Old 02-02-2013, 03:44 PM   #743
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Thanks for the heads up, just replaced em
lbroskee is offline   Reply With Quote
Old 02-02-2013, 05:19 PM   #744
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Got mine installed this afternoon. Excellent quality and they work perfectly.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 02-02-2013, 06:06 PM   #745
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
Is the GB still open?
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 02-02-2013, 06:10 PM   #746
Jacob G.
Jacob G.'s Avatar
Drives: '13 Scion FR-S Whiteout
Just installed and it looks great! Did it solo so a little tricky switching heads on my ratchet and holding up the hood but the mission was a success. I did notice a little something that is itching at me... Right at the end when my hood is raising there is a little granular sound and the two struts finish at slightly different times. Not a big deal to me as long as this isn't something harmful but just something I noticed. Also took a little paint off the 10mm bolts when unscrewing but luckily I had some touch up paint.
Jacob G. is offline   Reply With Quote
Old 02-02-2013, 08:21 PM   #747
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
The last inch of travel in the struts is "damped" to slow the travel of the hood down as it reaches its maximum height, which leads to the sound that a few people are hearing, its perfectly normal. The unfortunate side effect is that they will finish at slightly different times, but it is still better than the hood slamming up. So, good eye, and nothing to worry about, its perfectly normal.
Orbital, Matt pretty much nailed it. In fact, one of my first designs (I prototyped 5 different designs) was nearly identical to the Syms kit. But I opted against it because I could not fit a long enough strut into the area to be able to raise the hood up to a high enough level, and I really didn't like how in the way they were if you wanted to work on something like your battery or master cylinder. I eventually picked the design we have today for a number of reasons, but mainly because they were out of the way (functional), raised the hood up about 20 more degrees (functional), and being able to use longer travel struts gives a more linear spring rate that exerts less force on the ground points and leads to the "two finger operation" and "drop to close" criteria that we really wanted to hit (functional). A completely functional dress up part!
Thank you so much everyone, we love hearing the feedback and seeing the installed pictures, so keep em coming!
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
Old 02-02-2013, 08:37 PM   #748
mangostick
Drives: whiteout FRS
gotta order a set of these.. I keep knocking into the prop rod when I have the hood open.
mangostick is offline   Reply With Quote
Old 02-02-2013, 10:42 PM   #749
FRSGT86
FRSGT86's Avatar
Drives: 2013 Raven FR-S, 2005 Dodge Ram
Got these installed this afternoon and I love them!
Installation was easy, action of dampers is buttery smooth and once installed, they look like they are supposed to be there.
Only suggestion I would make is to include the 10 mm bolt for the fender bracket in the kit. Not a big deal on my car since it's Raven, but on a different colored car, the painted bolt stands out too much against the black bracket.
Only other thing I'll say is that Toyota should buy a container full of these kits and start including them on the cars from the factory!
Great job by the Grimmspeed crew, this kit makes me happy I waited til these came along and got in on this groupbuy. I'll be watching for more great products from Grimmspeed in the future!
2013 FRS 6AT in Raven!
FRSGT86 is offline   Reply With Quote
Old 02-02-2013, 11:40 PM   #750
NeedsmoreCowbell
toyotas are practical :)
NeedsmoreCowbell's Avatar
Drives: Hot Lava FRS
easy peachy :0) now to drink a beer from el salvador. This hood looks beautiful at the altitude. I love it. Thanks Grimmspeed.
NeedsmoreCowbell is offline   Reply With Quote
Old 02-03-2013, 10:05 AM   #751
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Did any of your guys and girls have a problem with the black bolts screwing in? Is it because I have the wrong angle? I will try again today....
tripjammer is offline   Reply With Quote
Old 02-03-2013, 10:09 AM   #752
lbroskee
lbroskee's Avatar
ya. if ur not straight they will get stuck. just adjust the bolt and ull be good
Old 02-03-2013, 10:21 AM   #753
tripjammer
tripjammer's Avatar
Yeah I tried that. I did not want to break anything...I guess if the raise the hood up to a straight level the black bolts will probably thread in smoothly? I could get the old bolts back in...but those black bolts are a biotch.
Old 02-03-2013, 10:24 AM   #754
lbroskee
lbroskee's Avatar
ur hoos is prolly not fully aligned with the bracket then. i had some1 wold it to make it way easier. and the black ones r a tad bigger i believe
Old 02-03-2013, 11:13 AM   #755
tripjammer
tripjammer's Avatar
Yeah i had problems getting the lower black bolt in..it would scew in, but get stuck half way. I never got to the bracket part. I gave up.
Old 02-03-2013, 12:15 PM   #756
wootwoot
Drives: FRS
Sent my payment a few days ago. Please update when you get a chance.
wootwoot is offline   Reply With Quote
Replacing Struts and Installing Coil Springs DarrenDriven DIY (Do-It-Yourself) Guides 195 04-26-2017 04:15 PM
Stock Springs/Struts FRS jadewbj Brakes, Suspension, Chassis 1 12-18-2012 10:00 AM
WANTED (GA) - Stock FR-S/BRZ struts xwd Brakes, Suspension, Chassis 8 11-07-2012 10:43 AM
performance/aftermarker struts karma003 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-07-2012 11:26 AM
JDM BRZ Struts different than USDM BRZ Struts? switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-30-2012 10:21 AM
