#7589 |
Just the tip
They were running the intercooler when they had the 335 kit installed in their shop car with e85. I almost bought it from them.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#7590 | |
Drives: 86
can you elaborate more on this. How and where did you install the sensor? Sent from my iPhone using Tapatalk
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
#7591 |
Drives: UK GT86
Revised MAP sensor plate to fit both sensors. IAT sensor is a type that is long enough to extend into the manifold so is fast reacting to charge temps. Just rewire the IAT part of the MAF wiring to the new sensor.
.: Stealth 86 :.
#7592 |
Just the tip
If you lived closer to me I would pay you to help me do this. No one around here seems to want to help with that but maybe I need to throw $100s at them!
#7593 | |
Drives: UK GT86
It's where we got the idea from. The sensor we use is different.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | stockysnail (10-30-2016) |
#7594 | |
Drives: pinto power
#7595 |
Drives: 2013 Subaru BRZ Limited (Black)
Evening All,
Ever since installing the 210 non-intercooled i'm noticing stuttering/hesitation as I accelerate through the power band at moderate pace. The hesitation can be felt at various points from 2000-3200 rpm, but is fine if accelerating rapidly. I had Mike at MotoEast check the logs and he adjusted low-load, load RPM timing. Initially it seemed to help a bit, but I think that may have been placebo. I've checked for vacuum leaks and boost leaks but haven't found anything thus far. Any other thoughts? Should I try swapping map sensors (I have two stock ones)? Reset the ECU? Any other thoughts? I didn't have this problem prior to installing SC, so i'm not sure if it makes sense to be related to spark plugs or injectors? Car runs and idles just fine -- but the random 'torque dips' (as I like to think of them) are making me wonder. |
#7596 | |
Drives: 2013 Scion FRS
ScreamingElectron - SnakeShit |
#7597 |
Anyone got a 70mm Raceseng pulley they'd like to sell?
#7598 | |
Drives: Raven FR-S
Just make sure to warm up your oil to at least 150f and it shouldn't stutter after that. Mine does it anytime the engine is cold.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#7599 |
Hmm... Yeah mine is stuttering enough that's it's driving me a little crazy in traffic. The power band unless I'm wot feels like it has at least 3 consistent dips around 2400, 2800, and 3200. I can feel it in the rear Everytime it dips. Hmm...
#7600 |
#7601 | |
I ordered a 70mm the other night and they emailed me with an apology. I knew I shoulda bought both of them.
#7602 | |
Sprintex makes one now. http://www.ft86speedfactory.com/spri...l#.WB_5H_krKUk |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
