Old 04-17-2014, 09:30 AM   #757
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
How much camber are most people running in STX?
BRZZZZZZZZZZ is offline   Reply With Quote
Old 04-17-2014, 09:33 AM   #758
forwallblakmail
Troll Level: Expert
forwallblakmail's Avatar
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
-3.2 up front. -2.1 in the rear. 0 toe all around.
Nick K.
NASA ST5/TT5 #130
Southeast Region
forwallblakmail is offline   Reply With Quote
Old 04-17-2014, 09:37 AM   #759
Areddi
Areddi's Avatar
Drives: Firestorm FR-S
-1.5 in the front and -2.1 in the back with my KW V3's, 0 tow all around
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
Areddi is offline   Reply With Quote
Old 04-17-2014, 09:40 AM   #760
BRZZZZZZZZZZ
Car Nut
Hmmm I am set up with -2.5 and -2.0 with very very little toe at this time.
Old 04-17-2014, 09:49 AM   #761
Wepeel
Drives: '13 BRZ Ltd
Haven't seen a lot about ice mode lately. I never get it (I do not left-foot brake). My codriver, who LFBs, can get it almost every other run (he is trying to relearn to drive with just one foot now). Any LFB'ers out there that are running into this issue?
Wepeel is offline   Reply With Quote
Old 04-17-2014, 10:03 AM   #762
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
"usually" the pedal dance takes car of it.. for the most part. havn't seen it on my car since early last year..
Scooby South is offline   Reply With Quote
Old 04-17-2014, 11:07 AM   #763
mrazny
Drives: BMW 135i, soon to BRZ
Originally Posted by Turbo Den View Post
with the new 2014 R.S.
http://ca.autoblog.com/2014/04/16/20...new-york-2014/
since it comes with TRD lowering springs... does it mean, if my non-R.S. model uses the same set of springs, i will still stay in stock class? or into STX?
Also, IF the RS does get classed in C-Street, ONLY 2014 base twins can package convert, and package convert does not mean only the springs. Everything different about the RS would need to be done to the base 2014.
What this will mean is new aero for STX likely.
mrazny is offline   Reply With Quote
Old 04-17-2014, 11:10 AM   #764
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
I wouldn't worry about the the RS series but it seems like worrying is popular here.
There is no UD/BD in ST either so only 2014's could add the extra weight.
TomR
ABQautoxer is offline   Reply With Quote
Old 04-17-2014, 11:27 AM   #765
vroom4
Heres one for the crowd, when you hit the limiter, is it bouncing off it or does it cut fuel? Mine bounces twice and then cuts fuel. Does pedal dance fix this?
vroom4 is offline   Reply With Quote
Old 04-17-2014, 02:02 PM   #766
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I believe it still fuel cuts. Pedal dance just disables aids except ABS
Old 04-17-2014, 03:36 PM   #767
mrazny
Unless Toyoboru updates a 2013 accessories catalog that includes the RS aero...
Old 04-17-2014, 05:46 PM   #768
Churg
Churg's Avatar
Drives: 2014 WRB BRZ
Hey guys,
Relatively new to the AutoX world, I've done a few events so far, and I'm completely hooked. I pulled a noob mistake and bought 17x9 RPF1's and bumped myself into STX immediately, so I'm running Novice this year and plan on having my car completely prepped by the end of the season.
After driving my friend's STi with a lightweight flywheel and clutch, I fell in love, but I can't seem to find any solid info on whether or not I can actually run a lighter flywheel or better clutch in STX. I don't even know where to look for specific rulings; whenever I see anyone quote rulings, I can't seem to find where they are.
Any help on this would be greatly appreciated. If I can't run a lighter flywheel, I'd rather have my heart crushed now, as opposed to taking the time to install it, and show up to an event to find out it isn't legal.
EDIT: After re-reading the OP, I see that transmission changes cannot be done. So I'm guessing this rules out what I was hoping to do...
Churg is offline   Reply With Quote
Old 04-17-2014, 06:57 PM   #769
mrazny
Originally Posted by Churg View Post
Hey guys,
Yes, quick answer is no. There's also really no *need* to with STX levels of power and tires.
SCCA rules... Scca.com -> SOLO -> Cars and Rules -> solo rules link
which is this: http://www.scca.com/assets/2014%20So...nd%20links.pdf
Old 04-20-2014, 10:43 AM   #770
Itsjusdame
Itsjusdame's Avatar
Drives: Asphalt
I was looking In to getting LCA's to help correct some of the rear camber added from lowering . From the question previous I see most are running +/- 2.0 . I autocross at least once a month, should I even bother at this time?
Itsjusdame is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
