#757 | |
Also, for anyone else reading too: If the problem is that the DRL is not coming on at all, please make sure the DRL is supposed to be coming on to begin with! You must have the vehicle started and running. Autos must be in D, manual must have ebrake down. You might need a friend to look and see. Please be safe when testing.
The Following 7 Users Say Thank You to Diode Dynamics For This Useful Post: | 4honor (02-26-2015), Elkton86er (02-26-2015), FLYFISHR (02-26-2015), Husker BRZ (02-26-2015), Jmonty (02-26-2015), PandaSPUR (02-26-2015), Porcupint (02-26-2015) |
#758 | |
Drives: 13 GBS BRZ
@PandaSPUR I'm not repining this one.. ![]() |
#759 |
Drives: WRB BRZ 6AT
So I received the module yesterday, installed it following the instruction on DD's youtube video.... one of the module's plug's under clip broke off (only slight pressure), was still able to plug everything in though... but car battery dead
![]() well, long story short, was able to jump start it...with car started and running and hand brake down, the boomerang and DRL don't light up. They only light up when I put my car in gear... DD, is mine faulty also? |
#760 | |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Try setting it to "Auto" mode on your headlight stalk and see if that turns them both on with parking brake down and in Neutral, with the car running.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
The Following User Says Thank You to DaJo For This Useful Post: | Diode Dynamics (02-26-2015) |
#761 | ||
Your vehicle needs to be in gear for the DRL to come on, so everything is working properly. Quote:
You do need to have the car started, with the car in drive or neutral if it's an automatic, or handbrake down on a manual. Make sure you're on a flat surface when checking, or a have a friend look. Thanks!
The Following User Says Thank You to Diode Dynamics For This Useful Post: | Annahra (02-26-2015) |
#762 |
Drives: 2014 WRB BRZ LTD
#763 | |
Drives: WRB BRZ 6AT
#764 | |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
I have no idea how the BRZs with auto transmission work, but BEFORE the mod, did the DRLs light up while you were in neutral?
Sounds like theyre working fine if they light up when you're in gear. Quote:
The Following 2 Users Say Thank You to PandaSPUR For This Useful Post: | Diode Dynamics (02-26-2015), Porcupint (02-26-2015) |
#765 |
@jflBRZ
My gar is in the garage for the winter but I'm PRETTY sure the DRLs don't come on with a manual transmission unless it's actually in gear. I vaguely remember trying to take a look once and I couldn't.
#766 |
FT86Club Vancouver
The Following User Says Thank You to DaJo For This Useful Post: | jflBRZ (02-26-2015) |
#767 |
Drives: 2013 BRZ Limited WRB
Just got tracking info minutes ago for my 2/15 order. Things are moving!
#768 | |
Drives: 13 GBS BRZ
The Following User Says Thank You to Porcupint For This Useful Post: | qoncept (02-26-2015) |
#769 |
We have a manual. Car must be running and ebrake dropped fully for DRL to come on.
I believe for automatic, car must be running and in Drive. Again, this mod does not change when the DRL works, just what lights come on as the DRL. Thanks!
#770 |
Go Big Red!!
Drives: 2013 SSM BRZ Limited
@KelvinBRZ @PandaSPUR
Here is a pic of my 6k headlights: (I know it isn't the best picture but it gives you an idea, I'll add a night time one tonight. I will say the light isn't as effective as 4300k, that being said I think I will be trying the 5k lights in the near future to try and get more actual use out of the light. I don't dislike the 6k, but I think the 5k gives you basically the same aesthetic look with more functional use. While I was out there I checked my module and tried my lights on auto, in neutral, and the car running and.... voila ![]() Last edited by Husker BRZ; 02-26-2015 at 08:03 PM. Reason: added night time pics |
The Following 4 Users Say Thank You to Husker BRZ For This Useful Post: |
[Closed] Gauging Interest thread | pansontw | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 08-27-2014 03:14 PM |
So has anyone managed to get the BRZ Boomerang/parking lights to operate as DRLs? | gt8613 | BRZ First-Gen (2012+) -- General Topics | 18 | 04-27-2014 02:09 AM |
Gauging Interest | ISC Suspension | Announcements, Contests, Giveaways | 17 | 04-03-2014 09:44 AM |
Jdm headlights - gauging interest | Hawk77FT | Exterior Parts (Aero, Lighting, Etc.) | 7 | 03-31-2014 09:38 AM |
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 10 | 08-30-2013 10:53 AM |
