Old 06-15-2017, 11:02 AM   #757
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
is there any reasoning that my car would make a large number of output files? some are minutes long while others are only 4 frames of data?
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 06-15-2017, 05:23 PM   #758
steve99
Usually two reasons
1. Your using triggers and the trigger condition is being set on and off
2. The connection to obd port is not good and the communications keeps getting interrupted or power to unit is interruped
Try bending the two rows of pins on tactrix inwards very slightly like 0.5 mm, try using an old full size SD memory card or similar so pins stay aligned
Old 06-17-2017, 01:44 PM   #759
aagun
Drives: 86
Hi ..
Tactrix op2 log the ram from 0xFFF8000 TO 0XFFF8FFF
DO YOU KNOW HOW TO READ OTHER AREA?
aagun is offline   Reply With Quote
Old 06-17-2017, 04:38 PM   #760
ThatDamnRanga
Drives: 2014 Dark Grey Metallic GT86
Originally Posted by aagun View Post
Hi ..
What 'other area' are you looking to read?
ThatDamnRanga is offline   Reply With Quote
Old 06-22-2017, 04:06 PM   #761
aagun
Drives: 86
From
0xFFF00000 TO 0xFFF7FFFF
0xFFF8FFFF TO 0xFFFFFFF
THE RAM IS FROM 0XFFF80000 TO 0XFFF8FFFF
Old 06-23-2017, 07:49 PM   #762
Swivel
Drives: 2015 Scion FR-S ZN6
(Warning: loaded question ahead)
How do I go about making these corrections myself?
The idle ignition timing tables for my ZA1JD00C are a bit messy; the same that we've seen for B01C and others. I tried using basic math (calculating the differences between start/end of tables and axes), but they seem to differ quite a bit between the various definition files. Any chance I could get some help on this?
The definition file I'm using as a base for this is the latest from OFT. In the example below, I'm missing the X axis for the "Base Timing Idle (In-Gear)(Above Speed Threshold)" table.
D00C
700C
3D Definition contains the coolant temp like it's supposed to, but the storage address is not defined, and it seems like the Y axis is incorrectly defined as well.
2D and 3D Definitions in D00C
RomRaider with ZA1JD00C
Originally Posted by Kodename47 View Post
I've gone through and updated all my definition files. I found some poorly defined idle ignition tables and I have added some tables so that many of the files are now more complete and matching across types.
Standard File Definitions:
ZA1JB01C Definition xml
ZA1JB01D Definition xml
ZA1JA01G Definition xml
ZA1JA02G Definition xml
ZA1JA01I Definition xml
Custom File Definitions:
ZA1JA01G with Metric Conversion
ZA1JA02G with Metric Conversion
ZA1JA01G with Metric Converion & Ratio Tables (ECUtek Comparison)
ZA1JA02G with Metric Converion & Ratio Tables (ECUtek Comparison)
OFT Zip Files
OFT Manual - Contains LC and FFS
US C Series OFT
ADM/EUDM G Series OFT
OFT Auto
US D Series OFT
ADM/EUDM I Series OFT
Swivel is offline   Reply With Quote
Old 06-24-2017, 12:56 AM   #763
steve99
D00C
700C
Unless your prepared to learn how to reverse engineer the ecu code, its going to be much easier to just flash your D00C ecu with the B01C rom it will work fine and the defs for B01C are much better
Old 06-24-2017, 08:37 AM   #764
aagun
Drives: 86
HERE YOU ARE
ZA1JF00C i dont know if i work or not
Code:
<table name="Base Timing Idle (In-Gear)(Above Speed Threshold)" storageaddress="118EFC">
<table type="X Axis" storageaddress="118ECC" />
<table type="Y Axis" storageaddress="118EF4" />
Code:
<table type="3D" name="Base Timing Idle (In-Gear)(Above Speed Threshold)" category="Ignition Timing - Advance" storagetype="uint8" endian="big" sizex="10" sizey="2" userlevel="4">
<scaling units="Base Ignition Timing (degrees BTDC)" expression="(x*.3515625)-20" to_byte="(x+20)/.3515625" format="0.00" fineincrement=".2" coarseincrement="1" />
<table type="X Axis" name="Engine Speed" storagetype="float" endian="little" logparam="P8">
<scaling units="RPM" expression="x" to_byte="x" format="#" fineincrement="50" coarseincrement="100" />
</table>
<table type="Y Axis" name="Coolant Temperature" storagetype="float" endian="little" logparam="P2">
<scaling units="Degrees F" expression="x" to_byte="x" format="#" fineincrement="1" coarseincrement="5" />
</table>
<description>This is the base timing in idle mode when vehicle speed is greater than the 'Base Timing Idle Vehicle Speed Threshold' and transmission is not in neutral.</description>
Old 06-24-2017, 04:39 PM   #765
Swivel
I actually am quite prepared! For the time being, I'll see about using the B01C. But if you could point me in the right direction, that would be awesome!
Old 06-24-2017, 08:49 PM   #766
steve99
Best place for rom dissassembly help is the www.romraider.com forums
Ask a guy called tdd he does a lot of dissassembly think hes a moderator on that forum , they hould be able to hook you up with the ida and instruction sets for the sh72531 processor our ecu uses, vood luck im sure those guys will apreciate people helping with dissassembly
Old 06-25-2017, 12:33 AM   #767
Swivel
Unfortunately it did not! However, I got a little curious and, assuming the tables are the same size for each MAP, I used some basic 16-bit math to calculate the location of the table in my D00C def.
Here's what I came up with:
Code:
    </table>
Which produces the following:
HERE YOU ARE
Code:
Code:
</table>
</table>
Old 06-25-2017, 04:40 AM   #768
aagun
Drives: 86
This is what you looking for
Old 06-25-2017, 04:42 AM   #769
aagun
Drives: 86
http://www.ft86club.com/forums/showt...=61069&page=11
Old 07-20-2017, 11:05 AM   #770
Tor
Tor's Avatar
Drives: Toyota GT86
When we log "load", which load is it exactly?
Is it just MAF*60/rpm? Or is it the final load after all corrections are applied?
Also, where does "load_abs" come from?
Thanks!
Tor is offline   Reply With Quote
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
