Old 04-25-2014, 12:17 AM   #771
Thongpocket
Master Troll
Thongpocket's Avatar
Drives: 2013 BRZ Limited
From what I understand the crawford power blocks would not take you out of STX, correct? Sorry if thats been asked. I skimmed thru and didn't see that question.
Thongpocket is offline   Reply With Quote
Old 04-25-2014, 12:36 AM   #772
FastWhite
Drives: Subaru BRZ Limited M/T
No it would not. If it is not stated in the rule set, then it is not allowed. From what I can tell it puts us into CSP where intake mods are allowed. But then you can also add a higher stall convertor for AT (me) or oil & trany coolers.
FastWhite is offline   Reply With Quote
Old 04-25-2014, 10:57 AM   #773
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Originally Posted by vroom4 View Post
Heres one for the crowd, when you hit the limiter, is it bouncing off it or does it cut fuel? Mine bounces twice and then cuts fuel. Does pedal dance fix this?
If you have a tune, you can make the limiter stay at certain RPM. if no tune. it bounces and falls on its face. With the tune its not automatic either,you should tell your tuner you want a 'hard' Rev limit.. that's the only thing that will take car of it.
I believe it still fuel cuts. Pedal dance just disables aids except ABS
Correct..the Pedal dance also allows a higher threshold on all the nannies, ABS included. The pedal dance puts the car into a "diagnostic" mode.. so it be a 'more normal' car without the aid of Traction, ABS, and G-limits.
Originally Posted by Churg View Post
Hey guys,
Relatively new to the AutoX world, I've done a few events so far, and I'm completely hooked. I pulled a noob mistake and bought 17x9 RPF1's and bumped myself into STX immediately, so I'm running Novice this year and plan on having my car completely prepped by the end of the season.
After driving my friend's STi with a lightweight flywheel and clutch, I fell in love, but I can't seem to find any solid info on whether or not I can actually run a lighter flywheel or better clutch in STX. I don't even know where to look for specific rulings; whenever I see anyone quote rulings, I can't seem to find where they are.
Any help on this would be greatly appreciated. If I can't run a lighter flywheel, I'd rather have my heart crushed now, as opposed to taking the time to install it, and show up to an event to find out it isn't legal.
EDIT: After re-reading the OP, I see that transmission changes cannot be done. So I'm guessing this rules out what I was hoping to do...
Stock or Stock type replacement is all that is allowed. No flywheel modifications are allowed other than stock.
Originally Posted by Itsjusdame View Post
I was looking In to getting LCA's to help correct some of the rear camber added from lowering . From the question previous I see most are running +/- 2.0 . I autocross at least once a month, should I even bother at this time?
Adjustable rear LCA's are allowed but they can't have spherical bushings.. they have to have Rubber/urethane to be legal.. ie: Whiteline legal, Cusco not legal.. what camber are you trying to run? what is front set at??
No intake modifications allowed other than an air intake/filter
Highlighted for your pleasure... however: There is a proposal on the line that will allow oil coolers.. but as of right now, not legal
You guys are asking good questions.. LMK if I can help further.
Bill
Scooby South is offline   Reply With Quote
Old 04-25-2014, 09:39 PM   #774
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
I'm a noob trying to determine if I can upgrade brake lines and brake fluid and stay classed as CS?
The car is completely stock.
I was classified CS for my first event last weekend (what a blast!).
GeorgeJFrick is offline   Reply With Quote
Old 04-25-2014, 09:51 PM   #775
Scooby South
Conedancer
Brake Fluid...yes..
Brake lines...no..
Stock rules are very specific... not alot you can do..sorry
Bill
The Following User Says Thank You to Scooby South For This Useful Post:
GeorgeJFrick (04-25-2014)
Old 04-25-2014, 10:13 PM   #776
Scooby South
Conedancer
here are the 2014 Ruleset
2014 SOLO rules
Old 04-28-2014, 11:31 AM   #777
Areddi
Areddi's Avatar
Drives: Firestorm FR-S
What is the most torque-focused header nowadays? I am still header/tune-less but otherwise fully prepped for STX. After the DC Pro this weekend and facing a straight-uphill run for a good section of the left course, not to mention the launches, I really could see where I was falling short on power in the torque dip. Any thoughts?
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
Areddi is offline   Reply With Quote
Old 04-28-2014, 12:53 PM   #778
toeout
Has to be Nameless EL. Every dyno I've seen posted in that thread has shown pretty radical gains in the "dip" section. Just be aware that to get most out of it requires dyno tune ( unless your tuner has already tuned a lot cars with Nameless header). There is also the pesky 3" outlet on that header that makes it harder to get a good seal on 2.5" over pipes, let alone stock over pipe.
toeout is offline   Reply With Quote
Old 04-28-2014, 05:21 PM   #779
Scooby South
Conedancer
I would agree ^^^... there are other Long tube headers available. I have Nameless and no torque dip AT all.. Pulls strong all the way to redline.. For Reference.. Danny Kao has a HKS header.. so its more upper mid to topend header.. the Nameless is more bottomend to mid.. but pulls pretty strong up top also..
Bill
Areddi (04-28-2014)
Old 04-28-2014, 05:52 PM   #780
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Since tires as of 2015 have to be 200UTG or higher what are most people planning to use? I ran my first auto x in my car yesterday and I am happy with the suspension setup but I think I need more tire under the car, and I won't be able to use original Hankook RS-3s anyway next year so I am trying to think ahead.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 04-28-2014, 05:55 PM   #781
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
New RS3 is out.
tigermack is offline   Reply With Quote
Old 04-28-2014, 05:59 PM   #782
BRZZZZZZZZZZ
Car Nut
Originally Posted by tigermack View Post
New RS3 is out.
Hard to find and expensive in my parts of town. I also want to get rid of my 225 square set up and go with 245s or 255s square which means I need new wheels again
Old 04-28-2014, 06:03 PM   #783
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
New star specs in November!
The Following User Says Thank You to tahdizzle For This Useful Post:
Scooby South (04-28-2014)
Old 04-28-2014, 06:20 PM   #784
Scooby South
Conedancer
www.Tirerack.com
Bill
tigermack (04-28-2014)
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
