crazy with STX, but you do want to touch all the big things (wheels/tires, some kind of coilovers, header, tune, camber adjustment) to be competitive. I spent money on exhaust/tune, but I'm on ProParts Megans, left over SSC front sway bar, and OEM diff and I think my car is good enough to win anywhere. |
#789 | |
Drives: 2013 Subaru BRZ Turbo
We have one of our regulars that is very good running a new GR86 that might be a good measure for you. Come on out and check us out. Our site isn't nearly as grand as what you're used to but we have very good pavement so that helps a lot. |
#790 |
Drives: 2022 BRZ
#791 |
With a 17x8 RPF1 within street class offset rules, do actually fit. The 8 inch ones curve the spokes more and clear the Brembos. ... but we're stuck here with 7.5" lol.
#792 |
Drives: 2020 Subaru BRZ Limited PP
I ended up with a set of Sparco wheels with a 48 offset they clear perfect but it is close with a 225 tire and the springs. I am considering putting 7mm spacers on it
Sent from my SM-G986U using Tapatalk |
#793 |
Drives: 22 BRZ
Dumb question time - specific to the new generation twins - what is the Koni centering washer and is it required when running the Koni Sports on the new generation in SCCA DS? I can't seem to find any information what this is, what it does, if it existss, etc. I've searched this thread and found one mention of it. Reason I'm asking is that the small bit I've heard about it says it's required for the class. Left a couple voicemails for Koni and haven't gotten a call back.
#794 | |
https://www.koni-na.com/en-US/NorthA...About/Contact/ My only alternative is contacting a koni dealer that’s Motorsports affiliated to act as a go between since you’re not buying from koni directly anyway. Off the top of my head; Stranoparts, ProParts USA, or Tirerack will likely be willing to make at least a phone call or two to get your business. |
#795 | |
Drives: 22 BRZ
#796 |
Best run of the day for me at Phila. SCCA autox 6/19/22 at Ripken stadium. Finished 4th in DS out of 7 and 92nd in PAX
Sent from my SM-G986U using Tapatalk Last edited by kraftyone; 06-22-2022 at 02:23 PM. |
#797 | |
Drives: '22 BRZ
What tires are you on? You were hitting all the right marks, but I rarely heard much tire noise, only really in that far 180 right hander I was the blue STR BRZ in front of you, I posted my video in the 2022 STR thread for comparison. Obviously faster car/setup but still
#798 | |
| SCCA Solo Street Modified (SM) Discussion | whataboutbob | Tracking / Autocross / HPDE / Drifting | 61 | 07-27-2020 10:03 AM |
| SCCA Solo C Street Discussion | Kido1986 | Tracking / Autocross / HPDE / Drifting | 4831 | 07-08-2020 03:52 PM |
| Gen3MR2's C Street (SCCA SOLO) Progress | Gen3MR2 | Tracking / Autocross / HPDE / Drifting | 0 | 02-12-2016 01:02 PM |
| 2014 SCCA Solo Nationals/Pro Solo Finale thread | edj | Tracking / Autocross / HPDE / Drifting | 206 | 09-19-2014 11:34 AM |
| Henry's C Street (SCCA Solo) progression | Kido1986 | Tracking / Autocross / HPDE / Drifting | 74 | 05-04-2014 08:20 PM |
