Old 01-01-2013, 01:57 PM   #757
Xanatos
Xanatos's Avatar
Drives: @redline, '14 BRZ, '98 Forester
Originally Posted by cruzinbill View Post
last time I checked this was the only of the 3 that are a roots style....so they all have their place. Vortech for the centrifi lovers and avo for the turbo folks.
This is twin screw type.
Xanatos is offline
Old 01-01-2013, 02:29 PM   #758
Starscream15
Starscream15's Avatar
Drives: 2013 Subaru BRZ - DGM
Originally Posted by bakerr6 View Post
If they could get this kit up to 350 rwhp running a smaller pulley, IC and meth, then I think it would be a more feasible product to me.
The Bullet Rep at SEMA claimed they hit 320 with the intercooled kit so a smaller pulley should get close.
Starscream15 is offline
The Following User Says Thank You to Starscream15 For This Useful Post:
bakerr6 (01-01-2013)
Old 01-01-2013, 03:25 PM   #759
subatoy
subatoy's Avatar
Drives: subatoy
This sounds like its already using a smaller pulley.
if I'm correct SC can only change their boost levels with different pulley sizes.
subatoy is offline
Old 01-01-2013, 03:38 PM   #760
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
subatoy is correct. I had a range of pulleys on my roots blower I could change between 7, 9 and 11 psi... each one getting a little smaller. At 320 they definitely have a small pulley on there.
Jeff86 is offline
Old 01-01-2013, 04:26 PM   #761
subatoy
subatoy's Avatar
Drives: subatoy
do you have to get a new belt per pulley size?
subatoy is offline
Old 01-01-2013, 04:38 PM   #762
Opposed
Drives: 2013 Asphalt FR-S
Depends on the pulley size, but when you get to the smaller ones, you usually do. My friend had to change the belt size on his GTP when going to a smaller pulley.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline
Old 01-01-2013, 04:52 PM   #763
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
In the case of that SC (Jackson Racing), there was enough adjustment available in their tensioner to tighten the belt for smaller pulley sizes. Their setup replaced the car's stock spring tensioner. I'm curious how they are doing it on the Innovate kit. I hope they have spent some time creating a great design for routing and keeping tension on the belt.
The position where the Innovate SC is mounted is great. Just look at the amount of belt wrap around that pulley. It should mean you can run a very small pulley and the belt won't slip over it even at extremely high RPM... as long as the belt remains tight. If the belt slips you start losing psi.
Jeff86 is offline
Old 01-01-2013, 06:30 PM   #764
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Looking closely at this, I now think all they had to do was add a single bracket and new pulley in the location I noted to route the belt. I believe they have retained the stock tensioner in its original location. The tensioner and its pulley are immediately beneath the new pulley. If this is right, I think it's a very good (and fortunate) situation. The stock tensioner is spring loaded which keeps tension on the belt during high RPM. Looks really easy to install too. I would say with the use of the stock tensioner, going significantly smaller on the SC pulley would make a belt length change likelier.
Jeff86 is offline
Old 01-01-2013, 06:40 PM   #765
gmookher
No offense meant at all, but
Youre not correct.
There is more than one way to skin a cat. I am not allowed to say anything more, sorry.
... there IS more to induction design than rotational speed alone when engineering and prototyping such an offering...
gmookher is offline
Old 01-01-2013, 06:52 PM   #766
OrbitalEllipses
Drives: Attitude
Originally Posted by JoeBoxer View Post
I don't care if the thread delivers as long as the system does. There is something out there for everybody and that's what makes this such a great hobby. If people want to get in a rush and buy the first thing available that's fine and with AVO and Vortech you know what you're getting so that's understandable. I personally will wait on this one, Litchfield, and JDL's twin scroll turbo kit before i make a decision.
And there hasn't been any indication that the system delivers. More info needed soon or this will be an afterthought for the community.
OrbitalEllipses is offline
Old 01-01-2013, 06:55 PM   #767
Noob4Life
86 Noob
Drives: Firestorm FR-S
They might as well just delete the thread so we forget about them and then they can make a new thread if/when they get a respectable amount of info
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Noob4Life is offline
Old 01-01-2013, 06:56 PM   #768
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Youre not correct.
On roots or twin screw SCs you could effect PSI with cam profiles (less overlap) to hold boost, or the amount of exhaust back pressure can come into play, but generally speaking on these types, it's pulley size that determines your boost level.
Jeff86 is offline
Old 01-01-2013, 06:59 PM   #769
gmookher
I'm a fan of all solutions, I love that there are so many coming to market
Well, I know the setup I signed on for is scalable and my 60whp can become 80 or 100whp with some minor mods, and there is already commitment for future reseller support from perrin to achieve this bump past 60whp for those who want more.
I'm not saying you need to sign up for my solution, but I follow this thread to see what the other guy is getting ... it would be great to have some vendor or reseller feedback from this thread that said yes, the SC from Innovate can be amp'd up to 8 or 10psi if desired and will work well, with wonderous driveability.
It would be even cooler is someone already tested that, as is the case with the Vtech SC, it was great that an upper limit has been established for that system with stock fuel setup.
Since your boost curve for a twin screw is DIFFERENT in curve shape than a centri, I wonder how that scalability and shall we say "stage 1PLUS" can be done here on this kit?
gmookher is offline
Old 01-01-2013, 07:16 PM   #770
OrbitalEllipses
Drives: Attitude
I'm not signing up for any solution at this point. I'll have to wait until I see hotter cams and built top ends to make my choice.
***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** Touge Factory Interior Parts (Incl. Lighting) 9 11-29-2012 03:13 PM
lost screw for sensor intake Mr.Jay Engine, Exhaust, Transmission 5 10-21-2012 10:26 PM
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More Rev Works Audio/Visual, Electronics, Infotainment, NAV 28 10-09-2012 06:04 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 01:42 PM
Missing rubber piece for intake screw ngabdala Engine, Exhaust, Transmission 1 08-31-2012 07:10 AM
