Old 09-14-2016, 02:04 PM   #7547
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Originally Posted by ajcarson11 View Post
Thanks!
I am indeed manual.
You can see the OEM hose traced in red, with what I assume is the check-valve surrounded in the light blue box?
The OEM brake booster hose looks like it'll be long enough. And it has a check valve. If the OEM hose is not long enough, do I just need to source a hose that can go from the blue box to the back of manifold?
EDIT: Here is a higher-resolution version of the picture above for more detail: https://s16.postimg.org/okf5380zp/Sc...4_103206_1.png
Looks like I've used my stock brake tube. Just make sure it's not under the blower when you bolt it down, or you're gonna have a hell of a time. As it is, it barely has enough reach to tap the port on the SC, but it is possible and ive been running it.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 09-14-2016, 02:12 PM   #7548
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
also does it bug anyone else about the brake booster line facing up lol?
Or is that done for a reason.
I almost wanna cut it off and re-weld it pointing down.
Old 09-14-2016, 02:45 PM   #7549
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Thanks! I can easily purchase extra tubing to run from the check valve to the blower. I'm just not sure why innovate would include a separate check valve in their original kit if the stock one is in there. Maybe I just didn't understand the instructions.
Part of my day job involves quality control and user design experience... I am constantly bothered by lack of clarity in instructions!
ajcarson11 is offline   Reply With Quote
Old 09-14-2016, 06:04 PM   #7550
nmastereal
Thanks!
I am indeed manual.
the hose provided by sprintex goes from the connection at the top right (where it provides the vacuum for the brake cylinder) to the back of the supercharger.
Someone else will need to comment on using oem check valve. Should be fine if you can reuse it. You definitely need a check valve though so I wouldnt try brakes till you get it.
nmastereal is offline   Reply With Quote
The Following User Says Thank You to nmastereal For This Useful Post:
ajcarson11 (09-15-2016)
Old 09-15-2016, 11:33 PM   #7551
nmastereal
Originally Posted by Ryan86 View Post
If you open up the core these are the o rings sealing the coolant running through the core. Look at the condition on my o rings, can understand why they did not seal, causing it to leak into the manifold.
How did you know this was your problem? Ive had this installed for a year and now I am having problems. I lose almost an inch of coolant from overflow bottle over 30 min of driving when warmed up. Cant find leaks anywhere. Thought it was the pump but the pump holds fine if dried coolant provides a seal. Ordered another pump anyways.
Wondering of any tests I can do to see if its leaking into the manifold before taking off the manifold and sending it for warranty.
Also, I am feeling water moving before and after the core that is inside the blower. Just dont know if its any less than when I first installed a year ago. I am not getting any CEL but have some power loss after temps reach normal operating temps.
Also does anyone know the operating pressure of the intercooler system? I want to put pressure to the entire system and see what i can find.
Old 09-20-2016, 08:06 PM   #7552
SpeedWi
SpeedWi's Avatar
Drives: 2014 BRZ (SOLD)
Anyone else experiencing issues with extreme jerkiness around 3000 RPM and car stalling that stops. Just started happening over the last week or two.
Sent from my SM-G930T using Tapatalk
Supercharged 2014 DGM Limited
SpeedWi is offline   Reply With Quote
Old 09-20-2016, 08:28 PM   #7553
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Welcome to the innovate / Sprintex supercharger!!
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 09-20-2016, 09:05 PM   #7554
jwvand02
Drives: 2013 SWP BRZ Limited
Originally Posted by brianhj View Post
Yeah, that's true
He also said a "heartbreaker" dyno, which could mean that it's reading 10-15% lower than the typical dynojet, so it might really be 300whp vs something more like 255 with the 210 when comparing apples to apples.
jwvand02 is offline   Reply With Quote
Old 09-21-2016, 12:03 AM   #7555
SpeedWi
SpeedWi's Avatar
Have had this thing on for 10k miles and all of a sudden. Just seem so odd.
Old 09-21-2016, 01:36 AM   #7556
riboyster
riboyster's Avatar
Maybe bad batch of fuel is causing you to pull timing, and lose too much power at the surge point. Does kinda sound AFR related if you're stalling.
Old 09-21-2016, 11:30 AM   #7557
SpeedWi
SpeedWi's Avatar
Been through 2 tanks of e85 from different stations.ill just need to pull logs and just have motoeast change idle rpm on my tune.
Old 09-23-2016, 11:32 AM   #7558
ajcarson11
All -- I'm looking around for a 72.5mm pulley, but it seems raceseng discontinued it, and therefore it isn't sold anywhere. Would anyone be willing to part with theirs for $$, or trade for a 69mm?
I won't be able to run the 69mm (and it is currently up for sale in the sale section).
Thanks!
Old 09-23-2016, 11:41 AM   #7559
Chrisbrz14
Chrisbrz14's Avatar
Drives: Subaru Brz
Thanks!
Have you tried contacting motoeast?
Chrisbrz14 is offline   Reply With Quote
Old 09-23-2016, 12:05 PM   #7560
ajcarson11
Ah! Just looked and it looks like they may have this in stock. I went ahead and ordered.
Thanks!
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
