| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#757 | |
Drives: Crapcan
They probably are not going to bother to check. I doubt they would check the mains either.
#758 |
Ya at the dealership level they are only go to go until they find the smoking gun. I would hope that Subaru checked the other parts though.
#760 |
Drives: 2022 Toyota GR86 Premium 6MT
Here’s my contribution.
11/21 build date. 10,200 miles, car driven as it was intended (which may or may not include non-timed non-competitive closed course driving events) External signs of issues visible in RTV oozing out of timing chain cover at all sides, longest glob I found was about half an inch in length. Oil pan RTV intact except for one ~2 inch dangly piece. Definitely overapplied at the factory, per subaru’s own specification. Several small pieces of RTV hanging out in the bottom of the oil pan. Didn’t find any RTV in the oil filter after 4k miles. One small piece of RTV on dipstick (although considering the dipstick sits right on top of the RTV bead, i don’t think this indicates any real issue). RTV clogging pickup screen, definitely not the worst i’ve seen. I’d estimate 1/3 of the top screen is blocked in some capacity. |
#761 | |
Drives: 2022 BRZ sport-tech
Thank you.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
#762 | |
No flakes. I have a magnetic drain plug and there was nothing on there other than the normal black sludge. There were 2 small flakes in the oil filter I used from 5k-9k, but that is fairly normal. |
#763 | |
#764 |
Drives: BRZ 2nd gen
A close up and personal inspection of the oil pickup screen/basket.
Really gives you perspective of the surface area at play. https://twitter.com/yonsama800/statu...69665373138945 |
#765 | |
Drives: WRX
#766 |
Drives: BRZ 2nd gen
It looks like it could hold a considerable amount of debris before clogging up, albeit this does not factor in any cavitation issues that may occur.
Any fluid dynamics experts or submariners here that could chime in on working out the requirements for cavitation? |
#767 | |
- Higher oil temps - Higher pressure differentiation pre/post pump (how bad the blockage is) Any engineer can confirm?
#768 |
Drives: zd8 brz
I have some bad news regarding the STI brz cup car oil pan..
My last resource couldn’t get it claiming it’s discontinued. I’m 99% sure it’s not possible to obtain the oil pan unless you are a shop/team building a documented cup car I’m looking further into it, but I’m not hopeful anymore |
#769 | |
FNG
Drives: Hot Wheels
I plan to go this route in the future. |
#770 | |
Drives: zd8 brz
Tbh there’s no real reason to go with the brz STI cup car oil pan. I had already started the process for purchasing it and made a payment as well. ETA was 9/8/22, then I was hit with the info I shared. If I can Get it, I still Will, but I can’t recommend it when there’s options that cost half as much and get the job done |
| Tags |
| oh no not again |
| New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 01:15 AM |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
| Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 04:18 PM |
| Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 02:33 AM |
| Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 11:11 AM |
