Old 07-17-2018, 10:26 PM   #771
Open Loop
2013 FR-S Whiteout / SSC
Originally Posted by kch View Post
I can't comment on whether they will fit at that alignment with the stock-sized springs, as I have coils. However, I can tell you that you will have very little margin for spacers. Pic is with 245/40/17 RS3s at around -3* front camber. You could *maybe* fit a 5mm spacer and clear the fender.
Thank you. This weekend I saw the 17X9 rpf1's with a 42mm offset on an otherwise stock suspension, running 245/40-17 michelin pilots of some sort. I figure that there must be a way to make it work with my -3* camber, I just have to figure out the right offset. It sure looks good on your car, which I imagine are et35.
Open Loop is offline   Reply With Quote
Old 07-19-2018, 06:28 AM   #772
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Tucked in on the rumbles - 17x9 +35 - 255/40/17 maxxis rc1
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 08-22-2018, 06:12 PM   #773
jhalagian
Drives: 2015 brz
Wheel Directory: Enkei RPF1 17x9.0 +35
Can anyone confirm any rubbing issues on a bilstein pss14 coilover running a 255/40/17? Or if I should just stick to the 245. Was looking at PS4S, Extremecontact, or something comparable if anyone has recommendations. Thank you!
jhalagian is offline   Reply With Quote
Old 08-24-2018, 04:00 PM   #774
kch
Senior Misanthrope
kch's Avatar
I'm not 100% sure, as I haven't used Bilsteins before. However, the issue with fitting 17x9 +35 with 255s isn't strut clearance, but fender clearance. It should clear your coils just fine, and will be okay in the front with some reasonable camber to clear the fender.
Old 08-24-2018, 04:14 PM   #775
dallas
Drives: 2018 BRZ
this-a me
dallas is offline   Reply With Quote
Old 08-25-2018, 11:55 PM   #776
jhalagian
Drives: 2015 brz
Perfect, on OEM at the moment but would like the bilstein setup down the road, would camber bolts produce enough camber on their own?
Old 08-27-2018, 12:25 PM   #777
kch
Senior Misanthrope
kch's Avatar
I've never used camber bolts before, so I'm not sure. From what I hear, you can get -2* or so by putting the camber bolts in the *lower* holes, and using the old lower bolts in the upper holes.
Old 09-04-2018, 12:09 AM   #778
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
Decided to do something a little different with mine.
17x9 with 255/40 Hankook RS4.
BR-ZED is offline   Reply With Quote
Old 09-05-2018, 02:14 PM   #779
jubella2
jubella2's Avatar
Drives: DGM BRZ
I like that
jubella2 is offline   Reply With Quote
Old 09-09-2018, 02:35 PM   #780
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I've got +45 17x9 RPF1, 245-40-17 RE71R, with a 5mm spacer so +40 effectively, Bilstein B14, two sets of lobed camber bolts (16mm & 14mm SPC) gets me to -2.6 degrees and there's not much wiggle room, I might even have a touch of rub under 10/10ths cornering, haven't pulled the wheels off to check yet but I can't see any rubbing on the tire so I'm probably ok.
Here's a pic of the above setup. Point is you're looking at a +35 with a bit less camber and you shouldn't have an issue with a 255 tire. Not too many people go for the Bilstein but it's a good option imo, just want to share the love.
Edit this setup never rubbed even with some spirited driving.
ineedyourdiddly
Old 09-25-2018, 10:46 PM   #781
lc300
Drives: 2014 BRZ Sport Tech
They fit
lc300 is offline   Reply With Quote
Old 09-26-2018, 05:48 PM   #782
Doji Style
Drives: 2014 SWP BRZ
Originally Posted by Open Loop View Post
Hi everyone - I am on the SSC kit as my car is primarily used for autocross, but I am starting to get into track events, and I am thinking of getting a wider/lighter wheel, with potentially more rubber on the ground. I would love to get 245/40-17 RE71Rs to work on a 9 inch wide wheel.
I have about -3 camber in the front and -2.2 in the rear. I am pretty sure that the front has very little clearance with the spring on a 17X8 et40 225/45/17.
I am interested in whether anyone is running RPF1's 17X9 +35 on the SSC kit (or the same Eibach springs), and whether anything needs to be done to avoid rubbing like spacers and extended bolts.
Thank you, I appreciate it!
That wheel will put you in STX. I forget what the rule book says about SSC since I don't compete in it but I believe the max width you can go is 17x8 and they must weight 16lbs without additional weights.
2014 SWP Subaru BRZ
2014 VW GTI
2013 Asphalt FR-S - Sold
Doji Style is offline   Reply With Quote
Old 08-04-2019, 05:22 PM   #783
WC-BRZ
Drives: Black BRZ
With the AP Sprint Kit:
Thanks for the pics.
I think a 3mm spacer upfront should be good enough and would add a slight margin of safety without getting into headaches involving extended studs.
Would be awesome to see if someone has this setup with a 3mm spacer
WC-BRZ is offline   Reply With Quote
Old 08-04-2019, 09:16 PM   #784
kch
Senior Misanthrope
kch's Avatar
I tracked with this setup for a long while without issue. 3mm spacer not really necessary.
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
