Old 06-12-2017, 06:31 AM   #743
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Yes quite possible, do you know what mods the euro 2017 version has did it get new header and the red intake or just header, maybe cats more efficient as well.
We got the full package anf the 5 kw increase and the new logic rom,like usa manuals but for some reason europe got cut down version but i dont knpw what specs
Only the header. I am aware that we could not get the complete package, because of noise regulations.
The Following User Says Thank You to nikitopo For This Useful Post:
steve99 (06-12-2017)
Old 06-12-2017, 06:32 AM   #744
steve99
Originally Posted by Tor View Post
All the same. Something doesn't add up.
Changes to A01G:
- Load Compensation MP (table is bigger and has different values at low MP)
- CL fueling Target B minor change
- OL/CL Delay minor changes
- Some changes to cranking
- All base timing tables up to 5 deg less timing advance
- Knock correction Max Advance minor adjustment, but doesn't compensate for above.
- Transient Ignition Retard different values and new table size
- Max CFP delta for Transient Ignition Retard (what is that?), other values
- Ignition timing post start, more retard
- AFR Sensor Atmospheric pressure comp, different values
- Desired Overrun Mass airflow A+B different values (maybe the same as A02G, I didn't check)
- Error codes for rear 02 sensor
17 tables not defined in the new ROM. However, none that would explain the lack of ignition advance.
One table has an error in the definition:
I think you probably using kodename47 or waynos A01G defs they had extra tables defined a a few fixes over the standard romraider defs, from memory i think that errot was in the romraider defs and also one in the cranking tables.
Yes agree none of those tavle differences are going to produce power looks like mayve economy and emissions changes mostly.
I think nikitopo might be onto it though if the euro 2017 got the updated header might be more efficient , the old stock tune was quite agressive timing wise and knocked like crazy on out rubbish fuel here.
Old 06-12-2017, 06:36 AM   #745
Tor
Tor's Avatar
Drives: Toyota GT86
Originally Posted by nikitopo View Post
The revised header is better. Maybe they managed to get the same output with a more conservative tune?
The Euro car doesn't get the new header either as far as I know.
Plus it doesn't make sense. If the new header is less restrictive, it would make sense to run more timing or the same as before. No sense in making it more conservative after the car ran successfully for 5 years. Unless they released it for 95 octane. I know someone who just took delivery of a MY17 BRZ, I'll ask him.
He had an Ecutek tuned GT86 before so I'll also ask him if it feels down on power - though I guess the new final drive makes it difficult to compare.
Did the tune come directly off a Euro car?
Tor is offline   Reply With Quote
Old 06-12-2017, 06:41 AM   #746
steve99
Came from here found it couple of days ago.
http://www.romraider.com/forum/viewt...p?f=34&t=13808
If you know someone with tactrix, see if he will let you read out the rom to be sure
Ill updare my ecutek roms tomorrow and see if ecutek has it
Old 06-12-2017, 06:54 AM   #747
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
You are correct the new header is not included:
solidONE (06-18-2017)
Old 06-12-2017, 01:15 PM   #748
elBarto
elBarto's Avatar
Drives: Toyota GT86
It's because the car with all the new stuff will produce 1 gram of Co more then the old one, that's why we (EU) got a 2013 with a 2017 bodykit.
It puts the car in a different class of pollution and the car will cost too much for anybody to buy it.
I think we got the tweaked suspension, but all the fun stuff like the header, intake and Final drive is still like the old 2013-2016 version.
They also changed the tune like @Tor mentioned to have less power it seems.
edit: EU does have the 4.3 final drive. Yay
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
The Following 2 Users Say Thank You to elBarto For This Useful Post:
nikitopo (06-12-2017), steve99 (06-12-2017)
Old 06-12-2017, 03:12 PM   #749
Kodename47
Kodename47's Avatar
Drives: UK GT86
More PI % running, so less timing would make sense.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
elBarto (06-12-2017), nikitopo (06-13-2017)
Old 06-12-2017, 03:39 PM   #750
Kodename47
Kodename47's Avatar
Drives: UK GT86
K00G still runs earlier PI Ratios..... so scratch that idea.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-12-2017, 08:22 PM   #751
Tor
Tor's Avatar
Drives: Toyota GT86
I know someone that has a MY17 BRZ. I could ask if I could do a read of his car. I usually see him every few months.
- Can I do a read and save without suitable EcuFlash defs?
- I read in some thread that during a read there is also a short write - or was that something specific of Ecutek? Don't want to brick someone else's ECU and if he agrees to let me do a read I want to be sure if I tell him it's 100% safe.
The Following User Says Thank You to Tor For This Useful Post:
Old 06-12-2017, 11:15 PM   #752
steve99
With tactrix just do a READ of ecu. After read is completed ecuflash will probably throw up a window saying unknown rom type.
Just save rom as srf or as a bin does not rearly matter as you can convert.
Tactrix wont let you write unless you make up a dummy def file for writing so no chance of harming ecu.
If you use save as function and save as a BIN file (it will thow another warning about lost data dont worry just click yes to save.
Then you will be able to read that bin file with romraider if its a K00G rom
If hour friend wants to write/tune his car i can convert the romraider def to a ecuflash def if you want
Old 06-13-2017, 07:09 AM   #753
Tor
Tor's Avatar
Drives: Toyota GT86
Thanks a lot.
It leads to another question that I'm curious about. When I started out tuning, I was adviced never to modify and reflash my stock rom. Not that I ever wanted to do that, but were there a specific reason for that advice?
E.g. if I already had A01G on my car, would there be a difference between an A01G pulled directly off a car and e.g. an OFT A01G in the areas not defined?
Old 06-13-2017, 08:51 PM   #754
steve99
Thanks a lot.
Opensource systems like oft and tactrix only modify the code area between 8000 and 13fff hex. The section between 0000-7fff is just padding and not written. Some systems pad this differently eith ff or 00 characters.
Their is no vin or other unique info in the section written so an A01G rom is same whether it came off a subaru or toyota, so no real reason to never edit your stock rom as long as you have an original somewhere. Or someone elses original.
Ecuflash srf format stores some vin and other data but this isnt written durjng flash, its just for the tactric guys to aid rom identification and dissassembly.
Tor (06-13-2017)
Old 06-13-2017, 08:54 PM   #755
Tor
Tor's Avatar
Drives: Toyota GT86
Thanks for the info. So that what is happening when saving as a .bin.
Old 06-13-2017, 08:57 PM   #756
steve99
Yes that why you get the warning that its going to dump some info, but its not needed for what we are doing
Tor (06-13-2017)
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
