Old 10-25-2016, 01:15 AM   #771
MRT
Drives: 13-Toyota-FRS
Yo honestly, can someone just re-edit the first page so that we can get the standard settings needed for my stock scion frs to run with this app called Torque?
if anyone would be so kind to message or something, much appreciated.
not trying to read the last 50 pages to figure this out
MRT is offline   Reply With Quote
Old 10-25-2016, 06:28 AM   #772
steve99
just load the app and connect via an elm327 blutooth adapter to car obd port.
everything will work straight up, only thing woth adding is oil temp pid its all on first page of this thread
Old 11-18-2016, 06:00 AM   #773
9lives
Drives: Firestorm
Working for everything except fuel for me.
Great app!
9lives is offline   Reply With Quote
Old 11-22-2016, 09:47 AM   #774
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Great app!
Have you tried this: http://www.ft86club.com/forums/showthread.php?t=73171
Old 11-23-2016, 05:40 PM   #775
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Installed torque and a scan tool LX OBD reader. Everything works fine, including oil temp. My question is, is there a consensus that oil pressure is not available via the ECU on this car?
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 11-24-2016, 09:53 AM   #776
9lives
Drives: Firestorm
cant speak for everyone but oil pressure unavailable for me too.
Old 11-24-2016, 02:05 PM   #777
Kodename47
Kodename47's Avatar
Drives: UK GT86
There's no oil pressure sensor
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-11-2016, 10:03 PM   #778
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
i have the OBDLink LX Bluetooth and i specifically bought this one because i heard it switches off. I see the light on ALL the time.. I`m a bit worried it will drain my Shorai battery.. is this normal or if it is fully off it doesnt light up?
mokinbird87 is offline   Reply With Quote
Old 01-06-2017, 10:35 AM   #779
rikixass
rikixass's Avatar
You can only use a Nexus 7???
rikixass is offline   Reply With Quote
Old 01-06-2017, 01:01 PM   #780
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
I didn't trust the auto off feature of that so I have mine hooked up to the obd port via an obd cable that has a manual on/off switch and I turn it off when not in use.
Pointmutation is offline   Reply With Quote
Old 01-08-2017, 12:13 PM   #781
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
Do you have a link to the cable you use? That's a great idea.
I too saw that mine always stayed on. I found it goes to sleep if I turn the bluetooth on my phone off. Which is annoying, because I don't want it to drain the battery if I forget to turn the bluetooth off.
BR-ZED is offline   Reply With Quote
Old 01-11-2017, 09:25 AM   #782
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
My OBDLink LX also seems to stay on (at least in standby, I guess?) all the time, but I haven't had any problems with it draining my battery - even when the car has sat for a week and a half. If I were going to be away from my car for much longer than that I'd probably disconnect the battery anyway.
I wouldn't be overly concerned about the small amount of drain by the idling OBD adapter.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 01-11-2017, 01:17 PM   #783
Pointmutation
Drives: 2016 ZC6
I have this one. Just search for Obd switch and it'll pop up. Tonsiki OBD 2 Cord 16 pin M/F Male to Female Right Angle Diagnostic Extension Cable with Power Switch
My Obdlink is attached to this and I only turn it on when I want to run Torque app. They also have splitter Obd cords so you can attach multiple devices. I use a splitter one on top of this so I don't wear out my obd port when I wanna attach something else, like an OFT.
Old 02-10-2017, 05:54 PM   #784
wrh3
billswebspace.com
wrh3's Avatar
Drives: 2017 Alfa 4C, 2019 Fiat 124 Abarth
Originally Posted by cueball89 View Post
Has anyone compared oil temp data from the oem sensor and location to an aftermarket gauge installed in the block by the ac compressor? The oem senor seems to constantly read 10-15 degrees fahrenheit higher than my installed gauge. The oem sensor is reading 205 and the aftermarket gauge is seeing 190-195 going down the highway at 75. I assume that's just location differences.
Same issue here.
Bill
BillsWebSpace.com
wrh3 is offline   Reply With Quote
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
