Old 10-27-2016, 10:43 PM   #7589
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Originally Posted by riboyster View Post
This is with no charge cooler, correct?
They were running the intercooler when they had the 335 kit installed in their shop car with e85. I almost bought it from them.
stockysnail is offline   Reply With Quote
Old 10-29-2016, 02:22 PM   #7590
8686
8686's Avatar
Drives: 86
Originally Posted by Kodename47 View Post
You'd be daft to run a 335 without one IMO. They get very hot.
There are ways to monitor the charge temps, I run a separate IAT sensor in the manifold. It's quite common on the kits here in the UK.
can you elaborate more on this. How and where did you install the sensor?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 10-29-2016, 04:46 PM   #7591
Kodename47
Kodename47's Avatar
Drives: UK GT86
Revised MAP sensor plate to fit both sensors. IAT sensor is a type that is long enough to extend into the manifold so is fast reacting to charge temps. Just rewire the IAT part of the MAF wiring to the new sensor.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-29-2016, 09:04 PM   #7592
stockysnail
Just the tip
If you lived closer to me I would pay you to help me do this. No one around here seems to want to help with that but maybe I need to throw $100s at them!
Old 10-30-2016, 05:34 AM   #7593
Kodename47
Kodename47's Avatar
Drives: UK GT86
http://www.fa20club.com/product.php?productid=18374
It's where we got the idea from. The sensor we use is different.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
stockysnail (10-30-2016)
Old 10-31-2016, 10:25 PM   #7594
camelflage
Drives: pinto power
Originally Posted by stevo585 View Post
Also anyone managed to get a custom air to air intercooled setup with this? Kits biggest downfall imo. I hear the cooler doesn't work as well as the other PD systems out there.
I have seen this on a mustang before at the track. No sure the brand but def a PD with an air to air cooler.
i think this has been talked about before, but the issue I see with the sprintex is that unlike the vortech where you take in air, compress, cool the charge, then go into the intake we dont have space between the compression and intake to cool the air.
camelflage is offline   Reply With Quote
Old 11-01-2016, 07:48 PM   #7595
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Evening All,
Ever since installing the 210 non-intercooled i'm noticing stuttering/hesitation as I accelerate through the power band at moderate pace. The hesitation can be felt at various points from 2000-3200 rpm, but is fine if accelerating rapidly.
I had Mike at MotoEast check the logs and he adjusted low-load, load RPM timing. Initially it seemed to help a bit, but I think that may have been placebo.
I've checked for vacuum leaks and boost leaks but haven't found anything thus far. Any other thoughts? Should I try swapping map sensors (I have two stock ones)? Reset the ECU? Any other thoughts? I didn't have this problem prior to installing SC, so i'm not sure if it makes sense to be related to spark plugs or injectors?
Car runs and idles just fine -- but the random 'torque dips' (as I like to think of them) are making me wonder.
ajcarson11 is offline   Reply With Quote
Old 11-02-2016, 02:20 AM   #7596
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Originally Posted by ajcarson11 View Post
Evening All,
A little more noticeable with a cold block. These hesitations are normal; welcome to the club and enjoy your positive displacement
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 11-05-2016, 03:06 PM   #7597
riboyster
riboyster's Avatar
Anyone got a 70mm Raceseng pulley they'd like to sell?
Old 11-05-2016, 03:48 PM   #7598
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Evening All,
Just make sure to warm up your oil to at least 150f and it shouldn't stutter after that. Mine does it anytime the engine is cold.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 11-05-2016, 07:29 PM   #7599
ajcarson11
Hmm... Yeah mine is stuttering enough that's it's driving me a little crazy in traffic. The power band unless I'm wot feels like it has at least 3 consistent dips around 2400, 2800, and 3200. I can feel it in the rear Everytime it dips. Hmm...
Old 11-05-2016, 07:30 PM   #7600
ajcarson11
I've got a 69mm! Trying to decide if I'll make the jump to flex fuel in the spring and use it or not... Otherwise I have no need for it.
Old 11-06-2016, 02:59 AM   #7601
riboyster
riboyster's Avatar
Dang, I'm on alcohol injection with no IC so I'm not sure I'm ready to run that kinda boost just yet. Such a pity that Raceseng discontinued their pulleys. I ordered a 70mm the other night and they emailed me with an apology. I knew I shoulda bought both of them.
Old 11-06-2016, 11:47 PM   #7602
nmastereal
Sprintex makes one now. http://www.ft86speedfactory.com/spri...l#.WB_5H_krKUk
nmastereal is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
