#771 |
Drives: 2022 Subaru BRZ 6MT IR
Indeed it does! Very nice.
2022 BRZed, Red, Base, Manual, Simple
#772 |
Mebmer
Drives: Sienna, GR86, FL5
#773 |
Drives: '22 BRZ
I did Motul DCTF in my trans, shifts way better cold. Otherwise it already felt great.
#774 |
Drives: '22 BRZ
Recently did driver weighted alignment with OE crash bolts in the upper holes up front maxed out and otherwise stock. Camber close to -1.00 deg up front (a tad more on passenger side, less on driver side) and about -1.5 out back. Zero toe all around. Getting out all that stock toe-in made the steering way more resonsive. Ordered some exhaust parts this morning - catted/resonated front pipe (almost did the combo pipe but am hopeful a proper long-tube header will be designed for the 2.4) and csg touring cat-back (unfortunately back-ordered). I'll order suspension once I get some base line times with the stock parts at my local track.
#775 |
Drives: '22 Tacoma, '19 Macan, '22 BRZ
I'm with Doc - I swapped trans and diff fluid around 800 miles with Motul 300v 75w90 and it made a positive impact. For the money and easy DIY, it's a no brainer.
#776 |
Drives: 2022 BRZ
I think I got all my money worth out of these tires lol.
Here is my best run today on them.
2022 BRZ 71 STR
Sponsors Xero-Limit//Karcepts |
#777 |
Drives: Ice Silver 2022 BRZ Limited
Installed my new Bumper Plugs. Looks significantly better.
The Following User Says Thank You to MikeNSX2 For This Useful Post: | AK2112 (03-27-2022) |
#778 |
Another view.
#779 |
Drives: Mini
Yesterday I did all my LED's, amazing how a simple change made a big difference for me. I also installed the MTEC clutch spring. I definitely feel some slop but it's not bad at all and unfortunately it didn't really help me feel the bite point in the clutch. I'll keep using it for a while to see how it goes though, maybe it's just my shoes.
I also installed my rear view mirror dash cam, hardwired it to the fuse box but now no way to put the cover back on. Overall it was pretty easy install, easy to take off the panels but since I haven't driven yet, I hope I didn't leave anything loose! |
#780 |
Drives: '04 STi, '12 Mazda 3 Hatch
^It seems like you just disconnected the seat occupied sensor. Won't that prevent the air bag from working?
#781 |
ProCrastinationConsultant
What scenario would the driver's seat not have someone in it? The passenger seat sensor turns off the airbag, but I'm not aware of any vehicle that detects if the driver's seat has someone in it. Most just assume that if the car is on, there's someone in the driver's seat.
I don't believe the driver's side airbag can be turned on/off anywhere besides pulling the airbag system fuse to disable the entire system
#782 | |
Drives: '22 BRZ
#783 | |
Drives: '22 BRZ
The Following User Says Thank You to mr.whiskers For This Useful Post: | DocWalt (03-28-2022) |
WHAT DID YOU DO TO YOUR FRS TODAY? | KalbiCool88 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 11-04-2015 10:36 PM |
Do you know what today is? | Yruyur | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 01-21-2015 02:51 PM |
just got my OFT today...help please! | carlitosway6891 | Software Tuning | 9 | 02-20-2014 10:05 PM |
TODAY, TODAY, I GET IT TODAY!!!! :D | Trashed675 | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 02-14-2013 01:16 AM |
sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) -- General Topics | 8 | 03-31-2012 08:53 AM |
