Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
timurrrr
Old 08-26-2022, 11:01 PM   #757
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by mycrors7 View Post
i still dont believe the clogged pickup only damaged a single rod bearing
blocked pickup would damage all 4 bearings to some extent.
any way you can ask the dealer to check the other rod bearings for damage?
iirc, there's 3 failures that are all related to a cyl 1 rod bearing
They probably are not going to bother to check. I doubt they would check the mains either.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
AndyRC (08-29-2022), JusTheG (08-27-2022), mycrors7 (08-27-2022), Tcoat (08-27-2022)
Old 08-27-2022, 10:49 AM   #758
Ya at the dealership level they are only go to go until they find the smoking gun. I would hope that Subaru checked the other parts though.
AndyRC (08-29-2022), DylanJZA (08-28-2022), JusTheG (08-27-2022), mycrors7 (08-27-2022)
Old 08-30-2022, 05:45 PM   #759
Teseo
Drives: frs
@Kevinvo
That was madness. Those engine are more cursed than 1st gen valve springs
Old 09-03-2022, 05:19 PM   #760
removedonut
Drives: 2022 Toyota GR86 Premium 6MT
Here’s my contribution.
11/21 build date. 10,200 miles, car driven as it was intended (which may or may not include non-timed non-competitive closed course driving events)
External signs of issues visible in RTV oozing out of timing chain cover at all sides, longest glob I found was about half an inch in length. Oil pan RTV intact except for one ~2 inch dangly piece. Definitely overapplied at the factory, per subaru’s own specification. Several small pieces of RTV hanging out in the bottom of the oil pan.
Didn’t find any RTV in the oil filter after 4k miles.
One small piece of RTV on dipstick (although considering the dipstick sits right on top of the RTV bead, i don’t think this indicates any real issue).
RTV clogging pickup screen, definitely not the worst i’ve seen. I’d estimate 1/3 of the top screen is blocked in some capacity.
removedonut is offline   Reply With Quote
The Following 5 Users Say Thank You to removedonut For This Useful Post:
JusTheG (09-04-2022), Petah78 (09-03-2022), Tcoat (09-03-2022), Teseo (09-03-2022), Thatllbuffout (09-06-2022)
Old 09-03-2022, 06:14 PM   #761
Petah78
Drives: 2022 BRZ sport-tech
Thank you for the datapoint. Did you drop the pan because off issues observed? Or just being proactive? Any flakes/shimmer in the pan?
Thank you.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 09-03-2022, 08:11 PM   #762
removedonut
Thank you.
I have the tools, know-how, and a couple hours of free time so it just seemed like a no-brainer to get in front of the issue. The heaping globs of RTV hanging around all edges of my timing chain cover definitely motivated it, but no actual issues. I have an oil pressure gauge and my oil pressure consistently doubles subaru’s specification even with that RTV in there.
No flakes. I have a magnetic drain plug and there was nothing on there other than the normal black sludge. There were 2 small flakes in the oil filter I used from 5k-9k, but that is fairly normal.
The Following User Says Thank You to removedonut For This Useful Post:
Old 09-03-2022, 08:34 PM   #763
Petah78
Thank you for the detail data, lots of great information, especially with the oil pressure gauge and magnetic drain plug. It's good to know that there doesn't appear to be accelerated wear even with the the top partially blocked pick up. I would have likely done the same had it not be for warranty concerns. I will monitor via UOA and proceed with caution. Thank you again.
Old 09-06-2022, 01:47 AM   #764
Grif
Grif's Avatar
Drives: BRZ 2nd gen
A close up and personal inspection of the oil pickup screen/basket.
Really gives you perspective of the surface area at play.
https://twitter.com/yonsama800/statu...69665373138945
Grif is offline   Reply With Quote
The Following 8 Users Say Thank You to Grif For This Useful Post:
FrickingReallySlow (09-06-2022), Jianlun (09-08-2022), jongers (09-06-2022), justinco (09-07-2022), Pat (09-06-2022), Petah78 (09-06-2022), Thatllbuffout (09-06-2022), timurrrr (09-07-2022)
Old 09-06-2022, 04:38 AM   #765
Thatllbuffout
Drives: WRX
Interesting, I did not realize just how small that filter was. Thanks for sharing.
Thatllbuffout is offline   Reply With Quote
Old 09-06-2022, 05:22 AM   #766
Grif
Grif's Avatar
Drives: BRZ 2nd gen
It looks like it could hold a considerable amount of debris before clogging up, albeit this does not factor in any cavitation issues that may occur.
Any fluid dynamics experts or submariners here that could chime in on working out the requirements for cavitation?
Old 09-06-2022, 11:26 AM   #767
Petah78
Thank you for posting this info. I have long suspected that the top doesn't represent a large percentage of the total surface area of the pick up but this post confirmed it. The 4 sides looked to have a much larger surface area and by estimation, i say the top is about 1/7 (14%). I wouldn't think flow is the problem even if the entire top side is blocked. Cavitation is a real concern though. I am not an engineer but i think cavitation will only become an issue with:
- Higher oil temps
- Higher pressure differentiation pre/post pump (how bad the blockage is)
Any engineer can confirm?
Old 09-07-2022, 04:50 AM   #768
mycrors7
mycrors7's Avatar
Drives: zd8 brz
I have some bad news regarding the STI brz cup car oil pan..
My last resource couldn’t get it claiming it’s discontinued. I’m 99% sure it’s not possible to obtain the oil pan unless you are a shop/team building a documented cup car
I’m looking further into it, but I’m not hopeful anymore
mycrors7 is offline   Reply With Quote
Old 09-07-2022, 07:02 AM   #769
Doc_Bch_Stkrs
FNG
Drives: Hot Wheels
Not for nothing, I'm sure you want to use a Subaru part with a Subaru PN, however the Trust-Power Greddy JP site lists their oil pan baffle as being a part of the GR86/BRZ cup car.
I plan to go this route in the future.
Doc_Bch_Stkrs is offline   Reply With Quote
The Following User Says Thank You to Doc_Bch_Stkrs For This Useful Post:
Tokay444 (09-07-2022)
Old 09-07-2022, 12:17 PM   #770
mycrors7
mycrors7's Avatar
Drives: zd8 brz
Subaru USA considered the brz STI cup oil pan an aftermarket part, because it’s not available in their system.
Tbh there’s no real reason to go with the brz STI cup car oil pan. I had already started the process for purchasing it and made a payment as well. ETA was 9/8/22, then I was hit with the info I shared.
If I can Get it, I still Will, but I can’t recommend it when there’s options that cost half as much and get the job done
The Following User Says Thank You to mycrors7 For This Useful Post:
Tcoat (09-07-2022)
oh no not again
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 02:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 05:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 03:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 12:11 PM
