#771 | |
2013 FR-S Whiteout / SSC
#772 |
JHerbert Racing
Drives: 2013 Scion FRS
Tucked in on the rumbles - 17x9 +35 - 255/40/17 maxxis rc1
#773 |
Drives: 2015 brz
Wheel Directory: Enkei RPF1 17x9.0 +35
Can anyone confirm any rubbing issues on a bilstein pss14 coilover running a 255/40/17? Or if I should just stick to the 245. Was looking at PS4S, Extremecontact, or something comparable if anyone has recommendations. Thank you!
#774 | |
Senior Misanthrope
#775 |
Drives: 2018 BRZ
![]() this-a me |
#776 | |
Drives: 2015 brz
Perfect, on OEM at the moment but would like the bilstein setup down the road, would camber bolts produce enough camber on their own? Sent from my iPhone using Tapatalk |
#777 |
Senior Misanthrope
I've never used camber bolts before, so I'm not sure. From what I hear, you can get -2* or so by putting the camber bolts in the *lower* holes, and using the old lower bolts in the upper holes.
#778 |
Drives: 2014 WRB BRZ Limited
Decided to do something a little different with mine.
17x9 with 255/40 Hankook RS4. ![]() ![]() ![]() ![]()
#779 |
Drives: DGM BRZ
I like that
#780 | |
Here's a pic of the above setup. Point is you're looking at a +35 with a bit less camber and you shouldn't have an issue with a 255 tire. Not too many people go for the Bilstein but it's a good option imo, just want to share the love. Edit this setup never rubbed even with some spirited driving.
#781 |
Drives: 2014 BRZ Sport Tech
They fit
#782 | |
Drives: 2014 SWP BRZ
2014 SWP Subaru BRZ
2014 VW GTI 2013 Asphalt FR-S - Sold |
#783 |
Drives: Black BRZ
#784 |
Senior Misanthrope
I tracked with this setup for a long while without issue. 3mm spacer not really necessary.
| Wheel Directory: Enkei RPF1 17x9.0 +45 | LevinPhan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 265 | 06-04-2024 11:13 AM |
| Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** | LSD Motorsports | Groupbuys | 246 | 08-29-2013 01:35 PM |
| WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 | Touge Factory | Wheels and Tires | 2 | 02-05-2013 04:53 PM |
