Old 08-05-2013, 04:32 PM   #771
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Got bored, pieced this together form prototype parts and threw it on my personal car over the weekend. 75mm pulley, just like the production systems. The intercooler and plumbing are VERY prototype, as the picture clearly illustrates. It's not pretty, but it works. :p
mines13 is offline   Reply With Quote
Old 08-05-2013, 05:05 PM   #772
choi0706
Drives: t
brake booster vac clamp is not on the nipple..
choi0706 is offline   Reply With Quote
Old 08-05-2013, 05:24 PM   #773
mines13
mines13's Avatar
Nice catch. Had to actually walk out and check that to see if I fixed it after the picture, sure enough, I did not.
Old 08-05-2013, 05:44 PM   #774
Boil
Drives: CX500 Cafe Bobber
Okay, I am confused…
What are we looking at here…? I do not see an intercooler, and I am wondering what the black cylinders with the red knobs are, remote reservoirs for your front coil overs maybe…?
I dunno, more info please…!?! TY…!
Boil is offline   Reply With Quote
Old 08-05-2013, 05:47 PM   #775
sw20kosh
Drives: 2013 Black FR-S
The intercooler sits in the intake manifold right below the supercharger. You cannot see it with things assembled. What you can see is water lines and a water reservoir sitting next to the supercharger.
Old 08-05-2013, 05:47 PM   #776
Opposed
Drives: 2013 Asphalt FR-S
That's because the intercooler sits between the blower and manifold underneath. You can see the coolant res. to the right of the supercharger.
Edit: sw20kosh beat me to it
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 08-05-2013, 07:09 PM   #777
wrxgoose
WUB WUB
Drives: 2013 Firestorm
okay, so i'm trying to figure out what i'm doing wrong that could cause the supercharger to eat a belt, then cause this:
that's the belt cover for the alternator. I don't know if it's because the belt isn't tight enough or what, but i'm going to check the tension when the motor has cooled off.
wrxgoose is offline   Reply With Quote
Old 08-05-2013, 07:18 PM   #778
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
It's hard to tell 2nd hand and from a picture on the internet, but it looks like the belt wore through that from underneath. That makes me think there was too much slack.
I wonder if the idler after the alternator is binding up and causing the belt to "bunch up" around the alternator pulley.
Old 08-05-2013, 07:23 PM   #779
mines13
mines13's Avatar
Does your AC compressor clutch make an excessive noise when disengaged? Often times this is a pretty clear indicator of a failing auto tensioner. I actually had mine go when my car was complete stock with less than 10K on it. Also, ensure that your belt is in proper alignment, with no side loading at any point through the pulleys.
Old 08-05-2013, 07:25 PM   #780
wrxgoose
WUB WUB
my friend is thinking that it might be possible that this blower needs a lower redline, I don't know what could be causing it to jump up and eat the plastic. uploading another pic
don't think they'd cover it under warranty though. how much would that cost to fix?
Old 08-05-2013, 07:31 PM   #781
DriftEm
DriftEm's Avatar
What is your redline? is it still 7400rpm?
DriftEm is offline   Reply With Quote
Old 08-05-2013, 07:32 PM   #782
wrxgoose
WUB WUB
yeah, stock redline.
that's what it did to the bottom of the belt cover
Old 08-05-2013, 07:39 PM   #783
MattF
MattF's Avatar
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
Did you file the alternator? I am thinking your blower might not be sitting squarely on the engine. If it is cocked just a little bit it will cause the belt to come off or be stressed unnecessarily.
MattF is offline   Reply With Quote
Old 08-05-2013, 07:47 PM   #784
wrxgoose
WUB WUB
we did file the alternator, it wouldn't sit right otherwise. and i'm curious as to why this would only happen now, when I've had the blower on there for almost a month. yesterday it ate the belt, and now this with the new belt. I've left a message with the parts dept at my local Toyota dealership to find out the cost of a new tensioner and alternator belt cover.
edit: just went out and checked, there IS some play in the belt.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
